I’m trying to flash my new Jetson Orin Nano Developer Kit using the SDK Manager on my host machine running Ubuntu 22.04, with JetPack 6.1. However, I’m encountering the following errors during the flashing process:
Error Message:
"Either the device cannot mount the NFS server on the host or a flash command has failed."
"clnt_create: RPC: Unable to receive"
gzip Error:
"gzip: /home/nutranev_hp/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format"
I have attached the log file for your reference. Has anyone experienced similar issues or can provide guidance on how to resolve them?
SDKM_logs_JetPack_6.1_Linux_for_Jetson_Orin_Nano_[8GB_developer_kit_version]_2024-11-09_18-58-52.zip (285.2 KB)
Any help would be greatly appreciated!
Hi rahul_nutran,
I’ve moved your topic to correct category for Orin Nano since you are not using Jetson Nano.
Are you using standalone Ubuntu host PC or you are using VM/docker?
18:57:57.646 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: External storage specified mmcblk0p1
18:57:57.646 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Flashing Jeton Orin Nano
18:57:57.663 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [host] [ 3.95 MB used. Disk Avail on Partition /dev/nvme0n1p5: 101.02 GB ]
19:33:49.519 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: mount: /tmp/ci-8zsJPNhS8Z: wrong fs type, bad option, bad superblock on /dev/mmcblk0p1, missing codepage or helper program, or other error.
19:33:49.520 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ 1828]: l4t_flash_from_kernel: Failed to mount APP partition /dev/mmcblk0p1
19:33:49.520 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ 1828]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
19:33:49.520 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ 1828]: l4t_flash_from_kernel: Failed to write to APP
19:33:49.520 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ 1828]: l4t_flash_from_kernel: Error flashing external device
Are you flashing into SD or NVMe SSD?
Please format NVMe SSD as ext4 before use.
