I tried to boot with SDK manager, but some error occurs. I am not sure about the reason, and I upload the log. Thank you for your help!
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_Nano_modules_2024-09-04_17-08-37.zip (490.9 KB)
Besides, I met some notice during the process, NVIDIA USB DEVICE WAS REMOVED and NVIDIA USB DEVICE WAS ADDED. I am not sure whether it’s related.
Are you using VM or native Ubuntu host PC?
Please be aware of that VM cannot work well.
Native host PC. The error still exists, but I managed to use a flashed SAD card to boot the board successfully. Thank you!
SD card
So with SD card can boot up your device successfully, but no able to flash the device via SDK manager by JetPack, right?
Yes, I think that’s the case. The problem using SDK manager seems to be the connection between PC and the board.
Hi sunyusimon0532,
Are you using the devkit or custom board for Orin Nano?
Are you trying to flash into SD or NVMe?
17:37:57.894 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Flash is successful
17:37:57.895 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Reboot device
17:37:58.017 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Cleaning up...
From the SDKM log you shared, it seems you’ve flashed successfully.
17:41:41.355 - error: Internet connection.: Internet connection check failure.
And you have internet connection issue at the end.
I am using devkit, flash into SD. Yes, I think it may caused by connection issues, But I was unable to find and fix it. From the log it seems the flash was successful, But I can’t boot until I reflash the SD card with a Windows PC.
You can check the serial console log for the boot issue at this moment.
For the devkit, you can refer to the following instruction to get serial console log.
Jetson Nano & NX Style - Serial Debug Console - JetsonHacks
