I’m trying to flash the Jetson TX2 NX and it fails. I’m using the SDK Manager GUI on a virtual machine。
In the terminal, I get this error early in the process。
SDKM_logs_JetPack_4.6.3_Linux_for_Jetson_TX2_modules_2023-03-29_19-00-59.zip (122.1 KB)
kayccc
March 30, 2023, 2:23am
3
zhangm_job:
This is not suggested, please find a native Ubuntu host PC.
Hi zhangm_job,
Please help to get a standalone Ubuntu 18.04 PC for SDK Manager.
Are you using Jetson TX2 or Jetson Xavier NX ?
(The topic is in TX2 category, but you mention that you are flashing Xavier NX?)
Is that the devkit from NVIDIA or custom board?
I’ll try it on my local Ubuntu computer later.
Hello!
I have flashed it on a native Ubuntu host PC and still failed !
17:51:46 INFO: Device info before flashing: Jetson TX2 NX | 001/006 | 1-4 | Recovery
17:51:46 DEBUG: running command < true >
17:51:46 INFO: command finished successfully
17:51:46 DEBUG: running command < /tmp/device_mode_host_setup.sh >
17:51:46 INFO: exec_command: /tmp/device_mode_host_setup.sh
17:51:46 INFO: net.ipv4.ip_forward = 1
17:52:01 INFO: Default google DNS is not working, trying to find a valid server in local host settings!
17:52:01 INFO: Device mode on host successfully set with DNS 192.168.104.1!
17:52:01 INFO: command finished successfully
17:52:01 DEBUG: running command < true >
17:52:01 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS to /home/zhangm/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS
17:52:01 INFO: Flash Jetson TX2 - flash: [OEMPreconfig] SDKM_INSTALL_ERROR Password for L4T new user hebin:
17:52:01 INFO: Flash Jetson TX2 - flash: *** Checking ONLINE mode … OK.
17:52:01 INFO: Flash Jetson TX2 - flash: *** Checking target board connection … 1 connections found.
17:52:07 ERROR: Flash Jetson TX2 - flash: Put the target board in RCM mode and retry.
17:52:07 ERROR: Flash Jetson TX2 - flash: command terminated with error
17:52:07 SUMMARY: DateTime Target Setup - target: Depends on failed component
SDKM_logs_JetPack_4.6.3_Linux_for_Jetson_TX2_modules_2023-03-30_17-47-16.zip (94.6 KB)
Do you put the board in force recovery mode before flash?
I found there is an error about ECID.
17:52:01.934 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS: *** Checking target board connection ... 1 connections found.
17:52:07.039 - error: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS: *** Reading ECID ... SDKM_INSTALL_ERROR *** Error: ECID read failed.
Please check if the following thread could help.
Unable to flash Xavier AGX with SDK because of *** Reading ECID … *** Error: ECID read failed - Jetson & Embedded Systems / Jetson AGX Xavier - NVIDIA Developer Forums
Today,I use a local host machine with Ubuntu 18.4.
when i use the command
sudo ./flash.sh jetson-xavier-nx-devkit-tx2-nx mmcblk0p1
I have meet some mistakes like these.
log20230331.txt (12.2 KB)
Please refer to the following instruction to setup and flash your devkit.
NVIDIA Jetson Linux Developer Guide : Quick Start | NVIDIA Docs
Have you finished the following steps?
Enter these commands to untar the files and assemble the rootfs:
$ tar xf ${L4T_RELEASE_PACKAGE}
$ cd Linux_for_Tegra/rootfs/
$ sudo tar xpf ../../${SAMPLE_FS_PACKAGE}
$ cd ..
$ sudo ./apply_binaries.sh
thank you ,i have forgot the comand sudo ./apply_binaries.sh。
system
Closed
April 25, 2023, 8:01am
14
