SDKM_logs_2024-04-02_20-09-17.zip (701.7 KB)
I am using this carrier board Buy Carrier Board for Jetson Orin Nano/NX System on Module Online in India at Hubtronics.in , I am trying to flash orin nano 8GB using SDK manager manual method by force recovery with PIN 9 and 10 , I have connected this (Buy EVM M.2 Nvme PCIe 2230 256GB SSD Online In India at HUBTRONICS.in)SSD to carrier board. I tried all nvme/sd card/usb flash options from SDK manager with Manual set up and runtime option. Attached is the log. Please help I have been trying for long time now to set this up. I have checked other posts in this forum with no luck.
Then you should know how to dump the log:
I bought the serial debug cable and used minicom while flashing. Attached is the log.
dmesg.txt (5.8 KB)
logs_boot.txt (58.0 KB)
Your serial console is a little out of order. Some of the info got truncated.
Please resize your terminal and dump it again.
Seems like you PC is unable to connect to the Jetson SSH server to start the flashing process.
Do you mind running these commands after flashing fails?
ip a
lsusb
Please also consider swapping for another flashing cable.
ip a =>
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp6s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 14:fe:b5:c1:b4:bd brd ff:ff:ff:ff:ff:ff
3: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 88:53:2e:0a:fc:e4 brd ff:ff:ff:ff:ff:ff
inet 192.168.73.243/24 brd 192.168.73.255 scope global dynamic noprefixroute wlp3s0
valid_lft 3099sec preferred_lft 3099sec
inet6 2401:4900:65b2:1040:7dd7:21c1:bb49:f10c/64 scope global temporary dynamic
valid_lft 7165sec preferred_lft 7165sec
inet6 2401:4900:65b2:1040:a985:15f:4435:c256/64 scope global dynamic mngtmpaddr noprefixroute
inet6 fe80::ab5:5898:10d4:6c49/64 scope link noprefixroute
lsusb =>
Bus 002 Device 003: ID 8086:0189 Intel Corp. Centrino Advanced-N 6230 Bluetooth adapter
Bus 002 Device 004: ID 046d:c05a Logitech, Inc. M90/M100 Optical Mouse
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port / Mobile Action MA-8910P
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0408:2fb1 Quanta Computer, Inc. Laptop_Integrated_Webcam_2HDM
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I did use another cable for flashing but still no luck.
And SDK manager shows :
21 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
16:19:22 ERROR: Flash Jetson Linux - flash: command terminated with error
16:19:22 SUMMARY: DateTime Target Setup - target: Depends on failed component
minicom_jetson_log.txt (92.5 KB)
here is the new one
I have been struggling to flash ubuntu on this device for long time now .I have attached another log , could you please help resolve this issue and what is the solution ?
Is there any USB devices other than the flashing cable, like mouse or keyboard, connected to Jetson while flashing?
Make sure there is one.
Then you know you should have been asking here instead of not making a single reply in 10 days.
No there is none apart from flashing cable. Let me try connecting, May I know why should there be a USB keyboard or mouse?
Itβs a bug in JetPack 6 DP that USB devices cannot be enumerated correctly.
Can you follow this Quick start page
Quick Start β NVIDIA Jetson Linux Developer Guide 1 documentation
to flash your device?
You can download the neccessary package
${L4T_RELEASE_PACKAGE} : Driver Package (BSP)
${SAMPLE_FS_PACKAGE} : Sample Root Filesystem
from
Jetson Linux 36.2 | NVIDIA Developer
and use
sudo ./nvsdkmanager_flash.sh
to flash the sd card
or use
sudo ./flash.sh jetson-orin-nano-devkit-nvme internal
for flashing the NVMe
After connecting usb keyboard flashing is success!!!
Thank you so much!
