Jetson orin nano booting problem
hello, i’m working on booting the jetson orin nano with SD card but i have some problems
when i flash jetpack 5.1.5 at SD card and boot the jetson orin nano it just show black screen while pan is rotating but this is so curious because i used this jetson orin nano first with SSD by flashing with host pc sdkmanager and i flashed jetpack 5.1.5 after that i formated SSD to change the version of jetpack and when i add to jetson and try to connect to host pc it did’nt find jetson orin nano and i check lsusb but there was not jetson USB conection so back to now i tried to use SD card to boot first and use SSD after i boot SD card first but now it is not working just showing black screen. and i think jetson is not getting into recovery mode also i have change SSD, usb-c , cables, and the method was as same as at NVIDIA forum do you now the problem?
this jetson UEFI version is now at 6.1-xxxxx
here is the UART log file
UART_log.txt (33.5 KB)
please let me know what is the problem..
Please try to full flash your device using sdk manager or manual flash in ubuntu.
