Error during flashing Jetson Orin NX 16 GB using Orin Nano devkit carrier board
I am trying to flash a Jetson Orin NX 16 GB using Orin Nano devkit carrier board and a NVMe SSD (PC SN530 256 GB). The installation through the SDK manager fails with the error:
15:38:45 INFO: Flash Jetson Linux - flash: tar: Read checkpoint 10000
15:38:47 INFO: Flash Jetson Linux - flash: tar: Read checkpoint 20000
15:38:50 INFO: Flash Jetson Linux - flash: tar: Read checkpoint 30000
15:38:56 INFO: Flash Jetson Linux - flash: tar: Read checkpo
15:38:56 INFO: Flash Jetson Linux - flash: int 40000
15:39:07 INFO: Flash Jetson Linux - flash: Erased 67108864 bytes from address 0x00000000 in flash
15:39:07 INFO: Flash Jetson Linux - flash: Flash index file is /mnt/internal/flash.idx
15:39:07 INFO: Flash Jetson Linux - flash: Number of lines is 61
15:39:07 INFO: Flash Jetson Linux - flash: max_index=60
15:45:07 INFO: Flash Jetson Linux - flash: Flash failure
15:45:07 INFO: Flash Jetson Linux - flash: Either the device cannot mount the NFS server on the host or a flash command has failed. Debug log saved to /tmp/tmp.pOeI5StoxK. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
15:45:07 INFO: Flash Jetson Linux - flash: clnt_create: RPC: Unable to send
15:45:07 INFO: Flash Jetson Linux - flash: Cleaning up...
15:45:07 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.shri.sh; [error]: 130233 blocks
15:45:07 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
15:45:07 INFO: Flash Jetson Linux - flash: [host] [ Disk Avail on Partition : 0.00 B ]
15:45:07 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 10m41s ]
I am not sure how to solve this issue. The carrier board has a USB A (Linux PC) to USB C (board) connection, an ethernet connection and is in recovery mode. I am attaching the output log. Thanks in advance!
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_NX_modules_2024-06-20_15-34-10.zip (435.5 KB)
I also get the same error when I try to flash through the command line. I followed the instructions online and use this command:
 sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --network usb0 --showlogs jetson-orin-nano-devkit nvme0n1p1
This is for JetPack 6.0 and Jetson Linux version 36.3.
I also tried flashing by choosing JetPack 5.1.3 in the SDK manager. The log for this is attached below:
SDKM_logs_JetPack_5.1.3_Linux_for_Jetson_Orin_NX_modules_2024-06-20_16-43-21.zip (622.7 KB)
16:54:15 INFO: Flash Jetson Linux - flash: Read checkpoint 10000
16:54:20 INFO: Flash Jetson Linux - flash: tar: Read checkpoint 20000
16:54:25 INFO: Flash Jetson Linux - flash: tar: Read checkpoint 30000
16:54:30 INFO: Flash Jetson Linux - flash: tar: Read checkpoint 40000
16:54:35 INFO: Flash Jetson Linux - flash: tar: Read checkpoint 50000
16:54:40 INFO: Flash Jetson Linux - flash: tar: Read checkpoint 60000
17:00:40 INFO: Flash Jetson Linux - flash: Flash failure
17:00:40 INFO: Flash Jetson Linux - flash: Cleaning up...
17:00:41 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.shri.sh; [error]: 84983 blocks
17:00:41 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
17:00:41 INFO: Flash Jetson Linux - flash: [host] [ Disk Avail on Partition : 0.00 B ]
17:00:41 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 10m19s ]
17:00:41 ERROR: Flash Jetson Linux - flash: command terminated with error
17:00:41 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
What OS do you use with the host PC?
Can you check the status of nfs-kernel-server? Also disable firewall is there is any.
Or try this method instead:
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/FlashingSupport.html#flashing-to-an-nvme-drive
Thank you for responding. I am using Ubuntu 20.04. nfs-kernel-server is active and firewall is disabled.
The problem was that the fan was off so the device shuts down during flashing to prevent overheating.
Oh, OK, sure…
So is it solved now?
Yes. I was able to flash the module successfully. Thank you!
