Hello, I am using a carrier board Auvidea JD30D, use the feb 2022 firmware for the JetPack 4.6 (as downloaded from Firmware – Auvidea) and followed the instructions to flash (both simple and advanced with sdkmanager). I also tried to use a pin to force recovery (shorting pin 7 and 8 of J32). The flash keeps failing with the following messages:
[ 1.7342 ] Boot Rom communication
[ 1.7374 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 1.7393 ] BR_CID: 0x818010016465f1c10800000007fc8380
[ 1.7671 ] RCM version 0X180001
[ 1.8112 ] Boot Rom communication completed
[ 2.8180 ]
[ 3.8225 ] tegrarcm_v2 --isapplet
[ 1009.6334 ]
[ 1009.6376 ] tegradevflash_v2 --iscpubl
[ 1009.6391 ] CPU Bootloader is not running on device.
The dmesg on host shows the following error:
[ 94.951901] usb 2-1.6: new high-speed USB device number 5 using ehci-pci
[ 95.060989] usb 2-1.6: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[ 95.060992] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 95.060994] usb 2-1.6: Product: APX
[ 95.060995] usb 2-1.6: Manufacturer: NVIDIA Corp.
[ 296.205548] usb 2-1.6: USB disconnect, device number 5
[ 296.427167] usb 2-1.6: new high-speed USB device number 6 using ehci-pci
[ 296.536430] usb 2-1.6: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[ 296.536433] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 296.536435] usb 2-1.6: Product: APX
[ 296.536436] usb 2-1.6: Manufacturer: NVIDIA Corp.
[ 296.536438] usb 2-1.6: SerialNumber: 00000
[ 484.321200] INFO: task tegrarcm_v2:2702 blocked for more than 120 seconds.
[ 484.321205] Not tainted 5.4.0-150-generic #167~18.04.1-Ubuntu
[ 484.321207] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 484.321209] tegrarcm_v2 D 0 2702 2558 0x20020000
[ 484.321212] Call Trace:
[ 484.321220] __schedule+0x293/0x740
I am NOT receiving any signal from UART for debug (tried both from JST-GH connector and from GPIO pins 6,8,10) using a baud rate of 115200.
I am basically stuck, can anyone suggest how to solve or what try next?
Many thanks
Sasha
