sudo ./flash.sh jetson-tx2 mmcblk0p1
command ends up with:
1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.4177 ]
[ 0.4177 ] Copying signatures
[ 0.4184 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.4522 ]
[ 0.4522 ] Boot Rom communication
[ 0.4533 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 0.4540 ] BootRom is not running
[ 5.4546 ]
[ 6.4580 ] tegrarcm_v2 --isapplet
[ 6.4606 ] Applet version 01.00.0000
[ 6.4732 ]
[ 6.4733 ] Sending BCTs
[ 6.4761 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 6.4788 ] Applet version 01.00.0000
[ 6.5055 ] Sending bct_bootrom
[ 1006.5025 ]
Error: Return value 3
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Failed flashing t186ref.
Also, with the SDK Manager
while flashing, logs says
- 13:41:34 ERROR : Flash Jetson TX2 : 2843: SKP: 12288( 3 blks) ==> 3938964832:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2844: RAW: 495616( 121 blks) ==> 3938964844:495628
- 13:41:34 ERROR : Flash Jetson TX2 : 2845: SKP: 4096( 1 blks) ==> 3939460472:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2846: RAW: 24576( 6 blks) ==> 3939460484:24588
- 13:41:34 ERROR : Flash Jetson TX2 : 2847: SKP: 8192( 2 blks) ==> 3939485072:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2848: RAW: 4096( 1 blks) ==> 3939485084:4108
- 13:41:34 ERROR : Flash Jetson TX2 : 2849: SKP: 28672( 7 blks) ==> 3939489192:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2850: RAW: 65536( 16 blks) ==> 3939489204:65548
- 13:41:34 ERROR : Flash Jetson TX2 : 2851: SKP: 12288( 3 blks) ==> 3939554752:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2852: RAW: 24576( 6 blks) ==> 3939554764:24588
- 13:41:34 ERROR : Flash Jetson TX2 : 2853: SKP: 8192( 2 blks) ==> 3939579352:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2854: RAW: 24576( 6 blks) ==> 3939579364:24588
- 13:41:34 ERROR : Flash Jetson TX2 : 2855: SKP: 8192( 2 blks) ==> 3939603952:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2856: RAW: 4096( 1 blks) ==> 3939603964:4108
- 13:41:34 ERROR : Flash Jetson TX2 : 2857: SKP: 20480( 5 blks) ==> 3939608072:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2858: RAW: 20480( 5 blks) ==> 3939608084:20492
- 13:41:34 ERROR : Flash Jetson TX2 : 2859: SKP: 8192( 2 blks) ==> 3939628576:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2860: RAW: 69632( 17 blks) ==> 3939628588:69644
- 13:41:34 ERROR : Flash Jetson TX2 : 2861: SKP: 45056( 11 blks) ==> 3939698232:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2862: RAW: 192512( 47 blks) ==> 3939698244:192524
- 13:41:34 ERROR : Flash Jetson TX2 : 2863: SKP: 49152( 12 blks) ==> 3939890768:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2864: RAW: 139264( 34 blks) ==> 3939890780:139276
- 13:41:34 ERROR : Flash Jetson TX2 : 2865: SKP: 40960( 10 blks) ==> 3940030056:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2866: RAW: 262144( 64 blks) ==> 3940030068:262156
- 13:41:34 ERROR : Flash Jetson TX2 : 2869: SKP: 36864( 9 blks) ==> 3940308632:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2870: RAW: 204800( 50 blks) ==> 3940308644:204812
- 13:41:34 ERROR : Flash Jetson TX2 : 2871: SKP: 45056( 11 blks) ==> 3940513456:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2872: RAW: 126976( 31 blks) ==> 3940513468:126988
- 13:41:34 ERROR : Flash Jetson TX2 : 2874: RAW: 16384( 4 blks) ==> 3940640468:16396
- 13:41:34 ERROR : Flash Jetson TX2 : 2875: SKP: 36864( 9 blks) ==> 3940656864:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2876: RAW: 172032( 42 blks) ==> 3940656876:172044
