@DaneLLL Uart logs after doing force reset: old logs + this
3h
** WARNING: Test Key is used. **
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map…
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.65-tegra (buildbrain@mobile-u64-5414-d7000) (2
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Jetson-Small Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x8546a7898 SMBIOS=0xbabc0000 SMBIOS 3.0=0x853230000
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x00000008531ac398 to 0x00000008.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000086b800000, B
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id sharl
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible s
[ 0.000000] OF: reserved mem: initialized node fsi-carveout, compatible id nt
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nt
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000088000000-0x00000000b9ccffff]
[ 0.000000] node 0: [mem 0x00000000ba800000-0x00000000ba9affff]
[ 0.000000] node 0: [mem 0x00000000babb0000-0x00000000babcffff]
[ 0.000000] node 0: [mem 0x00000000babd0000-0x00000000babfffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000c3ffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000084fffffff]
[ 0.000000] node 0: [mem 0x0000000850000000-0x0000000851faffff]
[ 0.000000] node 0: [mem 0x0000000851fb0000-0x0000000852cf0fff]
[ 0.000000] node 0: [mem 0x0000000852cf1000-0x0000000852e52fff]
[ 0.000000] node 0: [mem 0x0000000852e53000-0x0000000852edffff]
[ 0.000000] node 0: [mem 0x0000000852ee0000-0x0000000852efffff]
[ 0.000000] node 0: [mem 0x0000000852f00000-0x000000085317ffff]
[ 0.000000] node 0: [mem 0x0000000853180000-0x000000085319ffff]
[ 0.000000] node 0: [mem 0x00000008531a0000-0x000000085321ffff]
[ 0.000000] node 0: [mem 0x0000000853220000-0x000000085323ffff]
[ 0.000000] node 0: [mem 0x0000000853240000-0x0000000853ceffff]
[ 0.000000] node 0: [mem 0x0000000853cf0000-0x0000000853f1ffff]
[ 0.000000] node 0: [mem 0x0000000853f20000-0x0000000853fdffff]
[ 0.000000] node 0: [mem 0x0000000853fe0000-0x000000085411ffff]
[ 0.000000] node 0: [mem 0x0000000854120000-0x000000085418ffff]
[ 0.000000] node 0: [mem 0x0000000854190000-0x000000085424ffff]
[ 0.000000] node 0: [mem 0x0000000854250000-0x000000085425ffff]
[ 0.000000] node 0: [mem 0x0000000854260000-0x00000008542fffff]
[ 0.000000] node 0: [mem 0x0000000854300000-0x000000085434ffff]
[ 0.000000] node 0: [mem 0x0000000854350000-0x000000085435ffff]
[ 0.000000] node 0: [mem 0x0000000854360000-0x00000008543affff]
[ 0.000000] node 0: [mem 0x00000008543b0000-0x000000085456ffff]
[ 0.000000] node 0: [mem 0x0000000854570000-0x000000085457ffff]
[ 0.000000] node 0: [mem 0x0000000854580000-0x000000085465ffff]
[ 0.000000] node 0: [mem 0x0000000854660000-0x00000008546dffff]
[ 0.000000] node 0: [mem 0x00000008546e0000-0x000000085477ffff]
[ 0.000000] node 0: [mem 0x0000000854780000-0x000000085485ffff]
[ 0.000000] node 0: [mem 0x0000000854860000-0x00000008548affff]
[ 0.000000] node 0: [mem 0x00000008548b0000-0x000000085493ffff]
[ 0.000000] node 0: [mem 0x0000000854940000-0x000000085498ffff]
[ 0.000000] node 0: [mem 0x0000000854990000-0x00000008549affff]
[ 0.000000] node 0: [mem 0x00000008549b0000-0x0000000854a4ffff]
[ 0.000000] node 0: [mem 0x0000000854a50000-0x0000000854aaffff]
[ 0.000000] node 0: [mem 0x0000000854ab0000-0x0000000854b9ffff]
[ 0.000000] node 0: [mem 0x0000000854ba0000-0x000000085537ffff]
[ 0.000000] node 0: [mem 0x0000000855380000-0x000000085555ffff]
[ 0.000000] node 0: [mem 0x0000000855560000-0x000000087b8bffff]
[ 0.000000] node 0: [mem 0x000000087b8c0000-0x000000087b90ffff]
[ 0.000000] node 0: [mem 0x000000087b910000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0, zone DMA: 304 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 80 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 31 pages/cpu s90008 r8192 d28776 u126976
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation disabled by kernel conn
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7983060
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 by)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 byt)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000a9cd0000-0x00000000b9cd00)
[ 0.000000] Memory: 31083292K/32439104K available (18496K kernel code, 3214K)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 ji.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x4f4 wi0
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398s
[ 0.000618] Console: colour dummy device 80x25
[ 0.000897] printk: console [tty0] enabled
[ 0.000935] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.000947] pid_max: default: 32768 minimum: 301
[ 0.000995] LSM: Security Framework initializing
[ 0.001060] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, l)
[ 0.001107] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 byt)
[ 0.002750] rcu: Hierarchical SRCU implementation.
