We have created our own broad for the Tegra TX2. I don’t know how to install intel i210 driver on TX2. We need more information to hang up intel i210. Does nvidia provide any pcie on jetson TX2? I use lspci can not find any pci-e.
20190816TX2_log.txt (84.3 KB)
aesinfo,
I don’t know what is your exact problem here.
So you have a custom carrier board for TX2
Yes, TX2 has a pcie port on devkit, but we don’t know about your board design.
If you mean your board cannot detect the pcie device,
could you put your i210 device on our devkit first and see if lspci and see it?
If it can, please share the dmesg from your custom board. Thanks.
Hi WayneWWW
Debug message from custom board
[0000.100] C> block index = (4) and rail_id = (1)
[0000.104] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.221] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-c4328dc3)
[0000.230] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.234] I> DMA Heap @ [0x85200000 - 0x86200000]
[0000.239] I> bit @ 0xd480000
[0000.242] I> BR-BCT relocated to 0xd7020000
[0000.246] I> Boot-device: eMMC
[0000.250] I> sdmmc bdev is already initialized
[0000.254] I> pmic: reset reason (nverc) : 0x80
[0000.259] I> Reading GPT from 512 for device 00000003
[0000.265] I> Reading GPT from 8388096 for device 00000003
[0000.272] I> Found 13 partitions in 00000003 device
[0000.277] I> Reading GPT from 512 for device 00010003
[0000.283] I> Found 29 partitions in 00010003 device
[0000.289] W> No valid slot number is found in scratch register
[0000.294] W> Return default slot: _a
[0000.298] I> A/B: bin_type (16) slot 0
[0000.301] I> Loading partition bpmp-fw at 0xd7800000
[0000.306] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.312] I> Addr: 0xd7800000, start-block: 58761217, num_blocks: 1
[0000.327] I> Binary(16) of size 529040 is loaded @ 0xd7800000
[0000.332] W> No valid slot number is found in scratch register
[0000.338] W> Return default slot: _a
[0000.341] I> A/B: bin_type (17) slot 0
[0000.345] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.350] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.356] I> Addr: 0xd79f0000, start-block: 58763633, num_blocks: 1
[0000.369] I> Binary(17) of size 465760 is loaded @ 0xd798e200
[0000.548] I> BPMP-FW load address = 0xd7800000
[0000.553] I> BPMP-FW DTB load address = 0x5018e200
[0000.557] I> Loading SCE-FW …
[0000.560] W> No valid slot number is found in scratch register
[0000.566] W> Return default slot: _a
[0000.570] I> A/B: bin_type (12) slot 0
[0000.573] I> Loading partition sce-fw at 0xd7300000
[0000.578] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.583] I> Addr: 0xd7300000, start-block: 58765633, num_blocks: 1
[0000.592] I> Binary(12) of size 76592 is loaded @ 0xd7300000
[0000.598] I> Init SCE
[0000.600] I> Copy BTCM section
[0000.603] W> No valid slot number is found in scratch register
[0000.609] W> Return default slot: _a
[0000.612] I> A/B: bin_type (13) slot 0
[0000.616] I> Loading partition cpu-bootloader at 0x96000000
[0000.621] I> Reading two headers - addr:0x96000000 blocks:1
[0000.627] I> Addr: 0x96000000, start-block: 58740737, num_blocks: 1
[0000.638] I> Binary(13) of size 282736 is loaded @ 0x96000000
[0000.644] W> No valid slot number is found in scratch register
[0000.649] W> Return default slot: _a
[0000.653] I> A/B: bin_type (20) slot 0
[0000.656] I> Loading partition bootloader-dtb at 0x8520f400
[0000.662] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.667] I> Addr: 0x8520f400, start-block: 58742785, num_blocks: 1
[0000.678] I> Binary(20) of size 268320 is loaded @ 0x8520f400
[0000.684] I> MB2-params(VA) @ 0xd7000000
[0000.688] I> CPUBL-params(VA) @ 0xd7000000
[0000.692] I> CPUBL-params¶ @ 0x277000000
[0000.696] I> CPU-BL loaded @ PA 0x96000000
[0000.700] I> Loading TOS …
[0000.703] W> No valid slot number is found in scratch register
[0000.708] W> Return default slot: _a
[0000.712] I> A/B: bin_type (14) slot 0
[0000.715] I> Loading partition secure-os at 0x8530f600
[0000.720] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.726] I> Addr: 0x8530f600, start-block: 58744833, num_blocks: 1
[0000.734] I> Binary(14) of size 62576 is loaded @ 0x8530f600
[0000.740] I> Copying Monitor (length: 0xf270) from 0x8530f800 to 0x40000000
[0000.747] I> Erasing Monitor @ 0x8530f800
[0000.752] I> Unhalting SCE
[0000.754] I> Primary Memory Start:80000000 Size:70000000
[0000.759] I> Extended Memory Start:f0110000 Size:185ef0000
[0000.766] I> Waypoint2-ACK: 0x52012714
