I am trying to flash my Orin NX 16GB module with JetPack 5.1.1, on a native Ubuntu20 host. I am not using the dev kit, but I am also facing this issue with two different carrier boards and I have not had success troubleshooting this with the board manufacturers, so I am wondering if it could be an issue with my NX module.
Here are my steps for flashing:
- I put the board in recovery,
lsusb
shows0955:7323 NVIDIA Corp. APX
- I run the flash command with
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
. This includes the vendors’ BSP files.
The script times out with:
Waiting for target to boot-up…
Waiting for device to expose ssh …RTNETLINK answers: File exists
Waiting for device to expose ssh …Run command: flash on fc00:1:1:0::2
SSH is not ready
Cleaning up…
At this point, lsusb
shows 0955:7035 NVIDIA Corp. Linux for Tegra
I have tried increasing the timeout count in l4t_network_flash.func but it still eventually times out in the same way. I have attached the host logs.
logs_ssh_error.txt (241.8 KB)
I’d appreciate any advice to troubleshoot this. Thank you.
