the orin nano 4G/8G BOARD ID, BOARDSKU,FAB, BOARDREV IS ?
May I know why this is important to you? Any purpose?
Hi, please refer to the FAQ site for more info.
I want to flashing the module by executing ./flash.sh
sudo ./flash.sh jetson-orin-nano-dekvit nvme0n1p1
but report some error:
flash_log.txt (54.4 KB)
because any error referred to
so need to BOARD ID, BOARDSKU,FAB, BOARDREV
Can you specify where it is in the document or give
你的問題很顯然跟你貼的那一篇不一 樣,請不要搞混…
這些資訊是你在沒有接device的情況下想要手動燒NVMe/USB drive,或者是module上的EEPROM壞掉、讀不出來的時候才需要
Board ID(3767) version(300) sku(0004) revision(M.3)
Chip SKU(00:00:00:D6) ramcode(00:00:00:04) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
你的log裡顯示這些資訊是對的
你的問題是flashing command完全是錯的,如果你想flash NVME SSD的話,flashing command請使用以下其一
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 jetson-orin-nano-devkit internal
sudo ./flash.sh jetson-orin-nano-devkit-nvme internal
excutive order: sudo ./flash.sh jetson-orin-nano-devkit-nvme internal
Report the same error
New order log.txt (54.6 KB)
麻煩也抓一下serial console log
what is the baud rate?
Connection speed is 115200, with 8 bits, no parity, and 1 stop bit (115200 8N1).
log3.txt (177.7 KB)
this log is PIN FC_REC connect GND;
請問你真的知道自己在做什麼嗎
我是要你附上flash過程中的serial console log,你給我開機成功的log完全沒有意義…
I’m sorry !
这是 flash 过程中的 serial console log
log4.txt (5.2 KB)
I> Applet (version: 0.0.0.0-t234-54845784-8d394889)
I> t234-A01-1-Silicon (0x12347)
I> Emulation:
I> Entry timestamp: 0xffffffff
I> Task: Pinmux init (0x4000062d)
I> Task: Boot device init (0x40001321)
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI-0l initialized successfully
E> Error in command_complete 18000 int_status
E> OCR failed, error = 39390706
E> Failed to open sdmmc-3, err = 39390706
W> Ignoring init failure for device 0-3
W> Ignoring init failure for device 1-3
E> Unknown device 7
E> Unknown device 8
I> Task: Partition Manager Init (0x40002d61)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: I2C register (0x400006a5)
I> Task: Register exit handlers (0x400005f5)
I> Task: Enter 3p server (0x40001925)
I> USB configuration success
I> Populate chip info
I> RAM_CODE 0x4000041
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> Rebooting : reboot-recovery
後面就沒有東西了?
請問你是用DevKit還是custom board?
如果是custom board的話麻煩先把同一塊module插到DevKit上驗證一下
你可以用initrd flash再試一次嗎?
flash.sh現在理論上可以支援NVMe、但是有可能不太穩定,而且我們官方的方法還是建議用initrd flash
是的,后面没有东西了
执行这个命令:
-c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml”
–showlogs --network usb0 jetson-orin-nano-devkit internal
报如下错误:
log5.txt (197.5 KB)
l4t_initrd_flash.sh过程中的 serial console log 如log4