[ 0.002839] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORd
[ 0.003204] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.1s
[ 0.003213] DTB Build time: May 16 2022 21:09:35
[ 0.004323] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.004443] Remapping and enabling EFI services.
[ 0.005606] smp: Bringing up secondary CPUs …
[ 0.005993] Detected PIPT I-cache on CPU1
[ 0.006025] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.006054] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006404] Detected PIPT I-cache on CPU2
[ 0.006414] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006429] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006741] Detected PIPT I-cache on CPU3
[ 0.006750] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006764] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009089] Detected PIPT I-cache on CPU4
[ 0.009112] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c000
[ 0.009137] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.009505] Detected PIPT I-cache on CPU5
[ 0.009515] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e000
[ 0.009529] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.009861] Detected PIPT I-cache on CPU6
[ 0.009871] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f50000
[ 0.009886] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.010239] Detected PIPT I-cache on CPU7
[ 0.010248] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f52000
[ 0.010262] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.012593] Detected PIPT I-cache on CPU8
[ 0.012615] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f54000
[ 0.012642] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.013009] Detected PIPT I-cache on CPU9
[ 0.013019] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f56000
[ 0.013033] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.013376] Detected PIPT I-cache on CPU10
[ 0.013387] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f5800
[ 0.013402] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.013738] Detected PIPT I-cache on CPU11
[ 0.013749] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a00
[ 0.013763] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.013814] smp: Brought up 1 node, 12 CPUs
[ 0.013879] SMP: Total of 12 processors activated.
[ 0.013883] CPU features: detected: Privileged Access Never
[ 0.013886] CPU features: detected: LSE atomic instructions
[ 0.013888] CPU features: detected: User Access Override
[ 0.013891] CPU features: detected: 32-bit EL0 Support
[ 0.013894] CPU features: detected: Common not Private translations
[ 0.013897] CPU features: detected: RAS Extension Support
[ 0.013899] CPU features: detected: Data cache clean to the PoU not requirede
[ 0.013904] CPU features: detected: CRC32 instructions
[ 0.013907] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.047510] CPU: All CPU(s) started at EL2
[ 0.049812] devtmpfs: initialized
[ 0.059016] Registered cp15_barrier emulation handler
[ 0.059033] Registered setend emulation handler
[ 0.059038] KASLR enabled
[ 0.059117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.059129] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.060665] pinctrl core: initialized pinctrl subsystem
[ 0.061084] SMBIOS 3.0.0 present.
[ 0.061091] DMI: /, BIOS r34.1-975eef6 05/16/2022
[ 0.061325] NET: Registered protocol family 16
[ 0.062173] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.062380] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic als
[ 0.062579] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic s
[ 0.062637] audit: initializing netlink subsys (disabled)
[ 0.062744] audit: type=2000 audit(0.060:1): state=initialized audit_enabled1
[ 0.063687] printk: console [ramoops-1] enabled
[ 0.063694] pstore: Registered ramoops as persistent store backend
[ 0.063700] ramoops: using 0x200000@0xba9b0000, ecc: 0
[ 0.063861] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.063863] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.063870] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.065283] cpuidle: using governor menu
[ 0.065421] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.065531] ASID allocator initialised with 65536 entries
[ 0.065677] Serial: AMBA PL011 UART driver
[ 0.067066] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.067089] Tegra reboot handler registered.
