Dear admin,
Currently, the version of Jetpack installed on Jetson Orin Nano Developer Kits 8GB is 6 and I would like to downgrade the version to 5.1.3 or 5.1.2.
I tried a couple of times with SDK manager in recovery mode, but I failed to flash SD card with error messages.
The logs with error are here:
11:02:04 INFO: Flash Jetson Linux - flash: [ 0.3904 ] Offset :4608 Len :3584
11:02:04 ERROR: Flash Jetson Linux - flash: [ 0.4047 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
11:02:04 INFO: Flash Jetson Linux - flash: [ 0.4162 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
11:02:04 ERROR: Flash Jetson Linux - flash: [ 0.4280 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
11:02:04 INFO: Flash Jetson Linux - flash: [ 0.4346 ] Generating SHA2 Hash for mb1bct
11:02:04 INFO: Flash Jetson Linux - flash: [ 0.4405 ] adding BCH for mb1_bct_MB1_aligned.bct
11:02:04 INFO: Flash Jetson Linux - flash: [ 0.4456 ] Assuming zero filled SBK key
11:02:04 INFO: Flash Jetson Linux - flash: [ 0.4577 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
11:02:04 INFO: Flash Jetson Linux - flash: [ 0.4587 ] BR_CID: 0x80012344705DD4432000000018FF8180
11:02:04 INFO: Flash Jetson Linux - flash: [ 0.4845 ] Sending bct_br
11:02:09 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
11:02:09 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 7s ]
11:02:09 ERROR: Flash Jetson Linux - flash: command terminated with error
11:02:09 SUMMARY: DateTime Target Setup - target: Depends on failed component
11:32:09 INFO: *** Retrying to install. attempt number: 2
11:32:09 INFO: CUDA Runtime - target: verifying checksum of /home/roy/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb
11:32:09 INFO: CuDNN Runtime - target: verifying checksum of /home/roy/Downloads/nvidia/sdkm_downloads/cudnn-local-tegra-repo-ubuntu2004-8.6.0.166_1.0-1_arm64.deb
11:32:09 INFO: TensorRT Runtime - target: verifying checksum of /home/roy/Downloads/nvidia/sdkm_downloads/nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb
11:32:09 INFO: OpenCV Runtime - target: verifying checksum of /home/roy/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
11:32:22 ERROR: Flash Jetson Linux - flash: [ 0.1728 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
11:32:22 ERROR: Flash Jetson Linux - flash: [ 0.1951 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
11:32:22 ERROR: Flash Jetson Linux - flash: [ 0.1966 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
11:32:22 INFO: Flash Jetson Linux - flash: [ 0.2091 ] adding BCH for mb1_bct_MB1_aligned.bct
11:32:22 INFO: Flash Jetson Linux - flash: [ 0.2125 ] Assuming zero filled SBK key
11:32:22 INFO: Flash Jetson Linux - flash: [ 0.2258 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
11:32:22 INFO: Flash Jetson Linux - flash: [ 0.2270 ] BR_CID: 0x80012344705DD4432000000018FF8180
11:32:22 INFO: Flash Jetson Linux - flash: [ 0.2531 ] Sending bct_br
11:32:27 ERROR: Flash Jetson Linux - flash: [ 0.2963 ] ERROR: might be timeout in USB write.
11:32:27 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
11:32:27 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
11:32:27 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 5s ]
11:32:27 ERROR: Flash Jetson Linux - flash: command terminated with error
11:32:27 SUMMARY: DateTime Target Setup - target: Depends on failed component
11:32:54 INFO: CUDA Runtime - target: verifying checksum of /home/roy/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb
11:32:54 INFO: CuDNN Runtime - target: verifying checksum of /home/roy/Downloads/nvidia/sdkm_downloads/cudnn-local-tegra-repo-ubuntu2004-8.6.0.166_1.0-1_arm64.deb
11:32:54 INFO: TensorRT Runtime - target: verifying checksum of /home/roy/Downloads/nvidia/sdkm_downloads/nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb
11:32:55 INFO: OpenCV Runtime - target: verifying checksum of /home/roy/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
11:33:22 ERROR: Flash Jetson Linux - flash: [ 0.1633 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
11:33:22 INFO: Flash Jetson Linux - flash: [ 0.1691 ] Generating SHA2 Hash for mb1bct
11:33:22 INFO: Flash Jetson Linux - flash: [ 0.1747 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
11:33:22 INFO: Flash Jetson Linux - flash: [ 0.1779 ] Assuming zero filled SBK key
11:33:22 ERROR: Flash Jetson Linux - flash: [ 0.1860 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
11:33:22 INFO: Flash Jetson Linux - flash: [ 0.1925 ] Generating SHA2 Hash for mb1bct
11:33:22 INFO: Flash Jetson Linux - flash: [ 0.1998 ] adding BCH for mb1_bct_MB1_aligned.bct
11:33:22 INFO: Flash Jetson Linux - flash: [ 0.2034 ] Assuming zero filled SBK key
11:33:23 INFO: Flash Jetson Linux - flash: [ 0.2203 ] BR_CID: 0x80012344705DD4432000000018FF8180
11:33:23 INFO: Flash Jetson Linux - flash: [ 0.2507 ] Sending bct_br
11:33:28 ERROR: Flash Jetson Linux - flash: [ 0.2931 ] ERROR: might be timeout in USB write.
11:33:28 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
11:33:28 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
11:33:28 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 6s ]
11:33:28 ERROR: Flash Jetson Linux - flash: command terminated with error
11:33:28 SUMMARY: DateTime Target Setup - target: Depends on failed component
are there any problems causing errors?
Thank you :)
