I am installing jetpack 4.2 using sdkmanager. I was successful until flashing. However, during the installation of sdk I get the message “jetson device is in recovery mode.”, and I can not install it.But I have already enter the desktop with my username and password. How should this problem be addressed?
When you completes the flashing proces and initial setup process, the tx2 boots to the Linux desktop.
Then you can enter username and password to continue install SDK components. → Are you see the SDK Manager’s post-flash installation dialog?
I am also seeing the same problem. It flashed successfully. After completing the system configuration on the TX2, I entered the user credentials of TX2 in the SDK manager to install the SDK components. It says Jetson is in recovery mode.
Are you connect the HDMI cable?
After completed the flash, you need initial setup process (setup your username, password and language…), then the device boots to Linux Desktop. At this point, please enter your username and password to continue install again.
Yes, that is what I did. After flashing, I finished setting the username, password, language, timezone, etc. After that the TX2 rebooted. Then I entered the username and password in the SDK manager. It says Jetson device is in recovery mode.
could you tell me which sdk have you downloaded for jetpack 4.2 installation. I’m trying to install sdk_manager for jetpack4.2 but only got sdk_manager_0.9.11 for the new version.
Yeah I’ve also downloaded the same version of SDK manager which is 0.9.11. Nvidia says that it can be used to download jetpack4.2 and I do have been downloading it. I just have some problem installing the SDK components.
I have the same problem. The flash went ok, I have created the account (username, password, etc) on the host computer but when i want to install the SDK through Jetson it says that “Jetson device is in recovery mode”. I have restarted the jeston several times but it still says that it is in revocery mode and I can’t install it.
I have solved the problem. Try the following steps.
Connect your host PC to Jetson using a USB cable
Run SDK manager software on the host PC and start to setup the software using manual mode.
Flashing Ubuntu to Jetson through the SDK manager. After that, do initial setups such as creating an account on the Ubuntu of Jetson.
Quit the SDK manager once on the host PC.
Restart the SDK manager on the host PC and unchecked the flashing process of Ubuntu image data to skip the flashing process (Very important!!) in the wizard menu of the SDK manager.
Then, you can install Jetson SDK components using an user account created on Jetson.
