Jetpack 4.5.1 Linux for Jetson TX2 installation failed
I use SDKmanager1.6.0 on host ubuntu 18.04 to flash jetpack on jetson tx2 P3310-1000 module P2597-0000 carrier board,then I meet the problem.
15:04:30 INFO: Flash Jetson TX2 - flash: [ 1.1360 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
15:04:30 INFO: Flash Jetson TX2 - flash: [ 1.1390 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
15:04:30 INFO: Flash Jetson TX2 - flash: [ 1.1400 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
15:04:35 INFO: Flash Jetson TX2 - flash: [ 1.2042 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
15:04:36 INFO: Flash Jetson TX2 - flash: [ 7.3316 ] tegrarcm_v2 --isapplet
15:04:36 INFO: Flash Jetson TX2 - flash: [ 7.3384 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
15:04:36 INFO: Flash Jetson TX2 - flash: [ 7.3576 ] Sending bct_bootrom
15:21:23 INFO: Flash Jetson TX2 - flash: Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
15:21:23 ERROR: Flash Jetson TX2 - flash: command terminated with error
15:21:24 SUMMARY: Device Mode Host Setup in Target SDK - target: Depends on failed component
I’ve tried many time but still failed,so what should I do?Thanks for anyone’s help.
Hello @chant223
could you please let me know the part number of your module and the Jetpack version you have been trying to flash?
Soved by myself.
Has it been solved? Were you able to successfully flash the device?
Yes,the above error is due to the fact that I started the forced recovery mode according to the paper instructions in the purchase kit. I followed the TX2 developer kit user guide downloaded from NVIDIA’s website, and it was no problem.
