Hi, I’m trying to install on my tx2 using sdk manager but I get the following error when it’s in the image flashing stage, everything was downloaded correctly.
19:45:35 ERROR: Flash Jetson TX2 - flash: log = print_process(process, enable_print)
19:45:35 ERROR: Flash Jetson TX2 - flash: command terminated with error
19:45:35 SUMMARY: DateTime Target Setup - target: Depends on failed component
19:51:03 SUMMARY: NVIDIA Insight Systems - host: Install completed successfully.
19:54:43 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
20:18:28 SUMMARY: File System and OS - target_image: Install completed successfully.
12:25:50 SUMMARY: DateTime Target Setup - target: Depends on failed component
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Sorry for the late response, is this still an issue to support? Thanks
