In short, I tried flashing Jetson 6.1 using SDK Manager, but I encountered the above issue during the process.
I initially started with this tutorial and followed the exact procedure outlined in the Jetson AI Lab guide and used the SDK-Method.
lsb_release -a:
Distributor ID: Ubuntu
Description: Ubuntu 22.04.5 LTS
Release: 22.04
Codename: jammy
uname -a
Linux server-1 6.5.13-cma-akd1500 #1 SMP PREEMPT_DYNAMIC Tue May 28 14:11:33 IST 2024 x86_64 x86_64 x86_64 GNU/Linux
Some questions to confirm:
- Is your Orin Nano a dev kit or a custom board?
- Is your host a native or a virtual machine?
I am using the Orin Nano dev kit, not a customized board.
And my Host is a native one, not a VM.
Do you type c flashing cable support data transfer?
Also use lsusb to make sure the device in recovery mode.
sorry, I have used the second method (microSD-only method) and updated the firmware to the latest (36.4.3) and Jetpack to 6.2.
if you don’t mind could you please provide some tutorial links on how to enable GPU …etc or some examples to start experimenting with it?
This topic is just for flashing. If this one is already gone, then maybe you should file a new topic.
Thank you for the support, no need to raise a new topic I found the tutorial links.
Thanks again
