I have been trying to flash my Jetson Orin NX-based Avermedia D131L Carrier Board without any success. So far flashing has been tried with SDK manager version 2.0.0 on Ubuntu 18.04, 20.04, and 22.04 respectively. Furthermore, docker image versions of the SDK manager didn’t provide help either. The corresponding SSD for flashing is formatted and clear. The device can only be set to recovery mode from the boot menu. For possible USB connection errors, I have tried 2 different cables. Also, I have tried jetpack 6.0 and 5.1.3.
You can find the log outputs in the attachment. When all processes are complete, the device loses connection during the OS flashing part, and the host machine cannot read the board information, as observed.
10:34:09.432 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.1960 ] Warning: pub_key.key is not found
10:34:09.433 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.1896 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
10:34:09.433 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.1911 ] Error: Skip generating mem_bct because sdram_config is not defined
10:34:09.433 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS - error is: [ 0.1911 ] Error: Skip generating mem_bct because sdram_config is not defined
10:34:09.434 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS - error is: [ 0.1911 ] Error: Skip generating mem_bct because sdram_config is not defined
10:34:09.434 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.1911 ] Copying signatures
10:34:09.434 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.1920 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
10:34:09.434 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.1977 ] Boot Rom communication
10:34:09.434 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.1985 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
10:34:09.435 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.1996 ] BR_CID: 0x80012344705DE44D780000000DFF0200
10:34:09.476 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.2287 ] Sending bct_br
10:34:14.608 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ 0.2721 ] ERROR: might be timeout in USB write.
10:34:14.608 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS - error is: [ 0.2721 ] ERROR: might be timeout in USB write.
10:34:14.621 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Error: Return value 3
10:34:14.621 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS - error is: Error: Return value 3
10:34:14.622 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
10:34:14.630 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: --- Error: Reading board information failed.
10:34:14.631 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS - error is: --- Error: Reading board information failed.
10:34:14.633 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: *** ERROR: Parsing boardid failed
10:34:14.633 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS - error is: *** ERROR: Parsing boardid failed
10:34:14.633 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.msb.sh; [error]: *** ERROR: Parsing boardid failed
10:34:14.634 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS - error is: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.msb.sh; [error]: *** ERROR: Parsing boardid
SDKM_logs_JetPack_5_1_3_Linux_for_Jetson_Orin_NX_modules_2024_02.zip (130.6 KB)