[ 0.067165] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.1s
[ 0.067174] DTB Build time: May 16 2022 21:09:35
[ 0.081266] mc: mapped MMIO address: 0x(ptrval) → 0x2c10000
[ 0.081286] mc: mapped MMIO address: 0x(ptrval) → 0x2c20000
[ 0.081296] mc: mapped MMIO address: 0x(ptrval) → 0x2c30000
[ 0.081307] mc: mapped MMIO address: 0x(ptrval) → 0x2c40000
[ 0.081316] mc: mapped MMIO address: 0x(ptrval) → 0x2c50000
[ 0.081324] mc: mapped MMIO address: 0x(ptrval) → 0x2b80000
[ 0.081334] mc: mapped MMIO address: 0x(ptrval) → 0x2b90000
[ 0.081342] mc: mapped MMIO address: 0x(ptrval) → 0x2ba0000
[ 0.081349] mc: mapped MMIO address: 0x(ptrval) → 0x2bb0000
[ 0.081358] mc: mapped MMIO address: 0x(ptrval) → 0x1700000
[ 0.081366] mc: mapped MMIO address: 0x(ptrval) → 0x1710000
[ 0.081374] mc: mapped MMIO address: 0x(ptrval) → 0x1720000
[ 0.081382] mc: mapped MMIO address: 0x(ptrval) → 0x1730000
[ 0.081390] mc: mapped MMIO address: 0x(ptrval) → 0x1740000
[ 0.081399] mc: mapped MMIO address: 0x(ptrval) → 0x1750000
[ 0.081408] mc: mapped MMIO address: 0x(ptrval) → 0x1760000
[ 0.081416] mc: mapped MMIO address: 0x(ptrval) → 0x1770000
[ 0.081425] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.081443] mc-err: mcerr ops are set to t23x
[ 0.081777] tegra23x-cbb 13a00000.cbb-en: secure_irq = 21
[ 0.081843] tegra23x-cbb c600000.aon-en: secure_irq = 22
[ 0.081891] tegra23x-cbb de00000.dce-en: secure_irq = 23
[ 0.081933] tegra23x-cbb be00000.rce-en: secure_irq = 24
[ 0.081970] tegra23x-cbb b600000.sce-en: secure_irq = 25
[ 0.085699] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.085710] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.085715] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.085720] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.087088] ACPI: Interpreter disabled.
[ 0.088184] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 0.088295] vbusA-cvb: supplied by vdd-5v-sys
[ 0.088372] vbusB-cvb: supplied by vdd-5v-sys
[ 0.088483] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 0.088561] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 0.088971] iommu: Default domain type: Translated
[ 0.089013] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.089160] SCSI subsystem initialized
[ 0.089220] usbcore: registered new interface driver usbfs
[ 0.089234] usbcore: registered new interface driver hub
[ 0.089249] usbcore: registered new device driver usb
[ 0.089429] mc: Linux media interface: v0.10
[ 0.089439] videodev: Linux video capture interface: v2.00
[ 0.089580] pps_core: LinuxPPS API ver. 1 registered
[ 0.089586] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.089594] PTP clock support registered
[ 0.089793] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.089832] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.091137] Registered efivars operations
[ 0.091585] FPGA manager framework
[ 0.091771] Advanced Linux Sound Architecture Driver Initialized.
[ 0.092042] Bluetooth: Core ver 2.22
[ 0.092059] NET: Registered protocol family 31
[ 0.092064] Bluetooth: HCI device and connection manager initialized
[ 0.092072] Bluetooth: HCI socket layer initialized
[ 0.092081] Bluetooth: L2CAP socket layer initialized
[ 0.092090] Bluetooth: SCO socket layer initialized
[ 0.092614] camchar: rtcpu character device driver loaded
[ 0.092841] clocksource: Switched to clocksource arch_sys_counter
[ 0.243047] VFS: Disk quotas dquot_6.6.0
[ 0.243091] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.243201] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.243406] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 06
[ 0.243418] tegra-carveouts tegra-carveouts: assigned reserved memory node ft
[ 0.243433] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 02
[ 0.243441] nvmap_page_pool_init: Total RAM pages: 7836359
[ 0.243446] nvmap_page_pool_init: nvmap page pool size: 979544 pages (3826 M)
[ 0.243454] pnp: PnP ACPI: disabled
[ 0.243528] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.243602] misc nvmap: created heap vpr base 0x00000000d6000000 size (68812)
[ 0.245130] la/ptsa driver initialized.
