*** Boot Rom communication
/home/aetina/flash/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/mfi_jetson-tx2-devkit/tegrarcm_v2 --instance 3-2 --chip 0x18 0 --rcm rcm_list_signed.xml
BootRom is not running
*** Boot Rom communication succeeded.
*** Checking applet
/home/aetina/flash/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/mfi_jetson-tx2-devkit/tegrarcm_v2 --instance 3-2 --isapplet
USB communication failed.Check if device is in recovery
*** Error: Checking applet failed.
I follow the README_Massflash.txt
Step 1 Build the mfi_jetson-tx2-devkit.tbz2
Use the command below
./nvmassflashgen.sh jetson-tx2-devkit mmcblk0p1
Step 2 follow the tips
2. Untar mfi_jetson-tx2-devkit.tbz2. ( tar xvjf mfi_jetson-tx2-devkit.tbz2 )
3. cd mfi_jetson-tx2-devkit
4. Connect Jetson boards(jetson-tx2-devkit only) and put them in RCM mode.
5. ./nvmflash.sh
I use the way which you provide to flash two Jetson
One of them still fail,the other is flashing complete.
The log below
/home/aetina/flash/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/mfi_jetson-tx2/tegrarcm_v2 --instance 3-2 --chip 0x18 0 --rcm rcm_list_signed.xml
BR_CID: 0x818010016400b2091000000007fc0180
RCM version 0X180001
Boot Rom communication completed
*** Checking applet
/home/aetina/flash/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/mfi_jetson-tx2/tegrarcm_v2 --instance 3-2 --isapplet
No device on specified bus-port[3-2]
