SDK manager failed to flash image on jetson orin
I am trying to install Nvidia jetson linux using SDK. Flashing faild here is the terminal output
11:49:54 INFO: Flash Jetson Linux - flash: [ 0.2023 ] tegrarcm_v2 --instance 1-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
11:49:54 INFO: Flash Jetson Linux - flash: [ 0.3206 ] Sending bct_mem
11:49:54 INFO: Flash Jetson Linux - flash: [ 0.3293 ] Sending blob
11:49:58 INFO: Flash Jetson Linux - flash: ***************************************
11:49:58 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:49:59 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:00 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:01 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:02 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:03 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:04 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:05 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:06 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:07 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:08 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:10 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:11 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:12 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:13 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:14 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:15 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:16 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:17 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:18 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:19 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:20 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:21 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
11:50:34 INFO: Flash Jetson Linux - flash: Waiting for device to expose ssh ...Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
11:50:34 INFO: Flash Jetson Linux - flash: SSH ready
11:53:36 INFO: Flash Jetson Linux - flash: mount.nfs: Connection timed out
11:53:36 INFO: Flash Jetson Linux - flash: Either the device cannot mount the NFS server on the host or a flash command has failed. Debug log saved to /tmp/tmp.dqXHNk3V0D. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
11:53:43 INFO: Flash Jetson Linux - flash: Cleaning up...
11:53:43 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
11:53:44 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 16m36s ]
11:53:44 ERROR: Flash Jetson Linux - flash: command terminated with error
11:53:44 SUMMARY: DateTime Target Setup - target: Depends on failed component
I tried multiple time got the same error
here is the log  file
[SDKM_logs_JetPack_5.1.3_Linux_for_Jetson_Orin_Nano_modules_2024-08-16_11-57-40.zip|attachment](upload://pANE20CZPd52YeST6FdLt8ua0K7.zip) (224.5 KB)
Hi mubashir87665,
Are you using the devkit or custom board for Orin Nano?
What’s the Jetpack version you are trying to flash?
Please refer to the following thread to check if disabling the firewall could help for this issue.
I have uploaded the log file you can look at it
Sorry that I don’t see your log file.
Please upload it again.
Have you also referred to the thread I shared to disable firewall on the host?
