Can't flash JetPack 6.0 in Jetson Orin Nano with SDK Manager
Hi.
I can’t flash my Jetson Orin Nano (8GB) with the SDK manager. I’m trying to flash JetPack 6.0.
The exported logs from the installation are attached.
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_Nano_modules_2024-07-24_12-32-27.zip (507.8 KB)
Are you using devkit or with custom board?
Are you using VM or with Ubuntu OS host?
Hi jacob.vv13,
Are you using the devkit or custom board for Orin Nano?
12:40:31.673 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Error: Invalid argument during seek for read on /dev/mmcblk0
12:40:31.673 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS - error is: Error: Invalid argument during seek for read on /dev/mmcblk0
12:40:31.674 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS:
12:40:31.681 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ 8]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
12:40:31.681 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS - error is: [ 8]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
12:40:31.681 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS:  -   the xml indicates the gpt is larger than the device storage
12:40:31.681 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS:  -   the xml might be invalid
12:40:31.681 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS:  -   the device might have a problem.
12:40:31.681 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS:  Please make correction.
Please check if AGX Orin Flashing Error - #7 by DaveYYY could help for your case.
