Jetson Orin Nano Not detected by SDK Manager and will not boot from SD Card
I have a Jetson Orin Nano Developer Kit [945-13766-0005-0000] and I have tried booting from SD Card [as I have done successfully with Jetson Nano Developer Kit previously]
“jp60dp-orin-nano-sd-card-image”
I also tried using the SDK manager from Ubuntu 22.04.3 LTS as host, the device was not recognised by the software.
So I connected the UART TX/RX to a serial UART convertor and have the output and it looks as though I have some access.
This is the end output of the serial comms. There did not seem to be any errors only warnings and info in the previous text.
UEFI Interactive Shell v2.2
EDK II
UEFI v2.70 (EDK II, 0x00010000)
Mapping table
FS1: Alias(s):F1:
MemoryMapped(0xB,0x231A00000,0x231CA3977)
FS0: Alias(s):F0:
Fv(49A79A15-8F69-4BE7-A30C-A172F44ABCE7)
BLK0: Alias(s):
VenHw(1E5A432C-0466-4D31-B009-D4D9239271D3)/MemoryMapped(0xB,0x1416000
0,0x1417FFFF)/PciRoot(0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/NVMe(0x1,1D-00-00-40-80-A7-
79-64)
Press ESC in 1 seconds to skip startup.nsh or any other key to continue.
Shell>
The NVME = Crucial P3 1TB PCIe Gen3 which I believe to be correct spec.
Using the https://jetsonhacks.com/2023/05/30/jetson-orin-nano-tutorial-ssd-install-boot-and-jetpack-setup/ I was able to flash the drive which is great however without Jim and his very helpful scripts I would not have been able to deploy the project I was working on in time.
Is there a way to get the SDK manager to work? Is this issue being looked into? Is there something I was not doing correctly?
Did you put a jumper across FC REC and GDN to put it in force recovery mode?
It’s not detected with lsusb?
i have the same problem
Please open a new topic for your own issue. Thanks
