I am trying to flash JetPack 6.2 onto my M.2 SSD, but my SDK Manager keeps failing the installation with the same error code. I have attached the logs below.
SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_Nano_[8GB_developer_kit_version]_2025-03-21_12-48-45.zip (82.9 KB)
The displayed error code is error code 11, it fails to install file systems and os
Some questions to confirm
- Is your Orin Nano using a dev kit or a custom carrier board?
- Is you ubuntu host a native or a virtual machine?
My Orin Nano is using a dev kit.
My ubuntu host is a native machine.
point to note: I have previously used this host machine to flash the jetpack 6.2 on an sd card and an NVme but now it fails on any installation with the error code: 11
Yes it is still an issue
Please download Driver Package (BSP) and Sample Root Filesystem from Jetson Linux | NVIDIA Developer.
And follow the Quick Start — NVIDIA Jetson Linux Developer Guide to flash your device again.
I will try that and provide some feedback
