Issues while flashing Orin Nano using the SDK manager
sdkm-2024-09-05-14-56-26.log (797.5 KB)
For some reason, the jetson doesn’t boot up and I see that the installation fails. SD card flashing didn’t work, so I tried using SDK manager.
I’ve attached the log files as well.
Host: Ubuntu 22.04.4 LTS x86_64
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_Nano_modules_2024-09-05_14-56-45.zip (209.8 KB)
15:00:36.491 - Info:Either the device cannot mount the NFS server on the host or a flash command has failed. Debug log saved to /tmp/tmp.6d6z0cpUrm. You can access the target’s terminal through “sshpass -p root ssh root@fc00:1:1:0::2”
Error log is as above.
Is this NV devkit or custom board? If this is NV devkit, please check the firewall setting on your host PC so that NFS server could be launched.
If this is custom board, please dump serial console from UART.
Yes, it’s an NV devkit. Could the issue be because of my college wifi’s firewall?
Jetson is established a etherent interface between Jetson and your host PC through the usb cable.
Thus, I don’t think this is related to any WIFI. Only related to your host setting.
How do I open the corresponding ports, any guide?
Ping.
Sorry for the late response.
Yeah, it’s still isn’t fixed. I downgraded my host to ubuntu 20.04, but still the same issue persists.
Try to disable the firewall setting on your host pc
sudo ufw disable .
