Unable to Flash Jetson Orin NX developer kit (custom carrier board)
I currently have the Orin NX 16 Gb Developer kit and I want to flash it and reinstall a fresh Jetpack 5.1 from the SDK Manager.
I have the TWOWIN T801_MBPCB_V2.0 as printed on the carrier board which is one of the official hardware partners as per nvidia’s website
It appears unable to flash the Jetson after I attempted the installation through the SDK manager. The jetson was put into recovery mode for the setup and as below the final messages in the terminal (waiting for target to bootup appears multiple times) :
" 10:09:00 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
10:09:01 INFO: Flash Jetson Linux - flash: Cleaning up…
10:09:01 ERROR: Flash Jetson Linux - flash: command terminated with error"
Before the SDK Manager says: “The target is in a bad state. The Jetson target is in a bad state and cannot be flashed. Please manually put the target into recovery mode and then retry flashing.”
My issue is as follows as the log files exported below:
SDKM_logs_JetPack_5.1.3_Linux_for_Jetson_Orin_NX_modules_2024-08-07_10-05-15.zip (673.2 KB)
please let me know if you require any other files.
As a workaround solution,
I also have an original carrier board from the Jetson Orin Nano 8Gb and would like to know if i can simply swap the Jetson Orin NX 16 Gb with this Carrier board from the Jetson Orin Nano 8Gb ?
Would this solve any of the issues or is this an incompatible swap?
What is TWOWIN T801_MBPCB_V2.0 exactly? A component? or a carrier board?
It is the carrier board the Jetson Module is placed on:
This is a custom carrier board that Sdkmanager does not guarantee would be able to flash it.
Then is it possible to switch the carrier board as mentioned? :
If your original Orin Nano carrier board is NV devkit, then it can flash.
Okay thanks. Just to confirm.
  1. the hardware of the Jetson Orin NX 16Gb Module can simply be switched out with the Jetson Orin Nano 8GB module so that it utilizes the original carrier board?
  2. The carrier board as long as original can be flashed through sdk.
Yes correct
