I can not flash my Jetson Xavier developer kit with the SDK manager. I have following errors.
12:37:57 INFO: Flash Jetson AGX Xavier - flash: [OEMPreconfig] SDKM_INSTALL_ERROR Password for L4T new user vizbot:
12:37:57 INFO: Flash Jetson AGX Xavier - flash: *** Checking ONLINE mode … OK.
12:37:57 INFO: Flash Jetson AGX Xavier - flash: *** Checking target board connection … 1 connections found.
12:37:57 INFO: Flash Jetson AGX Xavier - flash: *** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x19 bootauth=NS
12:37:57 INFO: Flash Jetson AGX Xavier - flash: “/home/noriaki/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x19 --applet “/home/noriaki/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin; reboot recovery”
12:37:57 INFO: Flash Jetson AGX Xavier - flash: [ 0.0155 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/noriaki/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
12:37:57 INFO: Flash Jetson AGX Xavier - flash: [ 0.0169 ] Header already present for /home/noriaki/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
12:37:57 INFO: Flash Jetson AGX Xavier - flash: [ 0.0248 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
12:37:57 INFO: Flash Jetson AGX Xavier - flash: [ 0.0287 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/noriaki/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
12:37:57 INFO: Flash Jetson AGX Xavier - flash: [ 0.0342 ] Assuming zero filled SBK key
12:37:57 INFO: Flash Jetson AGX Xavier - flash: [ 0.0481 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
12:37:57 INFO: Flash Jetson AGX Xavier - flash: [ 0.0521 ] RCM version 0X190001
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.0945 ] tegrarcm_v2 --isapplet
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.1553 ] tegrarcm_v2 --ismb2
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.2240 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.2304 ] adding BCH for nvtboot_applet_t194_aligned.bin
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.2415 ] Assuming zero filled SBK key
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.2431 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.2518 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.3058 ] Sending mb2
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.3059 ] […] 100%
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.3245 ] tegrarcm_v2 --boot recovery
12:37:59 INFO: Flash Jetson AGX Xavier - flash: [ 2.3251 ] Applet version 01.00.0000
12:38:00 INFO: Flash Jetson AGX Xavier - flash: [ 3.3837 ] tegrarcm_v2 --isapplet
12:38:00 INFO: Flash Jetson AGX Xavier - flash: [ 3.4404 ] tegrarcm_v2 --ismb2
12:38:00 INFO: Flash Jetson AGX Xavier - flash: [ 3.5052 ] tegrarcm_v2 --ismb2
12:38:00 INFO: Flash Jetson AGX Xavier - flash: [ 3.5770 ] MB2 Applet version 01.00.0000
12:38:00 INFO: Flash Jetson AGX Xavier - flash: [ 3.6384 ] Chip Sample: non es
12:38:01 INFO: Flash Jetson AGX Xavier - flash: [ 3.6401 ] MB2 Applet version 01.00.0000
12:38:01 INFO: Flash Jetson AGX Xavier - flash: [ 3.7389 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/noriaki/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
12:38:01 INFO: Flash Jetson AGX Xavier - flash: [ 3.7404 ] Header already present for /home/noriaki/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
12:38:01 INFO: Flash Jetson AGX Xavier - flash: [ 3.7536 ] RCM 1 is saved as rcm_1.rcm
12:38:01 INFO: Flash Jetson AGX Xavier - flash: [ 3.7652 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
12:38:06 INFO: Flash Jetson AGX Xavier - flash: [ 3.7685 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.0710 ] tegrarcm_v2 --isapplet
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.1311 ] tegrarcm_v2 --ismb2
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.1960 ] tegrarcm_v2 --ismb2
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.2625 ] MB2 Applet version 01.00.0000
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.3300 ] Chip sku: 0xd0
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.3300 ] Chip Sample: non es
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.3307 ] tegrarcm_v2 --oem platformdetails eeprom cvb /home/noriaki/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.3314 ] MB2 Applet version 01.00.0000
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.4289 ] tegrarcm_v2 --ismb2
12:38:07 INFO: Flash Jetson AGX Xavier - flash: [ 10.4887 ] MB2 Applet version 01.00.0000
12:38:09 INFO: Flash Jetson AGX Xavier - flash: [ 10.5586 ]
12:38:09 INFO: Flash Jetson AGX Xavier - flash: Parsing baseboard EEPROM:
12:38:09 INFO: Flash Jetson AGX Xavier - flash: — Parsing board version (700) succeeded.
12:38:09 ERROR: Flash Jetson AGX Xavier - flash: command terminated with error
12:38:09 SUMMARY: DateTime Target Setup - target: Depends on failed component
My host is Ubuntu 18.04. My Xavier is in recovery mode. The USB cable is connected from the Xavier to my PC. I tried to change the USB port and cable. However, same issue occurs.
Could you help me??
Thank you.
