I am having issues flashing the Jetson Orin Nano via the sdkmanager to a microSD card in the Jetson. I am using Ubuntu-20.04 within wsl on a Windows laptop. The Jetson keeps disconnecting and reconnecting as I have auto-attach on. However, halfway through the flash, the Jetson seems to boot up (I see the NVIDIA boot logo screen) and my laptop itself no longer recognises the device. Therefore, I can no longer attach it to the wsl and the flash errors out with “hardware not detected”.
It seems you are using WSL for flashing. However, during the flashing process, the Orin Nano will frequently connect and disconnect, which may cause WSL, as a virtual machine, to fail in recognizing the USB device.
In short, resolving this issue with WSL can be time-consuming and require significant effort.
A quicker method would be to use a physical machine running Ubuntu 20.04 instead of a virtual machine.
Happy New Year. Sorry for the slow response; I had been away from the Jetson board at work.
I have now obtained a computer which I have freshly flashed Ubuntu20.04 onto but now I am getting new errors - dependency errors. I have attached the logs.