[ 0.245176] NET: Registered protocol family 2
[ 0.245379] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, l)
[ 0.247179] misc nvmap: created heap fsi base 0x00000000bf000000 size (16384)
[ 0.247520] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 26)
[ 0.247567] TCP established hash table entries: 262144 (order: 9, 2097152 by)
[ 0.247762] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, lin)
[ 0.248190] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.248264] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.248322] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, line)
[ 0.248454] NET: Registered protocol family 1
[ 0.248686] RPC: Registered named UNIX socket transport module.
[ 0.248698] RPC: Registered udp transport module.
[ 0.248702] RPC: Registered tcp transport module.
[ 0.248707] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.248718] PCI: CLS 0 bytes, default 64
[ 0.248818] Trying to unpack rootfs image as initramfs…
[ 0.358143] Freeing initrd memory: 8196K
[ 0.359993] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[ 0.360205] kvm [1]: IPA Size Limit: 48 bits
[ 0.360370] kvm [1]: VHE mode initialized successfully
[ 0.360946] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.362331] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.362528] NFS: Registering the id_resolver key type
[ 0.362548] Key type id_resolver registered
[ 0.362553] Key type id_legacy registered
[ 0.362578] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.362590] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registerin.
[ 0.362604] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.373932] NET: Registered protocol family 38
[ 0.373959] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 0.374013] io scheduler mq-deadline registered
[ 0.374019] io scheduler kyber registered
[ 0.377437] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.377467] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.377487] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.377504] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.379681] tegra_dc_assign_hw_data: no matching compatible node
[ 0.379689] tegradccommon module_init failed
[ 0.379695] tegradc module_init failed
[ 0.379905] EINJ: ACPI disabled.
[ 0.381157] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.381167] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 0.381173] tegra-pmc: ### PMC reset level: L0
[ 0.381178] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.382185] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.386284] random: fast init done
[ 0.387327] printk: console [ttyTCU0] enabled
[ 2.201077] arm-smmu 12000000.iommu: probing hardware configuration…
[ 2.206973] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.211522] arm-smmu 12000000.iommu: stage 1 translation
[ 2.216865] arm-smmu 12000000.iommu: stage 2 translation
[ 2.222372] arm-smmu 12000000.iommu: nested translation
[ 2.227536] arm-smmu 12000000.iommu: stream matching with 128 regists
[ 2.234710] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 on)
[ 2.242962] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.247745] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.254308] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.261463] arm-smmu 10000000.iommu: probing hardware configuration…
[ 2.267346] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.272069] arm-smmu 10000000.iommu: stage 1 translation
[ 2.277583] arm-smmu 10000000.iommu: stage 2 translation
[ 2.283006] arm-smmu 10000000.iommu: nested translation
[ 2.288433] arm-smmu 10000000.iommu: stream matching with 128 regists
[ 2.295608] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 on)
[ 2.303936] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.308819] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.315382] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.322302] arm-smmu 8000000.iommu: probing hardware configuration…
[ 2.328507] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.333230] arm-smmu 8000000.iommu: stage 1 translation
[ 2.338743] arm-smmu 8000000.iommu: stage 2 translation
[ 2.344168] arm-smmu 8000000.iommu: nested translation
[ 2.349334] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.356505] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.364813] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.369719] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.376281] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.383404] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe sl
[ 2.392442] tegra_profiler: version: 1.146, samples/io: 49/28
[ 2.396488] tegra_profiler: auth: init
[ 2.401319] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 2.406884] libphy: Fixed MDIO Bus: probed
[ 2.410231] tun: Universal TUN/TAP device driver, 1.6
[ 2.415817] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versin
[ 2.422574] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.428099] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.432895] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.438856] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.444269] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.450118] PPP generic driver version 2.4.2
[ 2.454470] PPP BSD Compression module registered
[ 2.459150] PPP Deflate Compression module registered
[ 2.464405] PPP MPPE Compression module registered
[ 2.469223] usbcore: registered new interface driver r8152
[ 2.474550] usbcore: registered new interface driver asix
[ 2.479978] usbcore: registered new interface driver ax88179_178a
