Jetson tx2 flashing problem
the error I received while performing the flash operation
i deleted the software in it, I will install it again, but the
ubuntu account still appears when I open it without the sd card
i enter recovery mode while performing the operation
19:17:33 ERROR: Flash Jetson TX2 - flash: Error: Return value 19
19:17:33 INFO: Flash Jetson TX2 - flash: Command tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
19:17:33 ERROR: Flash Jetson TX2 - flash: — Error: Reading board information failed.
19:17:33 INFO: Flash Jetson TX2 - flash: [ Component Install Finished with Error ]
19:17:33 INFO: Flash Jetson TX2 - flash: [host] [ 184.00 KB used. Disk Avail: 167.03 GB ]
19:17:33 INFO: Flash Jetson TX2 - flash: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 0s ]
19:17:33 ERROR: Flash Jetson TX2 - flash: command terminated with error
19:17:33 SUMMARY: Flash Jetson TX2 - flash: First Error: Installation failed.
19:17:33 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
19:17:33 SUMMARY: Multimedia API - target: Depends on failed component
19:17:33 SUMMARY: TensorRT on Target - target: Depends on failed component
19:17:33 SUMMARY: VisionWorks on Target - target: Depends on failed component
19:17:33 SUMMARY: VPI on Target - target: Depends on failed component
19:17:33 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
19:17:33 SUMMARY: cuDNN on Target - target: Depends on failed component
19:17:33 SUMMARY: OpenCV on Target - target: Depends on failed component
Is it a custom carrier board or devkit?
Which JetPack version you want to install?
Are you on VM or native Ubuntu 18.04 host PC?
But your previous desctiption said you’re flash with TX2?
Which one is correct?
