hi team
we design the carrier board ourselves, we design the sch according to Xavier NX reference design. when we install the orin NX 8GB CPU module and the NvME SSD. put the CPU into Recover Mode, and the download process will fail at 91% of flash Jetson linux. when happens,the USB device disappear first, then the sdkmanager display error.
SDKM_logs_2023-04-04_14-00-01.zip (740.6 KB)
13:57:25 ERROR: Flash Jetson Linux - flash: kpoint 540000
13:57:26 ERROR: Flash Jetson Linux - flash: 550000
13:57:57 ERROR: Flash Jetson Linux - flash: [ 0.4338 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
13:57:57 ERROR: Flash Jetson Linux - flash: [ 0.4363 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
13:57:57 ERROR: Flash Jetson Linux - flash: [ 0.4684 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
13:58:03 ERROR: Flash Jetson Linux - flash: 39726 blocks
13:58:03 ERROR: Flash Jetson Linux - flash: gzip: /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
13:58:11 ERROR: Flash Jetson Linux - flash: 56174 blocks
13:58:12 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000684374 s, 29.2 kB/s
13:58:14 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 1.63707 s, 41.0 MB/s
13:58:20 ERROR: Flash Jetson Linux - flash: Node /fragment@0 has a unit name, but no reg property
13:58:20 ERROR: Flash Jetson Linux - flash: /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
13:58:25 ERROR: Flash Jetson Linux - flash: [ 4.3418 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
13:58:28 ERROR: Flash Jetson Linux - flash: [ 7.2748 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
13:58:28 ERROR: Flash Jetson Linux - flash: [ 7.3192 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
13:58:28 ERROR: Flash Jetson Linux - flash: [ 7.3276 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
13:58:34 ERROR: Flash Jetson Linux - flash: 56174 blocks
13:58:42 ERROR: Flash Jetson Linux - flash: 83155 blocks
13:58:49 ERROR: Flash Jetson Linux - flash: [ 0.4828 ] ERROR: might be timeout in USB write.
13:58:49 ERROR: Flash Jetson Linux - flash: command terminated with error
13:58:49 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
the full sdkmanager log is in attachment.
the CPU module + SSD can be download ok in your xavier NX developer kit.
we want to know what cause this issue, what’s wrong prevent the download going on?