[ 2.486101] usbcore: registered new interface driver cdc_ether
[ 2.492050] usbcore: registered new interface driver net1080
[ 2.497648] usbcore: registered new interface driver cdc_subset
[ 2.503685] usbcore: registered new interface driver zaurus
[ 2.509379] usbcore: registered new interface driver cdc_ncm
[ 2.515061] usbcore: registered new interface driver aqc111
[ 2.520581] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.526788] ohci-pci: OHCI PCI platform driver
[ 2.531084] ohci-platform: OHCI generic platform driver
[ 2.536406] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 2.542244] usbcore: registered new interface driver uas
[ 2.547363] usbcore: registered new interface driver usb-storage
[ 2.553332] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 2.559184] mousedev: PS/2 mouse device common for all mice
[ 2.564510] usbcore: registered new interface driver xpad
[ 2.571735] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.575303] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:)
[ 2.583056] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.589280] i2c /dev entries driver
[ 2.592858] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 2.598437] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 2.603831] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 2.609244] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 2.614579] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 2.620097] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 2.625516] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 2.630852] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 2.637938] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not en.
[ 2.644475] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not en.
[ 2.653559] device-mapper: uevent: version 1.0.3
[ 2.657400] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-m
[ 2.666663] sdhci: Secure Digital Host Controller Interface driver
[ 2.672122] sdhci: Copyright(c) Pierre Ossman
[ 2.676581] Synopsys Designware Multimedia Card Interface Driver
[ 2.682689] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.688522] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 2.688607] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 2.689381] pstore: ignoring unexpected backend ‘efi’
[ 2.689831] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.690978] tegra-bpmp bpmp: firmware: 43f75b5aad2b8e1992e4-f0425a554b3
??debugfs initialized
??[ 4.460749] hid: raw HID events driver (C) Jiri Kosina
[ 4.461438] usbcore: registered new interface driver usbhid
[ 4.461597] usbhid: USB HID core driver
[ 4.461911] tegra-dce d800000.dce: Adding to iommu group 6
[ 4.463540] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for c]
[ 4.465639] dce: dce_wait_boot_complete:100 dce is ready to receive bootstrs
[ 4.465671] tegra234-aon c000000.aon: Adding to iommu group 7
[ 4.467021] c000000.aon:hsp: probed
[ 4.467305] tegra234-aon c000000.aon: init done
[ 4.467673] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 4.468126] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 4.468324] tegra23x-psc e860000.psc: init done
[ 4.468594] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 4.469381] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOV0
[ 4.470284] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple t]
[ 4.470542] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel.
[ 4.470968] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 4.473794] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-04
[ 4.475231] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple t]
[ 4.483742] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX0
[ 4.492451] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for.
[ 4.492453] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel.
[ 4.492465] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel.
[ 4.503625] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[10
[ 4.511609] dce: dce_admin_setup_clients_ipc:456 Get queue info failed for ]
[ 4.511710] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple t]
[ 4.520528] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[10
[ 4.528762] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for.
[ 4.528766] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel.
[ 4.540020] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ve0
[ 4.546977] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel.
[ 4.547151] dce: dce_worker:209 DCE_BOOT_DONE
[ 4.555912] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ve0
[ 4.621890] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX0
[ 4.634021] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (115)
[ 4.639804] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is sucl
[ 4.651472] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=66
[ 4.660946] t19x_cache tegra-cache: probed
[ 4.663115] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 4.689270] nvpmodel: initialized successfully
[ 4.689725] tegra_hv: get_hvd: not initialized yet
[ 4.689905] user_ivc_mempool: hypervisor not present
[ 4.690638] usbcore: registered new interface driver snd-usb-audio
[ 4.691447] u32 classifier
[ 4.692208] input device check on
[ 4.695892] Actions configured
[ 4.699307] Initializing XFRM netlink socket
[ 4.703946] NET: Registered protocol family 10
[ 4.708938] Segment Routing with IPv6
[ 4.711683] random: crng init done
[ 4.714916] NET: Registered protocol family 17
[ 4.719353] NET: Registered protocol family 15
[ 4.723843] bridge: filtering via arp/ip/ip6tables is no longer available by.