[0000.770] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.2(release):e1e4477
NOTICE: BL31: Built : 00:08:30, May 17 2018
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0001.011] I> Welcome to Cboot
[0001.014] I> Cboot Version: 00.00.2014.50-t186-0c600f85
[0001.019] I> CPU-BL Params @ 0x277000000
[0001.022] I> 0) Base:0x00000000 Size:0x00000000
[0001.027] I> 1) Base:0x277f00000 Size:0x00100000
[0001.031] I> 2) Base:0x277e00000 Size:0x00100000
[0001.036] I> 3) Base:0x277d00000 Size:0x00100000
[0001.040] I> 4) Base:0x277c00000 Size:0x00100000
[0001.045] I> 5) Base:0x277b00000 Size:0x00100000
[0001.049] I> 6) Base:0x277800000 Size:0x00200000
[0001.054] I> 7) Base:0x277400000 Size:0x00400000
[0001.059] I> 8) Base:0x277a00000 Size:0x00100000
[0001.063] I> 9) Base:0x277300000 Size:0x00100000
[0001.068] I> 10) Base:0x276800000 Size:0x00800000
[0001.072] I> 11) Base:0x30000000 Size:0x00040000
[0001.077] I> 12) Base:0xf0000000 Size:0x00100000
[0001.081] I> 13) Base:0x30040000 Size:0x00001000
[0001.085] I> 14) Base:0x30048000 Size:0x00001000
[0001.090] I> 15) Base:0x30049000 Size:0x00001000
[0001.094] I> 16) Base:0x3004a000 Size:0x00001000
[0001.099] I> 17) Base:0x3004b000 Size:0x00001000
[0001.103] I> 18) Base:0x3004c000 Size:0x00001000
[0001.108] I> 19) Base:0x3004d000 Size:0x00001000
[0001.112] I> 20) Base:0x3004e000 Size:0x00001000
[0001.116] I> 21) Base:0x3004f000 Size:0x00001000
[0001.121] I> 22) Base:0x00000000 Size:0x00000000
[0001.125] I> 23) Base:0xf0100000 Size:0x00010000
[0001.130] I> 24) Base:0x00000000 Size:0x00000000
[0001.134] I> 25) Base:0x00000000 Size:0x00000000
[0001.139] I> 26) Base:0x00000000 Size:0x00000000
[0001.143] I> 27) Base:0x00000000 Size:0x00000000
[0001.147] I> 28) Base:0x84400000 Size:0x00400000
[0001.152] I> 29) Base:0x30000000 Size:0x00010000
[0001.156] I> 30) Base:0x278000000 Size:0x08000000
[0001.161] I> 31) Base:0x00000000 Size:0x00000000
[0001.165] I> 32) Base:0x276000000 Size:0x00600000
[0001.170] I> 33) Base:0x80000000 Size:0x70000000
[0001.174] I> 34) Base:0xf0110000 Size:0x185ef0000
[0001.179] I> 35) Base:0x00000000 Size:0x00000000
[0001.183] I> 36) Base:0x00000000 Size:0x00000000
[0001.188] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.192] I> 38) Base:0x84000000 Size:0x00400000
[0001.197] I> 39) Base:0x96000000 Size:0x02400000
[0001.201] I> 40) Base:0x85000000 Size:0x01200000
[0001.205] I> 41) Base:0x277000000 Size:0x00280000
[0001.210] I> 42) Base:0x00000000 Size:0x00000000
[0001.214] I> 43) Base:0x00000000 Size:0x00000000
[0001.219] GIC-SPI Target CPU: 4
[0001.222] Interrupts Init done
[0001.225] calling constructors
[0001.229] initializing heap
[0001.231] initializing threads
[0001.235] initializing timers
[0001.238] creating bootstrap completion thread
[0001.243] top of bootstrap2()
[0001.246] CPU: ARM Cortex A57
[0001.249] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.254] initializing platform
[0001.257] I> Boot-device: eMMC
[0001.262] I> sdmmc bdev is already initialized
[0001.266] I> Reading GPT from 512 for device 00000003
[0001.272] I> Reading GPT from 8388096 for device 00000003
[0001.278] I> Found 13 partitions in 00000003 device
[0001.283] I> Reading GPT from 512 for device 00010003
[0001.289] I> Found 29 partitions in 00010003 device
[0001.294] W> opt-in fuse is not set, skip fuse_burning
[0001.298] I> Bl_dtb @0x8520f400
[0001.301] I> gpio framework initialized
[0001.305] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0001.313] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0001.320] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.329] E> i2c dev write failed
[0001.332] E> tca9539_device_init: failed to write polar reg
[0001.337] E> tegrabl_tca9539_init: failed to init device!
[0001.343] E> GPIO TCA9539 driver init failed
[0001.465] I> decompressor handler not found
[0001.472] I> fixed regulator driver initialized
[0001.509] I> register ‘maxim’ power off handle
[0001.515] I> virtual i2c enabled
[0001.518] I> registered ‘maxim,max77620’ pmic
[0001.522] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.533] I> Find /i2c@c250000’s alias i2c7
[0001.537] I> Reading eeprom i2c=7 address=0x50
[0001.568] I> Device at /i2c@c250000:0x50
[0001.572] I> Reading eeprom i2c=7 address=0x57
[0001.577] E> i2c dev read failed
[0001.580] E> eeprom: Failed to read I2C slave device
[0001.585] I> Eeprom read failed 0x1a89800d
[0001.590] I> Find /i2c@c240000’s alias i2c1
[0001.594] I> Reading eeprom i2c=1 address=0x51
[0001.601] E> i2c dev read failed
[0001.604] E> eeprom: Retry to read I2C slave device.
