Jetson Orin Nano Developer kit bootup issue
Device and Setup Details:
  • Device Model: Jetson Orin Nano Developer Kit 8GB
  • JetPack Version: JP513-orin-nano-sd-card-image_b29
  • Boot Media: SD card, flashed from Windows using Etcher
Issue Description:
  1. The device powers on and displays the UEFI firmware screen.
  2. The device does not boot into the operating system.
  3. No bootable devices are detected in the Boot Manager.
I’ve tried reformatting the SD card and reflashing it, but it didn’t work. I would appreciate any help in solving this issue.
Suggest to download SDK Manager to your Ubuntu host and follow user guide steps to re-flash BSP your Orin Nano devit.
Download link: SDK Manager | NVIDIA Developer
User Guide: NVIDIA SDK Manager Documentation — SDK Manager
Install Jetson Software with SDK Manager — SDK Manager
Thank You Kayccc!
I want to sincerely thank the forum for the guidance and support. My Jetson Orin Nano is now working perfectly, and I’d like to share the steps I followed in case it helps someone else facing similar issues.
Initial Problem:
I was unable to boot my Jetson Orin Nano. It was stuck on the UEFI firmware screen, attempting HTTP boot over IPv4. Additionally, my device wasn’t being detected when connected to my host machine initially.
Steps Taken to Resolve:
  1. Checked Connections and Recovery Mode:
  • Verified all hardware connections (power, SD card, and USB).
  • Placed the device in Recovery Mode by:
    • Holding the Force Recovery Button.
    • Pressing the Power Button while holding the recovery button.
  1. Ensured Proper Host Setup:
  • Used a host system running Ubuntu 24.04 (x86_64) in my case.
  • Installed the NVIDIA SDK Manager to manage the flashing process.
  1. Jumper Cable Workaround:
  • Initially, the device wasn’t recognized via USB. I used a jumper cable to ensure the device entered recovery mode successfully, after which it was detected by the SDK Manager.
  1. Flashing the Firmware:
  • Flashed the Jetson Orin Nano using the SDK Manager.
  • Selected and installed JetPack 6.1 and the required software packages.
  1. Device Booted Successfully:
  • After flashing, the device booted correctly, and I was able to complete the setup.
  • Verified all functionalities, and the system is now operational.
Current Setup:
  • Device: Jetson Orin Nano (8GB) developer kit.
  • JetPack Version: 6.1.
  • Host Machine OS: Ubuntu 24.04 (x86_64).
  • SDK Manager: Used to flash the firmware and install JetPack.
Glad to know issue resolved, thanks for your sharing!