[ 4.736883] Bluetooth: RFCOMM socket layer initialized
[ 4.741838] Bluetooth: RFCOMM ver 1.11
[ 4.745592] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.751628] Bluetooth: HIDP socket layer initialized
[ 4.756928] 9pnet: Installing 9P2000 support
[ 4.760847] Key type dns_resolver registered
[ 4.765884] registered taskstats version 1
[ 4.769604] pstore: Using crash dump compression: deflate
[ 4.775067] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 4.786319] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 4.787959] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 4.798674] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 4.800382] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 4.811026] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 4.832405] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 4.833574] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 4.833933] host1x 13e40000.host1x: Adding to iommu group 13
[ 5.841837] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 5.849883] host1x 13e40000.host1x: initialized
[ 5.850314] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu gr4
[ 5.850830] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (strea)
[ 5.852418] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu gr5
[ 5.852855] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (strea)
[ 5.854423] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu gr6
[ 5.854844] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (strea)
[ 5.856386] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu gr7
[ 5.856793] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (strea)
[ 5.858337] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu gr8
[ 5.858746] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (strea)
[ 5.860284] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu gr9
[ 5.860694] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (strea)
[ 5.871930] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu gr0
[ 5.878530] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (strea)
[ 5.889958] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu gr1
[ 5.896505] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (strea)
[ 5.907980] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu gr2
[ 5.914559] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (strea)
[ 5.926000] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu gr3
[ 5.932594] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (strea)
[ 5.944007] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu gr4
[ 5.950590] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (strea)
[ 5.962056] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu gr5
[ 5.968625] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (strea)
[ 5.980087] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu gr6
[ 5.986633] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (strea)
[ 5.998097] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu gr7
[ 6.004690] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (strea)
[ 6.016126] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu gr8
[ 6.022666] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (strea)
[ 6.034150] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu gr9
[ 6.040717] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (strea)
[ 6.052196] falcon 15340000.vic: Adding to iommu group 30
[ 6.061025] falcon 15340000.vic: initialized
[ 6.061359] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.069820] falcon 15380000.nvjpg: initialized
[ 6.071146] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.079293] falcon 15540000.nvjpg1: initialized
[ 6.081545] falcon 154c0000.nvenc: Adding to iommu group 33
[ 6.091653] falcon 154c0000.nvenc: initialized
[ 6.091892] falcon 15a50000.ofa: Adding to iommu group 34
[ 6.100251] falcon 15a50000.ofa: initialized
[ 6.101689] nvdec 15480000.nvdec: Adding to iommu group 35
[ 6.114011] nvdec 15480000.nvdec: initialized
[ 6.114233] tsec 15500000.tsec: Adding to iommu group 36
[ 6.121406] tsec 15500000.tsec: initialized
[ 6.123374] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.133311] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.140994] gpio-394 (camera-control-output-low): hogged as output/low
[ 6.141184] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.147425] gpio-487 (camera-control-output-low): hogged as output/low
[ 6.153636] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.161036] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.167096] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.173183] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.179291] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.184922] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.190537] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 6.197844] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_isos
[ 6.204267] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 6.212813] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disU
[ 6.219520] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.225547] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group8
[ 6.233254] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group9
[ 6.240301] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolationU
[ 6.249574] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.255579] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: grid-of-semaphored
[ 6.263681] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolationU
[ 6.273267] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.279457] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: grid-of-semaphored
[ 6.287923] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolationU
[ 6.297596] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.303781] scare-pigeon 13e40000.host1x:isp-thi@14b00000: grid-of-semaphored
[ 6.312283] pva 16000000.pva0: Adding to iommu group 40
