SDK Manager fails to flash Orin NX 8GB (NVMe) on Orin Nano Developer Kit
I’ve replaced the default module on the Orin Nano Developer Kit with an Orin NX 8GB and am trying to use SDK Manager 1.9.2.10899 to flash Jetson Linux 35.3.1 BSP onto the attached NVMe from Ubuntu 20.04.6 LTS. The SDK Manager detects the NX module correctly and successfully creates the Jetson Linux image.
Note: Flashing the default Orin Nano module with the same NVMe on the same system works fine.
Here are the SDK Manager flash settings:
The flashing fails at around 98% and here are the errors:
ERROR: failed to read rcm_state
ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
ERROR: /misc/tsc_controls/tsc_locking_config is not supported
ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
ERROR: /misc/tsc_controls/tsc_locking_control is not supported
ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
Error: Skip generating mem_bct because sdram_config is not defined
The second block of errors appears 11 times and the last error twice. Attached are the full exported logs though it seems that the terminal inside SDK Manager shows many more errors like:
16:17:49 ERROR: Flash Jetson Linux - flash: [ 2.8873 ] Error: Skip generating mem_bct because sdram_config is not defined
16:17:59 ERROR: Flash Jetson Linux - flash: 39726 blocks
16:17:59 ERROR: Flash Jetson Linux - flash: gzip: /home/ubuntu/data/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
16:18:22 ERROR: Flash Jetson Linux - flash: 56174 blocks
16:18:24 ERROR: Flash Jetson Linux - flash: 20+0 records in
16:18:24 ERROR: Flash Jetson Linux - flash: 20+0 records out
16:18:24 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.00458513 s, 4.4 kB/s
16:18:26 ERROR: Flash Jetson Linux - flash: 131072+0 records in
16:18:26 ERROR: Flash Jetson Linux - flash: 131072+0 records out
16:18:26 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.92588 s, 72.5 MB/s
16:19:20 ERROR: Flash Jetson Linux - flash: 39726 blocks
16:19:20 ERROR: Flash Jetson Linux - flash: gzip: /home/ubuntu/data/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
16:19:44 ERROR: Flash Jetson Linux - flash: 56174 blocks
16:19:45 ERROR: Flash Jetson Linux - flash: 20+0 records in
16:19:45 ERROR: Flash Jetson Linux - flash: 20+0 records out
16:19:45 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.00961248 s, 2.1 kB/s
16:27:09 ERROR: Flash Jetson Linux - flash: 131072+0 records in
16:27:09 ERROR: Flash Jetson Linux - flash: 131072+0 records out
16:27:09 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.944642 s, 71.0 MB/s
16:27:52 ERROR: Flash Jetson Linux - flash: tar:
16:27:52 ERROR: Flash Jetson Linux - flash: W
16:27:52 ERROR: Flash Jetson Linux - flash: r
16:27:52 ERROR: Flash Jetson Linux - flash: i
16:27:52 ERROR: Flash Jetson Linux - flash: e
16:27:52 ERROR: Flash Jetson Linux - flash: c
16:27:52 ERROR: Flash Jetson Linux - flash: h
16:27:52 ERROR: Flash Jetson Linux - flash: k
16:27:52 ERROR: Flash Jetson Linux - flash: p
16:27:52 ERROR: Flash Jetson Linux - flash: o
16:27:52 ERROR: Flash Jetson Linux - flash: n
16:27:52 ERROR: Flash Jetson Linux - flash: 10000
16:30:55 ERROR: Flash Jetson Linux - flash: 39726 blocks
16:30:55 ERROR: Flash Jetson Linux - flash: gzip: /home/ubuntu/data/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
16:31:01 ERROR: Flash Jetson Linux - flash: 56174 blocks
16:31:02 ERROR: Flash Jetson Linux - flash: 20+0 records in
16:31:02 ERROR: Flash Jetson Linux - flash: 20+0 records out
16:31:02 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000430252 s, 46.5 kB/s
16:31:03 ERROR: Flash Jetson Linux - flash: 131072+0 records in
16:31:03 ERROR: Flash Jetson Linux - flash: 131072+0 records out
16:31:03 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.361015 s, 186 MB/s
16:31:08 ERROR: Flash Jetson Linux - flash: /home/ubuntu/data/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg):
16:31:08 ERROR: Flash Jetson Linux - flash: Node /fragment@0 has a unit name, but no reg property
16:31:09 ERROR: Flash Jetson Linux - flash: /home/ubuntu/data/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg):
16:31:09 ERROR: Flash Jetson Linux - flash: Node /fragment@0 has a unit name, but no reg property
ERROR: Flash Jetson Linux - flash: 83156 blocks
ERROR: Flash Jetson Linux - flash: command terminated with error
SUMMARY: Flash Jetson Linux - flash: First error: Installation failed.
The write checkpoint error appears in increments of 10000 up to 550000.
NV_L4T_FLASH_JETSON_LINUX_COMP.log (236.1 KB)
NV_L4T_FILE_SYSTEM_AND_OS_COMP.log (16.3 KB)
NV_L4T_DRIVERS_COMP.log (1.4 KB)
Any help to get this resolved quickly would be appreciated as I need to know if this is a software issue or a hardware defect.
I came across this post about flashing issues on the AGX Orin which seemed to have the similar types of errors. The suggested solution was to retry it on Ubuntu 18.04 which indeed worked for me on the second try, though the errors were the same.
Although my problem is fixed for now it’d be great if the NVDIA Jetson team could follow up on these issues and make flashing bulletproof.
Hi igor_furoa,
Could you refer to the following thread to disable auto suspend on your host PC before flash?
Cannot flash Jetson AGX Orin (JetPack 5.1.1) - #15 by WayneWWW
Can confirm that flashing worked without problems after running:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
Thanks for the suggestion 👍