- 13:41:34 ERROR : Flash Jetson TX2 : 2878: RAW: 65536( 16 blks) ==> 3940828932:65548
- 13:41:34 ERROR : Flash Jetson TX2 : 2880: RAW: 344064( 84 blks) ==> 3940894492:344076
- 13:41:34 ERROR : Flash Jetson TX2 : 2882: RAW: 102400( 25 blks) ==> 3941238580:102412
- 13:41:34 ERROR : Flash Jetson TX2 : 2884: RAW: 20480( 5 blks) ==> 3941341004:20492
- 13:41:34 ERROR : Flash Jetson TX2 : 2885: SKP: 36864( 9 blks) ==> 3941361496:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2886: RAW: 69632( 17 blks) ==> 3941361508:69644
- 13:41:34 ERROR : Flash Jetson TX2 : 2887: SKP: 12288( 3 blks) ==> 3941431152:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2888: RAW: 24576( 6 blks) ==> 3941431164:24588
- 13:41:34 ERROR : Flash Jetson TX2 : 2889: SKP: 8192( 2 blks) ==> 3941455752:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2890: RAW: 20480( 5 blks) ==> 3941455764:20492
- 13:41:34 ERROR : Flash Jetson TX2 : 2891: SKP: 32768( 8 blks) ==> 3941476256:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2892: RAW: 12288( 3 blks) ==> 3941476268:12300
- 13:41:34 ERROR : Flash Jetson TX2 : 2893: SKP: 12288( 3 blks) ==> 3941488568:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2894: RAW: 40960( 10 blks) ==> 3941488580:40972
- 13:41:34 ERROR : Flash Jetson TX2 : 2895: SKP: 28672( 7 blks) ==> 3941529552:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2896: RAW: 28672( 7 blks) ==> 3941529564:28684
- 13:41:34 ERROR : Flash Jetson TX2 : 2897: SKP: 4096( 1 blks) ==> 3941558248:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2898: RAW: 339968( 83 blks) ==> 3941558260:339980
- 13:41:34 ERROR : Flash Jetson TX2 : 2900: RAW: 16384( 4 blks) ==> 3941898252:16396
- 13:41:34 ERROR : Flash Jetson TX2 : 2901: SKP: 4096( 1 blks) ==> 3941914648:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2902: RAW: 102400( 25 blks) ==> 3941914660:102412
- 13:41:34 ERROR : Flash Jetson TX2 : 2903: SKP: 8192( 2 blks) ==> 3942017072:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2904: RAW: 20480( 5 blks) ==> 3942017084:20492
- 13:41:34 ERROR : Flash Jetson TX2 : 2906: RAW: 69632( 17 blks) ==> 3942037588:69644
- 13:41:34 ERROR : Flash Jetson TX2 : 2908: RAW: 24576( 6 blks) ==> 3942107244:24588
- 13:41:34 ERROR : Flash Jetson TX2 : 2911: SKP: 32768( 8 blks) ==> 3942152336:12
- 13:41:34 ERROR : Flash Jetson TX2 : 2912: RAW: 12288( 3 blks) ==> 3942152348:12300
- 13:41:34 ERROR : Flash Jetson TX2 : 2914: RAW: 24576( 6 blks) ==> 3942164660:24588
- 13:41:34 ERROR : Flash Jetson TX2 : 3020: RAW: 90112( 22 blks) ==> 3946433964:90124
- 13:41:34 ERROR : Flash Jetson TX2 : 3456: RAW: 602112( 147 blks) ==> 3969253916:602124
- 13:41:35 ERROR : Flash Jetson TX2 : 3922: RAW: 790528( 193 blks) ==> 4026222580:790540
- 13:41:35 ERROR : Flash Jetson TX2 : 3933: SKP: 28672( 7 blks) ==> 4027566200:12
- 13:41:35 ERROR : Flash Jetson TX2 : 3934: RAW: 16384( 4 blks) ==> 4027566212:16396
- 13:41:35 ERROR : Flash Jetson TX2 : 3935: SKP: 4096( 1 blks) ==> 4027582608:12
- 13:41:35 ERROR : Flash Jetson TX2 : 3936: RAW: 126976( 31 blks) ==> 4027582620:126988
- 13:41:35 ERROR : Flash Jetson TX2 : 3938: RAW: 69632( 17 blks) ==> 4027709620:69644
- 13:41:35 ERROR : Flash Jetson TX2 : 3940: RAW: 483328( 118 blks) ==> 4027779276:483340
- 13:41:35 ERROR : Flash Jetson TX2 : 3942: RAW: 69632( 17 blks) ==> 4028262628:69644
- 13:41:35 ERROR : Flash Jetson TX2 : 3944: RAW: 348160( 85 blks) ==> 4028332284:348172
