Cant flash correctly Orin nx
Hello I have orin nx board and carrier board https://www.antratek.nl/j401-carrier-board-for-jetson-orin-nano-nx
I choose correct option I think for flash.
but I cant flash the board, it gives error.
17:38:01 SUMMARY: CUDA on Host - host: Install completed successfully.
17:38:01 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
17:38:01 SUMMARY: NvSci - host: Install completed successfully.
17:38:01 SUMMARY: VPI on Host - host: Install completed successfully.
17:38:01 SUMMARY: Nsight Systems - host: Install completed successfully.
17:38:01 SUMMARY: Nsight Graphics - host: Install completed successfully.
17:38:01 SUMMARY: Nsight Compute - host: Install completed successfully.
17:38:01 SUMMARY: Nsight Perf SDK - host: Install completed successfully.
17:38:01 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
17:38:01 SUMMARY: File System and OS - target_image: Install completed successfully.
17:38:44 ERROR: shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
17:38:44 ERROR: Flash Jetson Linux - flash: [ 0.2132 ] Error: Skip generating mem_bct because sdram_config is not defined
17:38:54 ERROR: Flash Jetson Linux - flash: gzip: /home/ulas/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
17:39:00 ERROR: Flash Jetson Linux - flash: 58274 blocks
17:39:01 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0,000391087 s, 51,1 kB/s
17:39:01 ERROR: Flash Jetson Linux - flash: 131072+0 records out
17:39:01 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0,348985 s, 192 MB/s
17:39:07 ERROR: Flash Jetson Linux - flash: /home/ulas/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
17:39:07 ERROR: Flash Jetson Linux - flash: /home/ulas/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
17:39:08 ERROR: Flash Jetson Linux - flash: [ 0.7638 ] ERROR: value 0x31 is out of range
17:39:08 ERROR: Flash Jetson Linux - flash: [ 0.7648 ] ERROR: value 0x31 is out of range
17:39:08 ERROR: Flash Jetson Linux - flash: [ 0.7650 ] ERROR: value 0x31 is out of range
17:39:19 ERROR: Flash Jetson Linux - flash: 42011 blocks
17:39:19 ERROR: Flash Jetson Linux - flash: gzip: /home/ulas/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
17:39:26 ERROR: Flash Jetson Linux - flash: 58274 blocks
17:39:26 ERROR: Flash Jetson Linux - flash: 20+0 records out
17:42:26 ERROR: Flash Jetson Linux - flash: 131072+0 records in
17:42:26 ERROR: Flash Jetson Linux - flash: 131072+0 records out
17:42:26 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 1,60872 s, 41,7 MB/s
17:42:32 ERROR: Flash Jetson Linux - flash: /home/ulas/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
17:42:32 ERROR: Flash Jetson Linux - flash: /home/ulas/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
17:42:40 ERROR: Flash Jetson Linux - flash: XPath set is empty
17:43:10 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 170000
17:43:10 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 180000
17:43:11 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 190000
17:43:12 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 200000
17:43:12 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 210000
17:43:12 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 220000
17:43:14 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 260000
17:43:15 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 270000
17:43:16 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 280000
17:43:17 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 290000
17:43:30 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 300000
17:43:38 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 310000
17:43:39 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 320000
17:43:40 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 330000
17:43:41 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 340000
17:43:42 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 350000
17:43:46 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 360000
17:43:46 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 370000
17:43:46 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 380000
17:43:47 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 390000
17:43:48 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 400000
17:43:48 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 410000
17:43:48 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 420000
17:43:49 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 430000
17:43:49 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 440000
17:43:50 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 450000
17:43:51 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 480000
17:43:51 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 490000
17:43:52 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 500000
17:43:53 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 510000
17:43:54 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 520000
17:43:54 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 530000
17:44:35 ERROR: Flash Jetson Linux - flash: /home/ulas/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
17:44:35 ERROR: Flash Jetson Linux - flash: /home/ulas/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
17:44:36 ERROR: Flash Jetson Linux - flash: [ 0.7705 ] ERROR: value 0x31 is out of range
17:44:36 ERROR: Flash Jetson Linux - flash: [ 0.7716 ] ERROR: value 0x31 is out of range
17:44:42 ERROR: Flash Jetson Linux - flash: [ 6.0402 ] ERROR: value 0x31 is out of range
17:44:45 ERROR: Flash Jetson Linux - flash: 58274 blocks
17:44:53 ERROR: Flash Jetson Linux - flash: 85060 blocks
17:45:47 ERROR: Flash Jetson Linux - flash: Error: Could not stat device /dev/nvme0n1 - No such file or directory.
17:45:47 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/ulas/.nvsdkm/replays/scripts/JetPack_5.1.4_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: 85060 blocks
17:45:47 ERROR: command error code: 11
17:45:47 ERROR: Flash Jetson Linux - flash: command terminated with error
17:45:47 SUMMARY: TensorRT on Target - target: Depends on failed component
17:45:47 SUMMARY: TensorRT Runtime - target: Depends on failed component
17:45:47 SUMMARY: VPI on Target - target: Depends on failed component
17:45:47 SUMMARY: VPI Runtime - target: Depends on failed component
17:45:47 SUMMARY: CuPVA Runtime - target: Depends on failed component
17:45:47 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
17:45:47 SUMMARY: CUDA Runtime - target: Depends on failed component
17:45:47 SUMMARY: cuDNN on Target - target: Depends on failed component
17:45:47 SUMMARY: CuDNN Runtime - target: Depends on failed component
17:45:47 SUMMARY: OpenCV - target: Depends on failed component
17:45:47 SUMMARY: OpenCV Runtime - target: Depends on failed component
17:45:47 SUMMARY: DateTime Target Setup - target: Depends on failed component
When I follow the instruction from this website for suitable carrier then I got these
Number of lines is 58 max_index=57 [ 1]: l4t_flash_from_kernel: Successfully create gpt for emmc [ 1]: l4t_flash_from_kernel: Starting to create gpt for external device Active index file is /mnt/external/flash.idx Number of lines is 17 max_index=16 writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 30aafa9b47f5f38cadb3fbc9f46be8472fc8a470 Error: Could not stat device /dev/nvme0n1 - No such file or directory. Flash failure Cleaning up...
This is a correct tutorial about flashing J30 and J40 devices Flash Jetpack | Seeed Studio Wiki
It appears that you are using a Seeed Studio carrier board, which is a custom carrier board and not compatible with our SDK Manager. Please contact Seeed Studio vendor directly to obtain their BSP for flashing.
Thank you.