[ 6.335939] pva 16000000.pva0: initialized
[ 6.342416] nvdla 15880000.nvdla0: Adding to iommu group 41
[ 6.350546] nvdla 15880000.nvdla0: initialized
[ 6.352258] nvdla 158c0000.nvdla1: Adding to iommu group 42
[ 6.360088] nvdla 158c0000.nvdla1: initialized
[ 6.361748] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.361930] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.362274] serial-tegra 3100000.serial: Adding to iommu group 3
[ 6.362822] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud =T
[ 6.370041] serial-tegra 3130000.serial: Adding to iommu group 3
[ 6.376062] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 64, base_baud =T
[ 6.407324] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10e
[ 6.407588] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.407762] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus nu1
[ 6.408726] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x1200
[ 6.416415] tegra-xusb 3610000.xhci: irq 232, io mem 0x03610000
[ 6.422521] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, b0
[ 6.430654] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 6.437828] usb usb1: Product: xHCI Host Controller
[ 6.442813] usb usb1: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 6.448852] usb usb1: SerialNumber: 3610000.xhci
[ 6.453952] hub 1-0:1.0: USB hub found
[ 6.457366] hub 1-0:1.0: 4 ports detected
[ 6.461560] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.466796] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus nu2
[ 6.474417] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSped
[ 6.481840] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, b0
[ 6.489987] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 6.497238] usb usb2: Product: xHCI Host Controller
[ 6.502227] usb usb2: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 6.508174] usb usb2: SerialNumber: 3610000.xhci
[ 6.513244] hub 2-0:1.0: USB hub found
[ 6.516774] hub 2-0:1.0: 4 ports detected
[ 6.521897] bwmgr API not supported
[ 6.521902] tegra-xusb 3610000.xhci: can’t register EMC bwmgr (-22)
[ 6.553806] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequz
[ 6.557253] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequz
[ 6.560272] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequz
[ 6.565715] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.571155] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 6.576522] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff0
[ 6.580690] mmc0: CQHCI version 5.10
[ 6.584920] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff0
[ 6.596910] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff0
[ 6.607205] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 6.619421] irq: IRQ290: trimming hierarchy from :pmc@c360000
[ 6.619610] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 290
[ 6.620549] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADt
[ 6.712836] tegra194-pcie 14100000.pcie: Link up
[ 6.713938] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.714119] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.714262] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus add)
[ 6.714511] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20affffff)
[ 6.714790] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7fffff]
[ 6.715030] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 6.715294] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 6.718588] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 6.718834] mmc0: Command Queue Engine enabled
[ 6.718869] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 6.718955] mmc0: periodic cache flush enabled
[ 6.718960] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.719242] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.719824] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 6.721103] pci 0001:01:00.0: supports D1 D2
[ 6.725182] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510)
[ 6.729460] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 6.736641] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 6.746461] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80ffff]
[ 6.757482] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.763795] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff]
[ 6.771532] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.777781] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.782837] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.788963] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 6.795970] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), 2
[ 6.804672] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), 2
[ 6.813333] pcieport 0001:00:00.0: Adding to iommu group 10
[ 6.818999] pcieport 0001:00:00.0: PME: Signaling with IRQ 50
[ 6.824731] pcieport 0001:00:00.0: AER: enabled with IRQ 50
[ 6.830892] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.837354] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 6.843235] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff0
[ 6.851897] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff0
[ 6.852039] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 6.860361] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff0
[ 6.921444] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bc0
[ 6.921666] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.921858] usb 1-3: Product: Bluetooth Radio
[ 6.921978] usb 1-3: Manufacturer: Realtek
[ 6.922084] usb 1-3: SerialNumber: 00e04c000001
[ 7.045935] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegrb
[ 7.083099] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bc0
[ 7.083334] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.083539] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 7.083682] usb 2-3: Manufacturer: Generic
[ 7.094156] hub 2-3:1.0: USB hub found
[ 7.096372] hub 2-3:1.0: 4 ports detected