- 13:41:35 ERROR : Flash Jetson TX2 : 3946: RAW: 229376( 56 blks) ==> 4028680468:229388
- 13:41:35 ERROR : Flash Jetson TX2 : 3948: RAW: 708608( 173 blks) ==> 4028909868:708620
- 13:41:35 ERROR : Flash Jetson TX2 : 3950: RAW: 69632( 17 blks) ==> 4029618500:69644
- 13:41:35 ERROR : Flash Jetson TX2 : 3952: RAW: 16384( 4 blks) ==> 4029688156:16396
- 13:41:35 ERROR : Flash Jetson TX2 : 4094: RAW: 241664( 59 blks) ==> 4036722692:241676
- 13:41:35 ERROR : Flash Jetson TX2 : 4222: RAW: 1327104( 324 blks) ==> 4058367492:1327116
- 13:41:36 ERROR : Flash Jetson TX2 : 4759: SKP: 1605394432( 391942 blks) ==> 4104498992:12
- 13:41:36 ERROR : Flash Jetson TX2 : 4760: RAW: 8192( 2 blks) ==> 4104499004:8204
- 13:41:36 ERROR : Flash Jetson TX2 : 4761: SKP: 57344( 14 blks) ==> 4104507208:12
- 13:41:36 ERROR : Flash Jetson TX2 : 4763: SKP: 61440( 15 blks) ==> 4104511328:12
- 13:41:36 ERROR : Flash Jetson TX2 : 4764: RAW: 20480( 5 blks) ==> 4104511340:20492
- 13:41:36 ERROR : Flash Jetson TX2 : 4765: SKP: 33533952( 8187 blks) ==> 4104531832:12
- 13:41:36 ERROR : Flash Jetson TX2 : 4766: RAW: 77824( 19 blks) ==> 4104531844:77836
- 13:41:36 ERROR : Flash Jetson TX2 : 4767: SKP: 100454400( 24525 blks) ==> 4104609680:12
- 13:41:36 ERROR : Flash Jetson TX2 : 4768: RAW: 212992( 52 blks) ==> 4104609692:213004
- 13:41:37 ERROR : Flash Jetson TX2 : 4769: SKP: 2013052928( 491468 blks) ==> 4104822696:12
- 13:41:37 ERROR : Flash Jetson TX2 : 4771: SKP: 45056( 11 blks) ==> 4104843200:12
- 13:41:37 ERROR : Flash Jetson TX2 : 4772: RAW: 16384( 4 blks) ==> 4104843212:16396
- 13:41:37 ERROR : Flash Jetson TX2 : 4773: SKP: 49152( 12 blks) ==> 4104859608:12
- 13:41:37 ERROR : Flash Jetson TX2 : 4774: RAW: 6889472( 1682 blks) ==> 4104859620:6889484
- 13:41:37 ERROR : Flash Jetson TX2 : 4775: SKP: 26664960( 6510 blks) ==> 4111749104:12
- 13:41:37 ERROR : Flash Jetson TX2 : 4776: RAW: 6909952( 1687 blks) ==> 4111749116:6909964
- 13:41:37 ERROR : Flash Jetson TX2 : 4777: SKP: 93622272( 22857 blks) ==> 4118659080:12
- 13:41:44 ERROR : Flash Jetson TX2 : 4778: RAW: 41545728( 10143 blks) ==> 4118659092:41545740
- 13:41:49 ERROR : Flash Jetson TX2 : 4780: RAW: 8712192( 2127 blks) ==> 4160204844:8712204
- 13:41:50 ERROR : Flash Jetson TX2 : 4781: SKP: 61440( 15 blks) ==> 4168917048:12
- 13:41:53 ERROR : Flash Jetson TX2 : 4782: RAW: 9015296( 2201 blks) ==> 4168917060:9015308
- 13:41:53 ERROR : Flash Jetson TX2 : 4783: SKP: 61440( 15 blks) ==> 4177932368:12
- 13:41:53 ERROR : Flash Jetson TX2 : 4784: RAW: 14651392( 3577 blks) ==> 4177932380:14651404
- 13:41:53 ERROR : Flash Jetson TX2 : 4785: SKP: 61440( 15 blks) ==> 4192583784:12
- 13:41:53 ERROR : Flash Jetson TX2 : 4786: RAW: 7852032( 1917 blks) ==> 4192583796:7852044
- 13:41:53 ERROR : Flash Jetson TX2 : 4787: SKP: 61440( 15 blks) ==> 4200435840:12
- 13:41:53 ERROR : Flash Jetson TX2 : 4788: RAW: 921600( 225 blks) ==> 4200435852:921612
After %95 percent, it gives ;
… - 13:58:41 ERROR : Flash Jetson TX2 : Run commands failed at step Install: command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
- 13:58:41 ERROR : Flash Jetson TX2 : command terminated with error
- 13:58:41 ERROR : Flash Jetson TX2 : install ‘Flash Jetson TX2’ failure, command < cd ‘/home/logi/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP’ -v=‘32.3’ -l=‘/home/logi/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310’ -L=‘/home/logi/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘13095’ -t=‘P3310’ -e=‘undefined’ > terminated with error