[0001.610] E> i2c dev read failed
[0001.613] E> eeprom: Failed to read I2C slave device
[0001.617] I> Eeprom read failed 0x1a89800d
[0001.622] I> Find /i2c@3160000’s alias i2c0
[0001.626] I> Reading eeprom i2c=0 address=0x50
[0001.631] E> i2c dev read failed
[0001.634] E> eeprom: Failed to read I2C slave device
[0001.639] I> Eeprom read failed 0x1a89800d
[0001.644] I> Find /i2c@3180000’s alias i2c2
[0001.648] I> Reading eeprom i2c=2 address=0x54
[0001.652] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.657] C> GPIO driver for chip_id 0x2 could not be found
[0001.662] E> cam_eeprom_read: Can’t get gpio driver
[0001.667] I> Eeprom read failed 0x2693400d
[0001.671] I> create_pm_ids: id: 3310-1000-D00-E, len: 15
[0001.676] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.691] I> found one nvdisp nodes at offset = 106020
[0001.696] I> found one nvdisp nodes at offset = 106936
[0001.706] I> enabling ‘vdd-hdmi’ regulator
[0001.710] C> GPIO driver for chip_id 0x3 could not be found
[0001.715] I> found one nvdisp nodes at offset = 107740
[0001.720] I> no valid display unit config found in dtb
[0001.725] W> display init failed
[0001.728] initializing target
[0001.732] calling apps_init()
[0001.735] starting app android_boot_app
[0001.739] I> Gpio keyboard init success
[0001.742] I> Kernel type = Normal
[0001.746] I> Loading kernel/boot.img from storage …
[0001.750] W> No valid slot number is found in scratch register
[0001.756] W> Return default slot: _a
[0001.760] I> A/B: bin_type (0) slot 0
[0001.763] I> Loading partition kernel at 0xa8000000
[0002.555] I> tegrabl_auth_payload: partition kernel (bin_type 0)
[0002.562] W> No valid slot number is found in scratch register
[0002.568] W> Return default slot: _a
[0002.571] I> A/B: bin_type (1) slot 0
[0002.575] I> Loading partition kernel-dtb at 0x92000000
[0002.587] I> tegrabl_auth_payload: partition kernel-dtb (bin_type 1)
[0002.594] I> Kernel DTB @ 0x92000000
[0002.597] I> Checking boot.img header magic … [0002.601] I> [OK]
[0002.603] I> Valid boot.img @ 0xa8000000
[0002.607] I> decompressor handler not found
[0002.611] I> Copying kernel image (488466 bytes) from 0xa8000800 to 0x80080000 … [0002.618] I> Done
[0002.620] I> Move ramdisk (len: 0) from 0xa8078000 to 0x9d000000
[0002.627] I> Updated bpmp info to DTB
[0002.633] I> Ramdisk: Base: 0x9d000000; Size: 0x0
[0002.637] I> Updated initrd info to DTB
[0002.641] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.648] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.656] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.663] I> disabled_core_mask: 0xffffff0c
[0002.667] W> No valid slot number is found in scratch register
[0002.672] W> Return default slot: _a
[0002.676] I> Active slot suffix:
[0002.679] I> add_boot_slot_suffix: slot_suffix =
[0002.684] I> add_serialno: Serial Num = 0421619045460
[0002.688] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlyc
[0002.727] I> Updated bootarg info to DTB
[0002.731] E> “plugin-manager” doesn’t exist, creating
[0002.736] E> “odm-data” doesn’t exist, creating
[0002.742] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:de:80:4f
[0002.748] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:de:80:50
[0002.754] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:de:80:51
[0002.760] E> “ids” doesn’t exist, creating
[0002.764] E> “connection” doesn’t exist, creating
[0002.769] E> “configs” doesn’t exist, creating
[0002.773] I> create_pm_ids: id: 3310-1000-D00-E, len: 15
[0002.778] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.789] I> Adding plugin-manager/ids/3310-1000-D00=/i2c@c250000:module@0x50
[0002.796] E> “i2c@c250000” doesn’t exist, creating
[0002.801] E> “module@0x50” doesn’t exist, creating
[0002.807] I> Adding plugin-manager/ids/3310-1000-D00-E
[0002.815] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.820] I> Adding plugin-manager/configs/3310-power-config 00
[0002.826] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.832] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.838] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.843] I> Adding plugin-manager/configs/3310-display-config 00
[0002.849] E> “chip-id” doesn’t exist, creating
[0002.854] I> Adding plugin-manager/chip-id/A02P
[0002.860] I> added [base:0x80000000, size:0x70000000] to /memory
[0002.866] I> added [base:0xf0200000, size:0x185e00000] to /memory
[0002.872] I> added [base:0x276600000, size:0x200000] to /memory
[0002.878] E> WARNING: Failed to pass NS DRAM ranges to TOS
[0002.883] I> Updated memory info to DTB
[0002.889] E> “reset” doesn’t exist, creating
[0002.893] E> “pmc-reset-reason” doesn’t exist, creating
[0002.898] E> “pmic-reset-reason” doesn’t exist, creating
[0002.904] I> disabled_core_mask: 0xffffff0c
[0002.915] I> Add serial number as DT property
[0002.920] I> tegrabl_load_kernel_and_dtb: Done
[0002.924] E> tegrabl_display_clear: display is not initialized
[0002.930] W> Boot logo display failed…
U-Boot 2016.07-g9c3b9a4 (May 17 2018 - 00:08:48 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
213 bytes read in 86 ms (2 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
20199936 bytes read in 541 ms (35.6 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x4
Flattened Device Tree blob at 92000000
Booting using the fdt blob at 0x92000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000092000000, end 00000000920467b7
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (johnnyli@ubuntu) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #1 SMP PREEMPT Mon Aug 12 19:42:10 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31128 r8192 d30312 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=14
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7976504K/8208384K available (11036K kernel code, 1770K rwdata, 5636K rodata, 1148K init, 679K bss, 166344K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
[ 0.000000] .init : 0xffffffc0010c9000 - 0xffffffc0011e8000 ( 1148 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0010c9000 ( 16676 KB)
[ 0.000000] .data : 0xffffffc001209000 - 0xffffffc0013c3a00 ( 1771 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.010315] Console: colour dummy device 80x25
[ 0.015033] console [tty0] enabled
[ 0.018601] bootconsole [uart0] disabled
[ 0.022718] kmemleak: Kernel memory leak detector disabled
[ 0.022743] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022760] pid_max: default: 32768 minimum: 301
[ 0.022841] Security Framework initialized
[ 0.022895] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022904] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023697] Initializing cgroup subsys freezer
[ 0.023719] Initializing cgroup subsys debug
[ 0.024120] CPU0 ipc=752
[ 0.024132] CPU1 ipc=1024
[ 0.024140] CPU2 ipc=1024
[ 0.024149] CPU3 ipc=752
[ 0.024158] CPU4 ipc=752
[ 0.024167] CPU5 ipc=752
[ 0.024243] ASID allocator initialised with 65536 entries
[ 0.053224] tegra-id: chipid=21817.
