19:31:49 DEBUG: Flash Jetson Linux - flash: using adapter to install NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS to /home/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS
19:31:49 INFO: Flash Jetson Linux - flash: user entered nvme0n1p1
19:31:49 INFO: Flash Jetson Linux - flash: *** Checking target board connection … 1 connections found.
19:31:50 ERROR: Flash Jetson Linux - flash: [ 0.0444 ] ERROR: failed to read rcm_state
19:31:50 INFO: Flash Jetson Linux - flash: [ 0.4160 ] adding BCH for mb2_t234_aligned.bin
19:31:50 INFO: Flash Jetson Linux - flash: [ 0.4500 ] adding BCH for mb2_t234_aligned.bin
19:31:50 INFO: Flash Jetson Linux - flash: [ 0.5608 ] Assuming zero filled SBK key
19:31:50 INFO: Flash Jetson Linux - flash: [ 0.7407 ] Offset :4608 Len :3584
19:31:50 ERROR: Flash Jetson Linux - flash: [ 0.8297 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
19:31:50 ERROR: Flash Jetson Linux - flash: [ 0.9301 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
19:31:51 INFO: Flash Jetson Linux - flash: [ 0.9917 ] Assuming zero filled SBK key
19:31:51 INFO: Flash Jetson Linux - flash: [ 1.0989 ] Sending bct_br
19:31:52 INFO: CUDA Runtime - target: Found file /home/nvidia/nvidia_down/cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb with correct checksum, skip downloading.
19:31:52 INFO: CUDA Toolkit for L4T - target: Found file /home/nvidia/nvidia_down/cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb with correct checksum, skip downloading.
19:31:56 ERROR: Flash Jetson Linux - flash: [ 1.1417 ] ERROR: might be timeout in USB write.
19:31:56 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
19:31:56 ERROR: Flash Jetson Linux - flash: command terminated with error
19:31:56 SUMMARY: DateTime Target Setup - target: Depends on failed component
ubuntu 18.04,
sdk mannger 1.9.1
The development board has already been flashed.
I want to refresh the machine again,however I have encountered a problem
Was that board also flashed by this host before?
It’s not this host, it’s a system that was flashed before leaving the factory
Then dump the serial console log and your host side log first.
Then there is nothing I can help. Please contact the board vendor to see how to dump uart log.
If you are the board maker, then please check with your hardware engineer to get the UART pin out.