[ 7.200968] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 7.368960] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bc0
[ 7.369197] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.369401] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 7.369531] usb 1-4: Manufacturer: Generic
[ 7.371563] hub 1-4:1.0: USB hub found
[ 7.372979] hub 1-4:1.0: 4 ports detected
[ 7.965301] tegra194-pcie 14160000.pcie: Phy link never came up
[ 7.965517] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 7.965707] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 7.965863] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus )
[ 7.966143] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242ffffff)
[ 7.966440] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427fffff]
[ 7.966690] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 7.966969] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 7.972781] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 7.972935] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), 2
[ 7.973367] pcieport 0004:00:00.0: Adding to iommu group 11
[ 7.973671] pcieport 0004:00:00.0: PME: Signaling with IRQ 52
[ 7.974156] pcieport 0004:00:00.0: AER: enabled with IRQ 52
[ 7.974495] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 7.974725] pci 0004:00:00.0: Removing from iommu group 11
[ 7.974875] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 7.981214] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 7.986240] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 7.990864] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 7.995503] vdd-dp: supplied by vdd-3v3-sys
[ 7.999715] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 8.004585] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 8.011018] tegra194-isp5 14800000.isp: initialized
[ 8.016400] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 8.020619] (NULL device *): fops function table already registered
[ 8.027602] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 8.033264] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.038744] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.052403] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 290
[ 8.149875] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 8.150089] tegra194-pcie 141a0000.pcie: IO 0x003a100000…0x003a1fffff0
[ 8.150333] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000…0x2b2fffffff0
[ 8.150572] tegra194-pcie 141a0000.pcie: MEM 0x2740000000…0x2b27ffffff0
[ 9.088944] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADt
[ 9.253174] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 9.253392] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.253577] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.253733] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus )
[ 9.254013] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2ffffff)
[ 9.254311] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27fffff]
[ 9.254553] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 9.254831] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 9.260621] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 9.260771] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), 2
[ 9.261200] pcieport 0005:00:00.0: Adding to iommu group 12
[ 9.261505] pcieport 0005:00:00.0: PME: Signaling with IRQ 54
[ 9.261986] pcieport 0005:00:00.0: AER: enabled with IRQ 54
[ 9.262327] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 9.262553] pci 0005:00:00.0: Removing from iommu group 12
[ 9.262701] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 9.269061] nvethernet 6810000.ethernet: Adding to iommu group 43
[ 9.274275] nvethernet 6810000.ethernet: failed to read skip mac reset flag,0
[ 9.282026] nvethernet 6810000.ethernet: failed to read MDIO address
[ 9.288574] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 9.295401] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- defauG
[ 9.303140] nvethernet 6810000.ethernet: failed to get phy reset gpio error:2
[ 9.314517] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:77:b0
[ 9.318000] nvethernet 6810000.ethernet: Macsec not enabled
[ 9.323298] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 9.332677] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 Ds
[ 9.338894] irq: IRQ292: trimming hierarchy from :pmc@c360000
[ 9.344242] irq: IRQ293: trimming hierarchy from :interrupt-controller@f40001
[ 9.351674] irq: IRQ294: trimming hierarchy from :pmc@c360000
[ 9.357285] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 9.364893] tegra-se-nvhost 15810000.se: Adding to iommu group 44
[ 9.370659] tegra-se-nvhost 15810000.se: initialized
[ 9.381611] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 9.381891] tegra-se-nvhost 15820000.se: Adding to iommu group 45
[ 9.388032] tegra-se-nvhost 15820000.se: initialized
[ 9.394527] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 9.398710] tegra-se-nvhost 15840000.se: Adding to iommu group 46
[ 9.405134] tegra-se-nvhost 15840000.se: initialized
[ 9.413324] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 9.416565] tegra_actmon d230000.actmon: in actmon_register()…
[ 9.422137] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 9.427838] tegra_actmon d230000.actmon: initialization Completed for the del
[ 9.435671] hvc_sysfs: hypervisor is not present
[ 9.472572] ALSA device list:
[ 9.472664] No soundcards found.
[ 9.473332] Freeing unused kernel memory: 3968K
[ 9.473529] Run /init as init process
[ 9.484379] Root device found: mmcblk0p1
[ 9.484965] Found dev node: /dev/mmcblk0p1
[ 9.508665] EXT4-fs (mmcblk0p1): bad geometry: block count 15191731 exceeds )
[ 9.509314] ERROR: mmcblk0p1 mount fail…
[ 39.901018] vdd-12v-sys: disabling
[ 39.901127] vdd-1v8-sys: disabling
[ 39.901223] vdd-3v3-ftdi: disabling
[ 39.901331] vdd-3v3-pcie: disabling
[ 39.901434] avdd-cam-2v8: disabling
[ 39.901538] vdd-12v-pcie: disabling
[ 39.901640] dsi-vdd-1v8-bl-en: disabling