[ 0.053255] tegra-id: opt_subrevision=1.
[ 0.053267] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.054066] DTS File Name: /home/johnnyli/Build_TX2/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-10s
[ 0.054092] DTB Build time: Aug 12 2019 19:22:22
[ 0.074194] CPU1: Booted secondary processor [4e0f0030]
[ 0.087943] CPU2: Booted secondary processor [4e0f0030]
[ 0.099131] CPU3: Booted secondary processor [411fd073]
[ 0.111109] CPU4: Booted secondary processor [411fd073]
[ 0.123085] CPU5: Booted secondary processor [411fd073]
[ 0.123281] Brought up 6 CPUs
[ 0.123359] SMP: Total of 6 processors activated.
[ 0.123375] CPU: All CPU(s) started at EL2
[ 0.124509] devtmpfs: initialized
[ 0.159573] Initilizing CustomIPI irq domain
[ 0.160055] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.161931] pinctrl core: initialized pinctrl subsystem
[ 0.162459] OS set in device tree is not L4T.
[ 0.162899] regulator-dummy: no parameters
[ 0.163113] Initializing plugin-manager
[ 0.163201] Plugin module not found
[ 0.163632] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.164423] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.165084] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.166359] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.166832] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.167139] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.167374] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.167851] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.168345] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.168676] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.169063] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.169343] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.169607] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.169907] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.171976] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.174992] Adding domain adsp-pd to PM domain ape-pd
[ 0.179412] NET: Registered protocol family 16
[ 0.180907] console [pstore-1] enabled
[ 0.180929] pstore: Registered ramoops as persistent store backend
[ 0.180948] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.189559] cpuidle: using governor ladder
[ 0.195102] cpuidle: using governor menu
[ 0.198127] bpmp: waiting for handshake
[ 0.198156] bpmp: handshake completed
[ 0.198218] bpmp: synchronizing channels
[ 0.198256] bpmp: channels synchronized
[ 0.198272] bpmp: mail init ok
[ 0.198740] vdso: 2 pages (1 code @ ffffffc001211000, 1 data @ ffffffc001210000)
[ 0.198809] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.202711] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.205194] tegra_powergate_init: DONE
[ 0.205232] DTS File Name: /home/johnnyli/Build_TX2/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-10s
[ 0.205266] DTB Build time: Aug 12 2019 19:22:22
[ 0.207540] Tegra reboot handler registered.
[ 0.210937] Registering Tegra186 clocks (this may take a while)…done
[ 0.213494] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.213524] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.213546] arm-smmu 12000000.iommu: stage 1 translation
[ 0.213565] arm-smmu 12000000.iommu: stage 2 translation
[ 0.213583] arm-smmu 12000000.iommu: nested translation
[ 0.213605] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.213632] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.213658] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.213677] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.213694] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.258409] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.265976] iommu: Adding device 3460000.sdhci to group 0
[ 0.267037] iommu: Adding device 3400000.sdhci to group 1
[ 0.272871] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.273489] iommu: Adding device 3160000.i2c to group 3
[ 0.274001] iommu: Adding device c240000.i2c to group 4
[ 0.274386] iommu: Adding device 3180000.i2c to group 5
[ 0.274758] iommu: Adding device 3190000.i2c to group 6
[ 0.275199] iommu: Adding device 31b0000.i2c to group 7
[ 0.275527] iommu: Adding device 31c0000.i2c to group 8
[ 0.275888] iommu: Adding device c250000.i2c to group 9
[ 0.276295] iommu: Adding device 31e0000.i2c to group 10
[ 0.278487] iommu: Adding device 3210000.spi to group 11
[ 0.278906] iommu: Adding device c260000.spi to group 12
[ 0.279232] iommu: Adding device 3240000.spi to group 13
[ 0.280094] iommu: Adding device 3100000.serial to group 14
[ 0.280414] iommu: Adding device 3110000.serial to group 15
[ 0.280731] iommu: Adding device c280000.serial to group 16
[ 0.281104] iommu: Adding device 3130000.serial to group 17
[ 0.282429] iommu: Adding device 2490000.ether_qos to group 18
[ 0.283117] iommu: Adding device b000000.rtcpu to group 19
[ 0.283615] iommu: Adding device c1a0000.aon to group 20
[ 0.284604] Wake73 for irq=42
[ 0.284965] iommu: Adding device smmu_test to group 21
[ 0.285593] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.285639] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.285679] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.285758] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.285855] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.285901] mc-err: Set intmask: 0xf3140
[ 0.286370] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.287288] Wake76 for irq=199
[ 0.287314] Wake77 for irq=199
[ 0.287337] Wake78 for irq=199
[ 0.287358] Wake79 for irq=199
[ 0.287379] Wake80 for irq=199
[ 0.287400] Wake81 for irq=199
[ 0.287421] Wake82 for irq=199
[ 0.287550] iommu: Adding device 3530000.xhci to group 22
[ 0.287946] iommu: Adding device 3550000.xudc to group 23
[ 0.288955] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.288994] tegra-pmc: ### PMC reset source: Power on reset
[ 0.289021] tegra-pmc: ### PMC reset level: L0
[ 0.289044] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.289428] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.289471] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.289663] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.289696] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.290252] iommu: Adding device 13e10000.host1x to group 24
[ 0.290619] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.290935] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.291270] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.291581] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.291843] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.292148] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.292448] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.292802] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.293446] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.294755] iommu: Adding device 15700000.vi to group 34
[ 0.295184] iommu: Adding device 15600000.isp to group 35
[ 0.295535] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.295762] iommu: Adding device 15340000.vic to group 37
[ 0.296012] iommu: Adding device 154c0000.nvenc to group 38
[ 0.296329] iommu: Adding device 15480000.nvdec to group 39
[ 0.296657] iommu: Adding device 15380000.nvjpg to group 40
[ 0.296937] iommu: Adding device 15500000.tsec to group 41
[ 0.297141] iommu: Adding device 15100000.tsecb to group 42
[ 0.297930] iommu: Adding device 15810000.se to group 43
[ 0.298242] iommu: Adding device 15820000.se to group 44
[ 0.298530] iommu: Adding device 15830000.se to group 45
[ 0.298735] iommu: Adding device 15840000.se to group 46
[ 0.299312] iommu: Adding device 17000000.gp10b to group 47
[ 0.301165] tegra-reset 5000000.clock: registered 193 resets.
