Orin Devkit - Flashing to Device Fails - Unit proc-fs-nfsd.mount is masked
Using NVIDIA SDK Manager - After target image creation and identifying the Orin Nano device - flashing step fails with error -
22:00:04 INFO: Flash Jetson Linux - flash: Flashing Jeton Orin Nano
22:00:04 INFO: Flash Jetson Linux - flash: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device mmcblk1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 -p -C nv-auto-config -p --no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
22:00:04 ERROR: Flash Jetson Linux - flash: Failed to restart nfs-kernel-server.service: Unit proc-fs-nfsd.mount is masked.
22:00:04 INFO: Flash Jetson Linux - flash: Cleaning up…
22:00:04 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 4s ]
22:00:04 ERROR: Flash Jetson Linux - flash: command terminated with error
22:00:04 SUMMARY: DateTime Target Setup - target: Depends on failed component
Flash logs attached
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Orin_Nano_modules_2023-11-10_21-50-55.zip (285.6 KB)
Let’s just focus on:
I think they are the same issue.
