Hi guys,
I am having trouble re-flashing my Jetson TX2 using SDK manager. I am using ubuntu 18.04 as a host (no VM). I put the TX2 in recovery mode by holding down the recovery button, pressing and releasing the reset button, and releasing the recovery button after at least two seconds.
When I run SDK manager, the software recognizes the TX2 connected through USB. When the software asks how to flash the TX2, I chose the manual option. Shortly after pressing the flash button, I get an installation failure.
I have tried running the flash.sh file in the Linux_for_Tegra directory using sudo ./flash.sh jetson-tx2 nvme0n1p1. This flashes the TX2, but when the TX2 is booted, the USB port is disconnected, making it impossible to interact with.
Any advice would be really appreciated. Thank you in advanced. Bellow is the terminal output from the failed flash from the SDK manager.
12:54:46 INFO: File System and OS - target_image: Disabling NetworkManager-wait-online.service
12:54:46 INFO: File System and OS - target_image: Disable the ondemand service by changing the runlevels to 'K'
12:54:46 INFO: File System and OS - target_image: Success!
12:54:46 INFO: File System and OS - target_image: [ Package Install Finished Successfully ]
12:54:46 INFO: File System and OS - target_image: command finished successfully
12:54:46 SUMMARY: File System and OS - target_image: Install completed successfully.
13:13:11 ERROR: Can not find matching device in recovery mode.
13:13:11 DEBUG: running command < true >
13:13:11 INFO: exec_command: true
13:13:11 INFO: command finished successfully
13:13:11 DEBUG: running command < /tmp/device_mode_host_setup.sh >
13:13:11 INFO: exec_command: /tmp/device_mode_host_setup.sh
13:13:11 INFO: Found route default enp39s0, setting up device mode
13:13:11 INFO: [host] [sudo] password for willup:
13:13:11 INFO: net.ipv4.ip_forward = 1
13:13:11 INFO: Device mode on host successfully set with DNS 8.8.8.8!
13:13:11 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS to /home/willup/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS
13:13:11 INFO: Flash Jetson TX2 - flash: change working directory to /home/willup/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra
13:13:11 INFO: Flash Jetson TX2 - flash: sudo ./nvsdkmanager_flash.sh --nv-auto-config --username vsml
13:13:11 INFO: Flash Jetson TX2 - flash: [OEMPreconfig] SDKM_INSTALL_ERROR Password for L4T new user vsml:
13:13:11 INFO: Flash Jetson TX2 - flash: *** Checking ONLINE mode ... OK.
13:13:11 INFO: Flash Jetson TX2 - flash: *** Checking target board connection ... 1 connections found.
13:13:11 INFO: Flash Jetson TX2 - flash: *** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x18 bootauth=NS
13:13:11 INFO: Flash Jetson TX2 - flash: *** Reading EEPROM ... "/home/willup/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x18 --applet "/home/willup/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin; reboot recovery"
13:13:11 INFO: Flash Jetson TX2 - flash: [ 0.0040 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/willup/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
13:13:11 INFO: Flash Jetson TX2 - flash: [ 0.0072 ] Assuming zero filled SBK key
13:13:11 INFO: Flash Jetson TX2 - flash: [ 0.0147 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
13:13:12 INFO: Flash Jetson TX2 - flash: [ 0.0174 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
13:13:12 INFO: Flash Jetson TX2 - flash: [ 0.0182 ] RCM version 0X180001
13:13:14 INFO: Flash Jetson TX2 - flash: [ 2.2859 ] tegrarcm_v2 --isapplet
13:13:15 INFO: Flash Jetson TX2 - flash: [ 2.8081 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/willup/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
13:13:15 INFO: Flash Jetson TX2 - flash: [ 2.8088 ] Applet version 01.00.0000
13:13:15 INFO: Flash Jetson TX2 - flash: [ 3.3217 ] Saved platform info in /home/willup/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
13:13:15 INFO: Flash Jetson TX2 - flash: [ 3.3980 ] RCM 0 is saved as rcm_0.rcm
13:13:15 INFO: Flash Jetson TX2 - flash: [ 3.4005 ] Assuming zero filled SBK key
13:13:15 INFO: Flash Jetson TX2 - flash: [ 3.4086 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
13:13:20 INFO: Flash Jetson TX2 - flash: [ 3.4109 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
13:13:22 INFO: Flash Jetson TX2 - flash: [ 9.9033 ] tegrarcm_v2 --isapplet
13:13:22 INFO: Flash Jetson TX2 - flash: [ 10.4280 ] tegrarcm_v2 --oem platformdetails eeprom cvb /home/willup/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
13:13:22 INFO: Flash Jetson TX2 - flash: [ 10.4287 ] Applet version 01.00.0000
13:13:22 ERROR: Flash Jetson TX2 - flash: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa4 in position 8: invalid start byte
13:13:22 ERROR: Flash Jetson TX2 - flash: --- Error: Reading board information failed.
13:13:22 ERROR: Flash Jetson TX2 - flash: command terminated with error
13:13:22 SUMMARY: DateTime Target Setup - target: Depends on failed component
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2022, [NVIDIA CORPORATION](http://www.nvidia.com/page/home.html). All rights reserved. | [NVIDIA Developer](https://developer.nvidia.com/)
