I’ve been spending a big amount of hours in attempting to flash my NVIDIA Jetson Orin Nano unit these days.
I’m using a virtual box as hypervisor to host an ubuntu v22.04 over which I installed the SDK Manager v2.2.0.12028.
The goal is to install in the unit the latest firmware and make it work over a SSD M2 2230 drive instead of booting with an SD card. Jetpack version is 6.2
Tried with different USB-C cables, forced recovery jumper is on, jet still I cannot flash my Jetson unit.
When trying from CLI using these, none work:
SDKManager says the device is in a bad state and that I should reboot, jump the forced recovery and start over, while the CLI ends with WARNING: Error 8.
Definitely need some help here, thanks in advance.
Our recommended approach is using native ubuntu,
but there are some users sharing their successful experience with VMWare.
You could refer to this to try.
Hi. Your article helped a lot. Almost made it through.
I’m getting an error on the size of the disk partition assigned to the image. While the image needs over 16GB, the default size during the OS image flashing into the device is around 3 GB.
See attached logs for more info.
What’s storage size you prepare for your VM?
Please prepare at least 64GB or more to flash your device.
Please refer to below link to get more information.
Hi!
I installed a M2 512GB disk on the board. Supposedly clean. I was expecting the SDK manager to setup all the partitions on it. Is there any place I could manually do this myself and set a larger one?
Hi, David.
Happy Friday.
VM storage size is 50 GB as per your recommendation.
I’m thinking the problem lies in how much space SDKManager sets in the destination M2 disk when attempting to flash the drive.
Hey, David.
I managed to increase the partition size to 80 GB and ran the flashing process again.
I’m getting a different error message now.
Adding the logs attached for your review.
