We are facing issue with different mix of BOARDID, BOARDSKU, FAB and BOARDREV (for single board).
Some of them are listed in README_initrd_flash.txt
Environment variables value table:
# BOARDID BOARDSKU FAB BOARDREV
# jetson-agx-xavier-industrial 2888 0008 600 A.0
# clara-agx-xavier-devkit 3900 0000 001 C.0
# jetson-xavier-nx-devkit 3668 0000 100 N/A
# jetson-xavier-nx-devkit-emmc 3668 0001 100 N/A
# jetson-xavier-nx-devkit-emmc 3668 0003 N/A N/A
# jetson-agx-xavier-devkit (16GB) 2888 0001 400 H.0
# jetson-agx-xavier-devkit (32GB) 2888 0004 400 K.0
# >> jetson-agx-orin-devkit 3701 0001 TS1 C.2
# >> jetson-agx-orin-devkit 3701 0000 TS4 A.0
# jetson-agx-xavier-devkit (64GB) 2888 0005 402 B.0
# holoscan-devkit 3701 0002 TS1 A.0
# >> jetson-agx-orin-devkit 3701 0004 TS4 A.0
# >> jetson-agx-orin-devkit (64GB) 3701 0005 500
# jetson-orin-nano-devkit (NX 16GB) 3767 0000 300
# jetson-orin-nano-devkit (NX 8GB) 3767 0001 300
# jetson-orin-nano-devkit (Nano 4GB) 3767 0004 300
# jetson-orin-nano-devkit (Nano 8GB) 3767 0003 300
# jetson-orin-nano-devkit (Nano 8GB) 3767 0005 300
AGX Orin 32GB
Board ID(3701) version(500) sku(0000) revision(M.0)
Chip SKU(00:00:00:D0) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(500)
AGX Orin 32GB
Board ID(3701) version(500) sku(0000) revision(L.0)
For 32GB version is FAB=500 and this is missing from table
AGX Orin 64GB
Board ID(3701) version(500) sku(0005) revision(R.0)
Chip SKU(00:00:00:D0) ramcode(00:00:00:03) fuselevel(fuselevel_production) board_FAB(500)
Revision M.0 , R.0 , L.0 are missing from table
Could somebody explain differences in between them
For example BOARDSKU 0000, 0001, 0004 for 3701 (AGX Orin devkit 32GB model)
Which are universal values for flashing 32GB model
BOARDID=3701
BOARDSKU=
FAB=
BOARDREV=
What is your purpose to know the detail here?
The flash process will read the info from your module EEPROM so you don’t need to manually write it for flash.sh.
If your module is production module, then it will definitely be p3701-0004.
If your module is from devkit, then it will be p3701-0000.
There won’t be 0001 for any 32GB module for Jetson.
We are producing and using Mass flash images , so flash.sh is not option. In case we use flash.sh we need to carry whole Linux_for_Tegra content which is huge.
You can just pick one of the module info and write it into massflash.
If there is any problem, we can discuss it later.
Just a reminder, you cannot use same massflash image for both Orin 32GB and 64GB. It must regenerate.
So we could say :
- For Jetson AGX Orin Devkit - 32GB
BOARDID=3701
BOARDSKU=0000
FAB=<not important>
BOARDREV=<not important>
important
- For Jetson AGX Orin Devkit - 64GB
BOARDID=3701
BOARDSKU=0005
FAB=<not important>
MFI images created with those values will be capable of flashing :
- MFI for 3701-0000 all Jetson AGX Orin devkits with 32GB
- MFI for 3701-0005 all Jetson AGX Orin devkits with 64GB
There is a minor mistake. The sku for 32GB is 0004 but not 0000. 0000 is devkit module. You are not using a devkit module to make your own product.
The FAB is also important but the BOARDREV does not.
That part is clear.
We were looking for some kind of hybrid solution to be able to flash all Jetson AGX Orin devkits (32GB/64GB) with single MFI image.
But maybe this is not yet supported
Sorry, that is not supported.
Devkits are used for development not a product. So for dev kit 0000 is right , based on your comments.
So in that case I assume we should use only ?
FAB=TS4
If you are talking about you want to massflash devkit modules, then use 0000.
If you are talking about you want to massflash production modules, then use 0004.
My point is you won’t put a devkit module on your product. That’s all.
The module info should be checked from the EEPROM.
FAB=TS4
Your previous eeprom said you are using FAB=500. So please just use 500 for your FAB
Yes mine is FAB=500 and I will stick to that, but my board combination is not listed in the table.
Can you elaborate please , what exactly is the difference between different FABs.
There is nothing to clarify. Your module FAB 500 will be stick for production module.
Some of the modules on the list are out of date. We may try to update the table.
I suppose next table will be with next official JetPack 6 ?
If you have more recent one at you disposal, could you share it ?
