Installation through SDK Manager ends with an error rootfs does not support NFS export
Jetson Orin Nano with sd card, in boot mode, with Waveshare Jetson Orin Nano development board. SDK Manager finds jetson, but any installation variant ends with an error rootfs does not support NFS export
09:43:31 INFO: Flash Jetson Linux - flash: Parsing module EEPROM:
09:43:31 INFO: Flash Jetson Linux - flash: --- Parsing board version (300) succeeded.
09:43:31 INFO: Flash Jetson Linux - flash: --- Parsing board SKU (0005) succeeded.
09:43:31 INFO: Flash Jetson Linux - flash: --- Parsing board REV (K.2) succeeded.
09:43:31 INFO: Flash Jetson Linux - flash: Parsing boardid successful
09:43:31 INFO: Flash Jetson Linux - flash: Flashing Jeton Orin Nano
09:43:31 INFO: Flash Jetson Linux - flash: /home/aname/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device mmcblk0p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 -p --no-systemimg -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
09:43:32 ERROR: Flash Jetson Linux - flash: exportfs: /home/aname/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs does not support NFS export
09:43:32 INFO: Flash Jetson Linux - flash: Cleaning up...
09:43:32 ERROR: Flash Jetson Linux - flash: command terminated with error
09:43:32 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
SDKM_logs_JetPack_6.0_DP_Linux_for_Jetson_Orin_Nano_modules_2024-02-28_09-32-59.zip (78.0 KB)
Just run
sudo ./flash.sh jetson-orin-nano-devkit internal
From /home/aname/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/.
thanks, I’ll try