[ 0.303363] iommu: Adding device d000000.bpmp to group 48
[ 0.303735] bpmp: ping status is 0
[ 0.304102] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.304583] bpmp d000000.bpmp: probe ok
[ 0.307144] iommu: Adding device 2600000.dma to group 49
[ 0.308226] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.308325] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.308381] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.308432] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.308491] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.308552] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.308647] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.308774] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.311028] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.311155] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.312224] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.312630] iommu: Adding device sound to group 51
[ 0.314428] iommu: Adding device 3510000.hda to group 52
[ 0.315636] iommu: Adding device adsp_audio to group 53
[ 0.317081] iommu: Adding device 2993000.adsp to group 54
[ 0.330390] vdd-ac-bat: 5000 mV
[ 0.332960] vdd-1v8-ap: 1800 mV
[ 0.334547] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.334982] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.353770] SCSI subsystem initialized
[ 0.354600] usbcore: registered new interface driver usbfs
[ 0.354680] usbcore: registered new interface driver hub
[ 0.354846] usbcore: registered new device driver usb
[ 0.360314] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.361175] pca953x 0-0074: failed reading register
[ 0.361336] pca953x: probe of 0-0074 failed with error -121
[ 0.361832] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.362678] pca953x 0-0077: failed reading register
[ 0.362794] pca953x: probe of 0-0077 failed with error -121
[ 0.383361] media: Linux media interface: v0.10
[ 0.383469] Linux video capture interface: v2.00
[ 0.389291] pps_core: LinuxPPS API ver. 1 registered
[ 0.389336] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.389389] PTP clock support registered
[ 0.390961] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.391061] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.393682] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.396813] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.397086] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.397287] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.406422] vddio-ddr: at 1125 mV
[ 0.410177] avdd_dsi_csi: 1200 mV
[ 0.414175] vdd-1v8: 1800 mV
[ 0.418179] vdd-3v3-sys: 3300 mV
[ 0.419863] spmic-ldo0: at 1800 mV
[ 0.421189] spmic-ldo1: at 800 mV
[ 0.427086] vddio-3v3: 3300 mV
[ 0.427868] vddio-sdmmc1: 1800 ↔ 3300 mV at 3300 mV
[ 0.431085] vdd-rtc: at 800 mV
[ 0.432030] avdd-ts-hv: 1800 ↔ 3300 mV at 1800 mV
[ 0.435084] spmic-ldo6: at 1500 mV
[ 0.439084] vdd-pex-1v05: 1000 mV
[ 0.439844] dvdd-pex: 1000 mV
[ 0.440271] max77620 4-003c: max77620 probe successful
[ 0.441218] Advanced Linux Sound Architecture Driver Initialized.
[ 0.443431] en-vdd-sd: 3300 mV
[ 0.443861] vdd-usb0-5v: 5000 mV
[ 0.444096] vdd-usb1-5v: 5000 mV
[ 0.444608] vdd-3v3: 3300 mV
[ 0.444846] en-vdd-vcm-2v8: 2800 mV
[ 0.445050] vdd-sys-bl: 3300 mV
[ 0.449644] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.452098] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.452738] clocksource: Switched to clocksource arch_sys_counter
[ 0.489002] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.489941] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.491519] nvmap_page_pool_init: Total RAM pages: 2010510
[ 0.491569] nvmap_page_pool_init: nvmap page pool size: 251313 pages (981 MB)
[ 0.492037] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.498142] Wake76 for irq=199
[ 0.498159] Wake77 for irq=199
[ 0.498175] Wake78 for irq=199
[ 0.498189] Wake79 for irq=199
[ 0.498203] Wake80 for irq=199
[ 0.498215] Wake81 for irq=199
[ 0.498229] Wake82 for irq=199
[ 0.499710] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.499958] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.500110] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.500213] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.500728] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.500920] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.501109] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.501314] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.501778] isomgr_init(): iso emc max clk=0KHz
[ 0.501794] isomgr_init(): max_iso_bw=0KB
[ 0.501955] NET: Registered protocol family 2
[ 0.502590] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.502827] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.503925] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.504084] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.504158] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.504518] NET: Registered protocol family 1
[ 0.505361] RPC: Registered named UNIX socket transport module.
[ 0.505446] RPC: Registered udp transport module.
[ 0.505471] RPC: Registered tcp transport module.
