Flashing the Jetson orin SSD using SDK manager fails at 83%
Hi, I’m trying to flash my JEtson orin nano using SDK-manager, but I faced the same error logs even when I tried some solutions from the community like changing the cable
Here are the err logs :
10:32:47 ERROR: Flash Jetson Linux - flash: [ 0.0162 ] ERROR: failed to read rcm_state
10:29:59 INFO: CuPVA Runtime - target: verifying checksum of /home/hadjousslab/Documents/nividia_jetson/cupva-2.3.2-l4t.deb
10:32:47 ERROR: Flash Jetson Linux - flash: [ 0.0953 ] Error: Skip generating mem_bct because sdram_config is not defined
10:29:59 INFO: CuPVA Runtime - target: verifying checksum of /home/hadjousslab/Documents/nividia_jetson/pva-allow-1.0.0.deb
10:29:59 INFO: CuPVA Runtime - target: Found file /home/hadjousslab/Documents/nividia_jetson/cupva-2.3.2-l4t.deb with correct checksum, skip downloading.
10:32:54 ERROR: Flash Jetson Linux - flash: [ 0.0167 ] ERROR: failed to read rcm_state
10:29:59 INFO: CuPVA Runtime - target: Found file /home/hadjousslab/Documents/nividia_jetson/pva-allow-1.0.0.deb with correct checksum, skip downloading.
10:32:54 ERROR: Flash Jetson Linux - flash: [ 0.0983 ] Error: Skip generating mem_bct because sdram_config is not defined
10:29:59 INFO: VPI Runtime - target: verifying checksum of /home/hadjousslab/Documents/nividia_jetson/vpi-lib-3.0.10-aarch64-l4t.deb
10:29:59 INFO: VPI Runtime - target: verifying checksum of /home/hadjousslab/Documents/nividia_jetson/vpi-python3.10-3.0.10-aarch64-l4t.deb
10:33:01 ERROR: Flash Jetson Linux - flash: 52057 blocks
10:29:59 INFO: VPI Runtime - target: Found file /home/hadjousslab/Documents/nividia_jetson/vpi-python3.10-3.0.10-aarch64-l4t.deb with correct checksum, skip downloading.
10:33:01 ERROR: Flash Jetson Linux - flash: gzip: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
10:29:59 INFO: VPI Runtime - target: Found file /home/hadjousslab/Documents/nividia_jetson/vpi-lib-3.0.10-aarch64-l4t.deb with correct checksum, skip downloading.
10:33:06 ERROR: Flash Jetson Linux - flash: 74756 blocks
10:29:59 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/hadjousslab/Documents/nividia_jetson/libnvidia-container1_1.14.2-1_arm64.deb
10:33:07 ERROR: Flash Jetson Linux - flash: 20+0 records in
10:29:59 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/hadjousslab/Documents/nividia_jetson/libnvidia-container-tools_1.14.2-1_arm64.deb
10:33:07 ERROR: Flash Jetson Linux - flash: 20+0 records out
10:33:07 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000100567 s, 199 kB/s
10:33:07 ERROR: Flash Jetson Linux - flash: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/flash.sh: line 3145: python: command not found
10:33:07 ERROR: Flash Jetson Linux - flash: 131072+0 records in
10:33:07 ERROR: Flash Jetson Linux - flash: 131072+0 records out
10:33:07 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.155427 s, 432 MB/s
10:33:12 ERROR: Flash Jetson Linux - flash: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
10:33:12 ERROR: Flash Jetson Linux - flash: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
10:33:26 ERROR: Flash Jetson Linux - flash: 52057 blocks
10:33:26 ERROR: Flash Jetson Linux - flash: gzip: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
10:33:31 ERROR: Flash Jetson Linux - flash: 74756 blocks
10:33:31 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000100779 s, 198 kB/s
10:33:31 ERROR: Flash Jetson Linux - flash: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/flash.sh: line 3145: python: command not found
10:34:32 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.15962 s, 420 MB/s
10:34:38 ERROR: Flash Jetson Linux - flash: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
0:35:02 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 650000
10:35:20 ERROR: Flash Jetson Linux - flash: 52057 blocks
10:32:31 INFO: net.ipv4.ip_forward = 1
10:35:20 ERROR: Flash Jetson Linux - flash: gzip: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
10:32:46 INFO: Default google DNS is not working, trying to find a valid server in local host settings!
10:35:26 ERROR: Flash Jetson Linux - flash: 74756 blocks
10:32:47 INFO: Device mode on host successfully set with DNS 155.230.10.2!
10:35:26 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.00010445 s, 191 kB/s
10:32:47 INFO: command finished successfully
10:35:26 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.145152 s, 462 MB/s
10:32:47 DEBUG: running command < true >
10:35:31 ERROR: Flash Jetson Linux - flash: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
10:35:31 ERROR: Flash Jetson Linux - flash: /home/hadjousslab/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
10:35:32 ERROR: Flash Jetson Linux - flash: [ 0.5943 ] ERROR: value 0x31 is out of range
10:35:36 ERROR: Flash Jetson Linux - flash: [ 4.4574 ] ERROR: value 0x31 is out of range
10:35:38 ERROR: Flash Jetson Linux - flash: 74756 blocks
10:35:47 ERROR: Flash Jetson Linux - flash: 128307 blocks
10:40:29 ERROR: Flash Jetson Linux - flash: command terminated with error
10:40:29 SUMMARY: DateTime Target Setup - target: Depends on failed component
SDK Manager has an export button, which give you all the log in a .zip file.
What you paster here really makes no help.
SDKM_logs_JetPack_6.0_DP_Linux_for_Jetson_Orin_Nano_modules_2024-04-25_15-40-16.zip (182.1 KB)
Do you have nfs-common and nfs-kernel-server installed on your host PC?
Yes, I have both installed on my host machine.
********:~$ apt list --installed | grep nfs-common
nfs-common/jammy-updates,now 1:2.6.1-1ubuntu1.2 amd64 [installed]
********:~$ apt list --installed | grep nfs-kernel-server
nfs-kernel-server/jammy-updates,now 1:2.6.1-1ubuntu1.2 amd64 [installed]
Check if firewall is enabled, as it will block NFS server and cause this error.
It worked after disabling the firewall, thank you for useful help
have a nice day.
