Trying to Flash Jetson Orin NX 16Gb, failed- "Flash Jetson Linux - flash: Waiting for target to boot-up..."
SDKM_logs_JetPack_6.1_Linux_for_Jetson_Orin_NX_16GB_2024-12-05_09-26-30.zip (547.2 KB)
I am trying to flash a jetson orin NX 16Gb with the NVIDIA SdkManager.
Physical connections:
I have connected the Orin NX board to my Ubnutu 20.04 based Thinkpad using a USB A to A.
The board is powered using a KeySight E36311A Power supply with 12V and 1A input supply.
Software Flash Method:
I am booting the jetson into Forced Recovery Mode by pressing the recovery button, then the reset button and releasing both at once after that.
Please refer to the attached logs. The NVIDIA SDK Manager is able to create the flash packages, but not able to flash it on the drive as the target device fails to boot. I am not sure what I am doing wrong. Can someone guide me through the correct process?
Thank you.
I would like to confirm the following details:
  1. What type of carrier board are you using? Is it the Orin Nano Devkit or a custom carrier board?
  2. Is your Ubuntu operating system running on a physical machine or within a virtual environment (e.g., WSL, VirtualBox, VMware)?"
Hey @DavidDDD !!
Thank you for your response!
I solved it. There were some OEM issues that the carrier board had. But it works now.
Thank you very much!
Regards