[ 0.505495] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.505902] Trying to unpack rootfs image as initramfs…
[ 0.539754] host1x 13e10000.host1x: initialized
[ 0.542954] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.548620] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.548966] audit: initializing netlink subsys (disabled)
[ 0.549108] audit: type=2000 audit(0.536:1): initialized
[ 0.562179] io scheduler noop registered (default)
[ 0.568408] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.571469] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.573732] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.576030] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.587448] tsec 15500000.tsec: initialized
[ 0.590176] tsec 15100000.tsecb: initialized
[ 0.596132] nvdec 15480000.nvdec: initialized
[ 0.604848] falcon 15340000.vic: initialized
[ 0.607054] falcon 154c0000.nvenc: initialized
[ 0.609253] falcon 15380000.nvjpg: initialized
[ 0.611721] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.613100] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.614394] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.615784] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.617171] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.618461] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.619730] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.621103] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.625649] DC OR NODE connected to /host1x/sor1
[ 0.626325] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.626359] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.626476] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.626813] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.626866] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.626907] max_iso_bw is relaxed to 4687500KB from 0KB
[ 0.627048] ------------[ cut here ]------------
[ 0.627086] WARNING: at ffffffc0008784ac [verbose debug info unavailable]
[ 0.627107] Modules linked in:
[ 0.627135]
[ 0.627171] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.4.38 #1
[ 0.627194] Hardware name: quill (DT)
[ 0.627217] task: ffffffc1ece30000 ti: ffffffc1ece38000 task.ti: ffffffc1ece38000
[ 0.627268] PC is at __tegra_isomgr_register+0x424/0x518
[ 0.627292] LR is at __tegra_isomgr_register+0x424/0x518
[ 0.627335] pc : [] lr : [] pstate: 60000045
[ 0.627375] sp : ffffffc1ece3bb00
[ 0.627402] x29: ffffffc1ece3bb00 x28: 0000000000000384
[ 0.627440] x27: 0000000000000008 x26: ffffffc001453000
[ 0.627479] x25: ffffffc001453428 x24: 0000000000000000
[ 0.627515] x23: ffffffc001394000 x22: 0000000000000008
[ 0.627551] x21: ffffffc001453818 x20: 0000000000000000
[ 0.627609] x19: 000000000047868c x18: 0000000000000000
[ 0.627645] x17: 0000000000000001 x16: 00000000004b1af6
[ 0.627681] x15: 0000000000000010 x14: ffffffc0813cb38f
[ 0.627726] x13: ffffffc0013cb397 x12: 0000000000000006
[ 0.627767] x11: ffffffc1ece3b910 x10: 0000000005f5e0ff
[ 0.627808] x9 : 00000000ffffffd0 x8 : ffffffc0002ca958
[ 0.627858] x7 : ffffffc001254880 x6 : 000000000000003a
[ 0.627892] x5 : 0000000000000000 x4 : 0000000000000000
[ 0.627971] x3 : 0000000000000000 x2 : 0000000000000716
[ 0.628013] x1 : ffffffc1ece38000 x0 : 000000000000002b
[ 0.628049]
[ 0.628100] —[ end trace e0f2d262eca06a43 ]—
[ 0.628124] Call trace:
[ 0.628149] [] __tegra_isomgr_register+0x424/0x518
[ 0.628174] [] tegra_isomgr_register+0x24/0x30
[ 0.628211] [] tegra_camera_probe+0x290/0x4f8
[ 0.628247] [] platform_drv_probe+0x58/0xc0
[ 0.628278] [] driver_probe_device+0xcc/0x408
[ 0.628301] [] __driver_attach+0x9c/0xa0
[ 0.628325] [] bus_for_each_dev+0x64/0xa0
[ 0.628350] [] driver_attach+0x20/0x28
[ 0.628373] [] bus_add_driver+0x1d0/0x298
[ 0.628396] [] driver_register+0x60/0xf8
[ 0.628419] [] __platform_driver_register+0x48/0x50
[ 0.628448] [] tegra_camera_init+0x18/0x20
[ 0.628480] [] do_one_initcall+0xd0/0x1d8
[ 0.628515] [] kernel_init_freeable+0x1d4/0x278
[ 0.628552] [] kernel_init+0x10/0xe0
[ 0.628582] [] ret_from_fork+0x10/0x40
[ 0.628606] __tegra_isomgr_register(): ISO BW usage:
[ 0.628628] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 0.628649] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 0.628670] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 0.628754] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 0.628777] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=4687500KB
[ 0.628806] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=0KB
[ 0.628827] __tegra_isomgr_register(): client=eqos, iso dedi bw=0KB
[ 0.628848] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 0.643319] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.643362] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.644118] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 0.646729] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.648649] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.648745] PD DISP0 index2 UP
[ 0.650159] PD DISP1 index3 UP
[ 0.650270] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.650469] PD DISP2 index4 UP
[ 0.651151] kfuse 3830000.kfuse: initialized
[ 0.653421] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.654318] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.658728] console [ttyS0] disabled
[ 0.659009] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.680972] Unsupported HDMI VIC 64, ignoring
[ 0.680994] PD DISP2 index4 DOWN
[ 0.681336] PD DISP1 index3 DOWN
[ 0.681628] PD DISP0 index2 DOWN
[ 0.684546] tegradc 15210000.nvdisplay: probed
[ 2.982991] console [ttyS0] enabled
[ 2.987473] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.989303] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.989599] serial-tegra 3130000.serial: RX in PIO mode
[ 2.991237] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.995428] Console: switching to colour frame buffer device 240x67
[ 3.005555] brd: module loaded
[ 3.011036] loop: module loaded
[ 3.011819] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.011848] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 3.011852] nct1008_nct72 7-004c: starting parse dt
[ 3.011987] nct1008_nct72 7-004c: success parsing dt
[ 3.012307] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 3.029121] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 3.049724] tmp451: Enabled overheat logging at 104.00C
[ 3.049950] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.050010] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 3.053484] THERMAL EST: found 3 subdevs
[ 3.053490] THERMAL EST num_resources: 0
[ 3.053495] [THERMAL EST subdev 0]
[ 3.053503] [THERMAL EST subdev 1]
[ 3.053507] [THERMAL EST subdev 2]
[ 3.053936] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 3.053941] THERMAL EST: thz register success.
