I just bougth my first Jetson Nano Orin developper Kit ans I m still unable to flash it…
I use a standalone Ubuntu 22.04 machine, I Installed SDK Manager, my Jetson module is correctly detected.
But I have an error when I try to flash the module with JetPack 6.0 DP, when the flash is almost done (98%), it throws an error.
Here the complete sdkmanager log :
SDKM_logs_JetPack_6.0_DP_Linux_for_Jetson_Orin_Nano_modules_2024-04-05_13-07-01.zip (200.2 KB)
I searched on forums and on the web and I don’t find the solution.
Do you have any idea please ? Did I miss something ?
Thanks a lot for your help
HG
Have you tried a different USB port on your computer? I had the same issue when flashing my orin and using a different port worked for me
Finally, I renounced to install JetPack 6 from SDKMANAGER.
I directly flashed the jetson bios to update QSPI bootloader from the terminal with commands and separatly I flashed the sd card from my windows system.
It works fine.
Here, the useful post to realize it :
https://forums.developer.nvidia.com/t/sdkmanager-2-0-0-file-system-and-os-install-error-on-wsl2-ubuntu-22-04/277515/15
I used standalone ubuntu not Wsl, so I followed only the steps for ubuntu.
Useful documentation :
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/IN/QuickStart.html
It’s so faster and easier than to use Sdk manager… I lost 2 days trying with sdk manager…
Summary of this post without wsl :
1 Donwload this 2 files
https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v2.0/release/jetson_linux_r36.2.0_aarch64.tbz2
https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v2.0/release/tegra_linux_sample-root-filesystem_r36.2.0_aarch64.tbz2
2 Execute these commands (see [documentation])(Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation)
tar xf ${L4T_RELEASE_PACKAGE}
sudo tar xpf ${SAMPLE_FS_PACKAGE} -C Linux_for_Tegra/rootfs/
cd Linux_for_Tegra/
sudo ./apply_binaries.sh
sudo ./tools/l4t_flash_prerequisites.sh
3 Put your Orin Nano Dev Kit into Force Recovery Mode
4 Verify Orin Nano Dev Kit is attached with lsusb command
5 Change to Linux_for_Tegra directory
6 Flash with this command
sudo ./flash.sh --no-systemimg -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit mmcblk0p
