We are flashing new TX2 modules with a massflash blob.
nvmflash does flash correctly all partitions.
But we have one module that fails with the following error.
As if some partition was not correctly flashed:
*** Boot Rom communication
/cam5/mfi_jetson-tx2/tegrarcm_v2 --instance 3-2 --chip 0x18 0 --rcm rcm_list_signed.xml
BR_CID: 0x8180100164122242040000000b020380
RCM version 0X180001
Boot Rom communication completed
*** Boot Rom communication succeeded.
*** Checking applet
/cam5/mfi_jetson-tx2/tegrarcm_v2 --instance 3-2 --isapplet
Applet version 01.00.0000
*** Checking applet succeeded.
*** Sending BCTs
/cam5/mfi_jetson-tx2/tegrarcm_v2 --instance 3-2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Sending bct_bootrom
[................................................] 100%
Sending bct_mb1
*** Sending BCTs succeeded.
*** Sending bootloader and pre-requisite binaries
/cam5/mfi_jetson-tx2/tegrarcm_v2 --instance 3-2 --download blob blob.bin
Sending blob
*** Sending bootloader and pre-requisite binaries succeeded.
*** Booting Recovery
/cam5/mfi_jetson-tx2/tegrarcm_v2 --instance 3-2 --boot recovery
*** Booting Recovery succeeded.
*** Checking applet
*** Checking CPU bootloader
/cam5/mfi_jetson-tx2/tegradevflash_v2 --instance 3-2 --iscpubl
CPU Bootloader is not running on device.
*** Error: Checking CPU bootloader failed.
Here’s the serial line output:
[0042.173] E> Waypoint-0.5 ACK pending: 0x8
[0042.177] C> MTS error (2) : dram alias check failure
[0042.182] C> cpu waypoint 0.5 failed
[0042.185] C> ERROR: Highest Layer Module = 0x32, Lowest Layer Module = 0x32,
Aux Info = 0x1, Reason = 0x6
[0016.266] E> Waypoint-0.5 ACK pending: 0x8
[0016.270] C> MTS error (2) : dram alias check failure
[0016.275] C> cpu waypoint 0.5 failed
[0016.278] C> ERROR: Highest Layer Module = 0x32, Lowest Layer Module = 0x32,
Thank you for your help.
Tanguy