[ 3.054236] THERMAL EST: end of probe, return err: 0
[ 3.054459] tegra_profiler: Branch: Dev
[ 3.054463] tegra_profiler: Version: 1.109
[ 3.054465] tegra_profiler: Samples version: 37
[ 3.054467] tegra_profiler: IO version: 21
[ 3.054483] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.054494] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.054499] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.054505] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 3.054511] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.054514] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 3.054518] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.054521] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.054526] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.054529] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.054534] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.054537] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.054827] tegra_profiler: auth: init
[ 3.060361] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.060378] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.061930] scsi host0: tegra_ahci
[ 3.062545] scsi host1: tegra_ahci
[ 3.062694] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 3.062698] ata2: DUMMY
[ 3.064081] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.064774] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.065387] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.066619] tun: Universal TUN/TAP device driver, 1.6
[ 3.066623] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.066919] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.066922] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.067026] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 3.067029] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.069284] PPP generic driver version 2.4.2
[ 3.069462] PPP BSD Compression module registered
[ 3.069471] PPP Deflate Compression module registered
[ 3.069518] PPP MPPE Compression module registered
[ 3.069534] NET: Registered protocol family 24
[ 3.069611] usbcore: registered new interface driver r8152
[ 3.069675] usbcore: registered new interface driver asix
[ 3.069706] usbcore: registered new interface driver ax88179_178a
[ 3.069736] usbcore: registered new interface driver cdc_ether
[ 3.069777] usbcore: registered new interface driver smsc95xx
[ 3.069809] usbcore: registered new interface driver net1080
[ 3.069866] usbcore: registered new interface driver cdc_subset
[ 3.069895] usbcore: registered new interface driver zaurus
[ 3.069956] usbcore: registered new interface driver cdc_ncm
[ 3.070375] Wake76 for irq=199
[ 3.070378] Wake77 for irq=199
[ 3.070380] Wake78 for irq=199
[ 3.070382] Wake79 for irq=199
[ 3.070383] Wake80 for irq=199
[ 3.070385] Wake81 for irq=199
[ 3.070386] Wake82 for irq=199
[ 3.070465] tegra-xotg xotg: usb2 phy is not available yet
[ 3.071044] usbcore: registered new interface driver usb-storage
[ 3.071141] usbcore: registered new interface driver usbserial
[ 3.071174] usbcore: registered new interface driver ftdi_sio
[ 3.071202] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.071229] usbcore: registered new interface driver option
[ 3.071253] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.071279] usbcore: registered new interface driver pl2303
[ 3.071298] usbserial: USB Serial support registered for pl2303
[ 3.071579] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.077289] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b de 80 51
[ 3.078261] libphy: dwc_phy: probed
[ 3.078300] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 3.141802] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 3.141982] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.142955] max_iso_bw is relaxed to 4769420KB from 4687500KB
[ 3.142956] ------------[ cut here ]------------
[ 3.142960] WARNING: at ffffffc0008784ac [verbose debug info unavailable]
[ 3.142965] Modules linked in:
[ 3.142965]
[ 3.142976] CPU: 5 PID: 149 Comm: kworker/u12:3 Tainted: G W 4.4.38 #1
[ 3.142979] Hardware name: quill (DT)
[ 3.143006] Workqueue: events_unbound async_run_entry_fn
[ 3.143009] task: ffffffc059365780 ti: ffffffc1e6054000 task.ti: ffffffc1e6054000
[ 3.143025] PC is at __tegra_isomgr_register+0x424/0x518
[ 3.143028] LR is at __tegra_isomgr_register+0x424/0x518
[ 3.143031] pc : [] lr : [] pstate: 80000045
[ 3.143032] sp : ffffffc1e6057a80
[ 3.143037] x29: ffffffc1e6057a80 x28: 0000000000000464
[ 3.143040] x27: 000000000000000a x26: ffffffc001453000
[ 3.143044] x25: ffffffc001453428 x24: 0000000000000000
[ 3.143046] x23: ffffffc001394000 x22: 000000000000000a
[ 3.143049] x21: ffffffc0014538f8 x20: 0000000000000000
[ 3.143051] x19: 0000000000014000 x18: 0000000000000000
[ 3.143053] x17: 0000000000000001 x16: 0000000000000007
[ 3.143056] x15: 0000000000000001 x14: ffffffc0013cbbb8
[ 3.143058] x13: ffffffc0013cb800 x12: 0000000000000007
[ 3.143060] x11: 0000000000000400 x10: 0000000005f5e0ff
[ 3.143063] x9 : ffffffc1e60579e0 x8 : 206d6f726620424b
[ 3.143065] x7 : 3032343936373420 x6 : ffffffc0013cb7d8
[ 3.143067] x5 : 0000000000000000 x4 : 0000000000000000
[ 3.143070] x3 : 0000000000000040 x2 : 00000000000003f4
[ 3.143072] x1 : ffffffc1e6054000 x0 : 0000000000000031
[ 3.143073]
[ 3.143074] —[ end trace e0f2d262eca06a44 ]—
[ 3.143078] Call trace:
[ 3.143081] [] __tegra_isomgr_register+0x424/0x518
[ 3.143085] [] tegra_isomgr_register+0x24/0x30
[ 3.143099] [] eqos_probe+0xa94/0x1238
[ 3.143111] [] platform_drv_probe+0x58/0xc0
[ 3.143122] [] driver_probe_device+0xcc/0x408
[ 3.143126] [] __driver_attach+0x9c/0xa0
[ 3.143132] [] bus_for_each_dev+0x64/0xa0
[ 3.143136] [] driver_attach+0x20/0x28
[ 3.143140] [] driver_attach_async+0x14/0x58
[ 3.143142] [] async_run_entry_fn+0x40/0x168
[ 3.143149] [] process_one_work+0x1d0/0x4b8
[ 3.143150] [] worker_thread+0x124/0x490
[ 3.143157] [] kthread+0xe0/0xf8
[ 3.143169] [] ret_from_fork+0x10/0x40
[ 3.143171] __tegra_isomgr_register(): ISO BW usage:
[ 3.143174] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 3.143177] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 3.143179] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 3.143182] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 3.143186] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=4687500KB
[ 3.143188] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=0KB
[ 3.143191] __tegra_isomgr_register(): client=eqos, iso dedi bw=81920KB
[ 3.143192] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 3.212928] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.215769] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.215810] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.216067] i2c /dev entries driver
[ 3.217329] gspca_main: v2.14.0 registered
[ 3.217453] usbcore: registered new interface driver gspca_zc3xx
[ 3.217889] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.220764] FAN: coudln’t get the regulator
[ 3.221665] device-mapper: uevent: version 1.0.3
[ 3.221992] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.222617] sdhci: Secure Digital Host Controller Interface driver
[ 3.222618] sdhci: Copyright(c) Pierre Ossman
[ 3.222624] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.223160] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.223736] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.224489] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.224695] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.224962] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.227049] usbcore: registered new interface driver usbhid
[ 3.227050] usbhid: USB HID core driver
[ 3.229784] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 3.230558] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 3.230731] ina3221x: probe of 0-0042 failed with error -121
[ 3.231160] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 3.231823] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 3.231925] ina3221x: probe of 0-0043 failed with error -121
[ 3.232591] nvadsp 2993000.adsp: in probe()…
[ 3.234231] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.234277] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.234577] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.248225] Denver: backdoor interface is NOT available.
