Having issues with Flashing Orin NX in Orin Dev kit
I have an Orin NX module w/NVMe drive plugged into an Orin Developer kit. I am able to successfully flash this module with the SDK manager UI but I would like to flash it with a custom configuration to enable HDMI. As far as I can tell, I should flash with the Jetson AGX dev kit configuration as that has HDMI enabled.
I have Ubuntu 20.04 as host OS, trying to flash JP 5.1.3.
I have tried this: How to flash Jetson Orin NX 16GB moudule
Here’s board info:
Board ID(3767) version(500) sku(0001) revision()
Chip SKU(00:00:00:D4) ramcode(00:00:00:02) fuselevel(fuselevel_production) board_FAB(500)
ECID is 0x80012344705DD51D400000000FFE8280
==== Fuse Info (/media/user/Backup/jetson_flash/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/) ====
cat: /media/user/Backup/jetson_flash/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/: Is a directory
==== EEPROM content (/media/user/Backup/jetson_flash/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin) ====
00000000: 02 00 fe 00 00 00 00 00 00 00 00 ff 00 00 00 00  ................
00000010: 00 01 00 01 36 39 39 2d 31 33 37 36 37 2d 30 30  ....699-13767-00
00000020: 30 31 2d 35 30 30 00 00 00 00 00 00 00 00 00 00  01-500..........
00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000040: b0 48 00 00 4c 57 f0 2d b0 48 31 36 31 32 38 32  .H..LW.-.H161282
00000050: 33 36 32 30 34 32 30 00 00 00 00 00 00 00 00 00  3620420.........
00000060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000090: 00 00 00 00 00 00 4e 56 43 42 00 ff 4d 31 00 00  ......NVCB..M1..
000000a0: 00 00 00 00 00 00 00 00 00 00 00 00 4c 57 f0 2d  ............LW.-
000000b0: b0 48 01 00 00 00 00 00 00 00 00 00 00 00 00 00  .H..............
000000c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11  ................
Using Orin NX flashing guidance here, I am trying to flash like so:
I built my image with this:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 p3509-a02+p3767-0000 nvme0n1p1
I changed the to p3509-a02+p3767-0000 as a few posts have indicated this config is the same as the Orin NX but it enables HDMI instead of DP.
When putting my device in recovery mode, I am just shorting the pins fc_rec pin to ground using a jumper. Is there a point in the flash process when I should remove the jumper or should those only be shorted when first powering?
The flasher seems to have issues connecting via USB / Ethernet connection to the jetson board. I have included the flasher host logs and the device logs from the UART2 debug console. Any ideas as to what is going on?
device_logs.txt (6.6 KB)
jetson_flash.log (6.9 KB)
I am not quite sure what are you going to do here.
Ok, this is NV developer kit.
Correctly flashed with SDKM. Expected result.
What does that mean?? You are using custom carrier board?
Orin AGX devkit does not have HDMI enabled. Where do you get such information?
