I recently acquired a ZED Box powered by a Jetson Orin NX 16 GB, equipped with a GSM adapter. I’m attempting to flash the firmware with JetPack 5.1.2 using NVIDIA SDK Manager (version 2.1.0). I’m connecting the device via a data-enabled micro-USB cable, following all the recommended steps for flashing as outlined in the official documentation.
However, during the flashing process, I encounter numerous errors, and the firmware update fails. Despite following the procedure carefully, I haven’t been able to resolve the issue. I’ve attached the log files from the SDK Manager that capture the errors during the flashing process.
Could you assist me in identifying the cause of these errors and guide me through troubleshooting this issue? Any help would be greatly appreciated, as I need to get this device up and running with the proper firmware.
i have attached the system logs file in the link below