[ 3.251029] coresight-tmc 8030000.etf: TMC initialized
[ 3.254875] coresight-tmc 8050000.etr: TMC initialized
[ 3.255544] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.256322] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.257007] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.257650] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.258229] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.259131] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.259894] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.260670] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.261466] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.261507] Module initialized successfully
[ 3.264744] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.265367] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.265871] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.266859] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.270458] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.270880] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.271448] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.271508] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.271562] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.271611] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.271679] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.271725] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.271766] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.271949] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.271952] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.272805] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.272808] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.272811] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.272814] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.272817] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.272820] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.272822] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.272862] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.278932] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.280111] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.280240] camchar: rtcpu character device driver loaded
[ 3.287907] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.288569] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.289031] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.290129] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.290165] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.290209] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.290248] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.290284] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.290317] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.290352] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.290389] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.290426] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.290464] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.290520] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.290555] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.290593] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.290629] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.290665] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.290736] **** A57 ECC: Enabled
[ 3.290739] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 3.290919] parse_throttle_dt_data: Num cap clks = 4
[ 3.290928] parse_throttle_dt_data: clk=mcpu type=1
[ 3.290930] parse_throttle_dt_data: clk=bcpu type=2
[ 3.290946] parse_throttle_dt_data: clk=gpu type=4
[ 3.290948] parse_throttle_dt_data: clk=emc type=3
[ 3.291719] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.291850] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.292402] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.293242] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.304791] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.305438] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.305512] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.305619] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.305687] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.306236] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.306922] mmc0: MAN_BKOPS_EN bit is not set
[ 3.315597] mmc0: Skipping tuning since strobe enabled
[ 3.325142] mmc0: periodic cache flush enabled
[ 3.325157] mmc0: new HS400 MMC card at address 0001
[ 3.325728] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.325916] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.326080] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.326247] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.328119] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 3.348853] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 3.348928] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.369412] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.388748] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.570524] mmc1 tuning done saved tap delay=19
[ 3.570534] mmc1: hw tuning done …
[ 3.570564] mmc1: tuning_window[0]: 0xffffffff
[ 3.570571] mmc1: tuning_window[1]: 0xfffffc7f
[ 3.570579] mmc1: tuning_window[2]: 0xfff1ffff
[ 3.570585] mmc1: tuning_window[3]: 0x47ffffff
[ 3.570592] mmc1: tuning_window[4]: 0x0
[ 3.570599] mmc1: tuning_window[5]: 0x0
[ 3.570605] mmc1: tuning_window[6]: 0x0
[ 3.570612] mmc1: tuning_window[7]: 0x0
[ 3.570620] sdhci: Tap value: 19 | Trim value: 5
[ 3.570628] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.582184] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.582281] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.058796] tegradc 15210000.nvdisplay: fb registered
[ 5.065774] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 5.072335] PD DISP0 index2 UP
[ 5.078513] PD DISP1 index3 UP
[ 5.083354] PD DISP2 index4 UP
[ 5.089813] Parent Clock set for DC plld2
[ 5.101639] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 5.130577] tegra-se-nvhost 15810000.se: initialized
[ 5.145129] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 5.161072] tegra-se-nvhost 15820000.se: initialized
[ 5.175760] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 5.191964] tegra-se-nvhost 15830000.se: initialized
[ 5.206527] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 5.222734] tegra-se-nvhost 15840000.se: initialized
[ 5.230600] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 5.246454] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 5.255418] Unsupported HDMI VIC 64, ignoring
[ 5.270394] cpufreq
Please use a code block or attach your log. It has been truncated.
This is code block
[code][0000.097] C> I2C command failed
TEGRA186
DRAM: 7.8 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1…
1: primary kernel
Starting kernel …
[ 0.627135]
[ 0.628049]
[ 3.142965]
[ 3.143073]
[ 5.270394] cpufreq: platform dri
Sorry. Looks like it is too long even for code block. Please attach it.
The pcie driver is not loaded. Which release are you using?
TX2_Linux_for_Tegra_R28.1
Do you see anything in “lsmod” command?
Hi Wayny
nvidia@tegra-ubuntu:~$ lsmod
Module Size Used by
It is a common issue that since you use your own custom kernel. The kernel version does not match with the module folder name.
If you use command “uname -r”, the result would be probably “4.4.38”. After boot up, it would go to load the kernel modules under /lib/modules/4.4.38.
However, it does not exist because there is only /lib/modules/4.4.38-tegra.
A solution is add the tegra suffix during kenrel image compilation.
export LOCALVERSION=-tegra
make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
Hi Wayne
As u say , our kernel is 4.4.38
nvidia@tegra-ubuntu:~$ uname -r
4.4.38
I will try your solution and test.
thank you for your helping. I will let you know test result.
thank
