In the SDK manager, we are able to get to step 3 and it builds the jetson os image but fails to flash the jetson board. Happens with following terminal statements; Any help and suggestions are greatly appreciated.
10:53:23 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS to /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS
10:53:23 INFO: Flash Jetson TX2 - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
10:53:23 INFO: Flash Jetson TX2 - flash: *** Checking target board connection … 1 connections found.
10:53:23 INFO: Flash Jetson TX2 - flash: *** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x18 bootauth=NS
10:53:23 INFO: Flash Jetson TX2 - flash: *** Reading EEPROM … “/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x18 --applet “/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin; reboot recovery”
10:53:23 INFO: Flash Jetson TX2 - flash: [ 0.0048 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
10:53:23 INFO: Flash Jetson TX2 - flash: [ 0.0232 ] RCM version 0X180001
10:53:25 INFO: Flash Jetson TX2 - flash: [ 2.0354 ] tegrarcm_v2 --isapplet
10:53:25 INFO: Flash Jetson TX2 - flash: [ 2.0488 ] Applet version 01.00.0000
10:53:25 INFO: Flash Jetson TX2 - flash: [ 2.0673 ] Saved platform info in /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
10:53:25 INFO: Flash Jetson TX2 - flash: [ 2.1414 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
10:53:25 INFO: Flash Jetson TX2 - flash: [ 2.1530 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
10:53:31 INFO: Flash Jetson TX2 - flash: [ 2.1551 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
10:53:32 INFO: Flash Jetson TX2 - flash: [ 8.3269 ] tegrarcm_v2 --isapplet
10:53:32 INFO: Flash Jetson TX2 - flash: [ 8.3398 ] Applet version 01.00.0000
10:53:32 INFO: Flash Jetson TX2 - flash: UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xa4 in position 16: invalid start byte
10:53:32 INFO: Flash Jetson TX2 - flash: — Error: Reading board information failed.
10:53:32 ERROR: Flash Jetson TX2 - flash: command terminated with error
10:53:32 SUMMARY: DateTime Target Setup - target: Depends on failed component
INSTALLATION FAILED
