DSI to LVDS on jetson TX1
I am new to developing for the Jetson and I am trying to bring up a LVDS panel using a DSI to LVDS converter. I have mortified the panel-s-wuxga-8-0.dtsi to enable the panel and enable the DSI to LVDS converter. my code follows the same guidelines as below.
dsi {
			status = "okay";
			nvidia,dsi-controller-vs = <DSI_VS_1>;
			your panel {
				status = "okay";
				nvidia,dsi-lvds-bridge = <TEGRA_DSI_ENABLE>;
I have looked at the dsi2lvds.c file but I am not quite sure what to modify in it. Also what do I modify in board-panel.c?
Why do you mention board-panel.c? Is there anything that need to modify in it?
We don’t support dsi-lvds bridge. Maybe other forum user can share some experiences.
I am reading the “NVIDIA Tegra Linux Driver Package Development Guide 28.1 Release” document specifically in the page “Display Configuration and Bringup” in the section “Configuring the Display Serial Interface”. in this section it says to configure the DSI panel you must
“Set up the initialize/suspend sequence.
These are passed as device tree bindings in the power tree for the platform and read in the following file:
/kernel/display/drivers/video/tegra/dc/panel/board-panel.c”
so does this mean that I need to modify it?
it says in this post that I need to modify it as well.
https://devtalk.nvidia.com/default/topic/920663/jetson-tx1/jetson-tx1-dsc-of-mipi-dsi-/
“We don’t support dsi-lvds bridge. Maybe other forum user can share some experiences.”
I am referring to the following posts.
https://devtalk.nvidia.com/default/topic/1021619/jetson-tx1/dsi-display-on-the-tx1/
https://devtalk.nvidia.com/default/topic/1005979/about-dsi-display-port/?offset=1#5135790
Also there is a file called dsi2lvds.c in the kernel.
Hello Wayne,
The DSI to LVDS panel is not being brought up and my HDMI is not coming up as well because I have the DSI enabled. How should go about viewing the log files to see what is the error?
regards,
Michael
Please share your dmesg and xorg.0.log.
Here is the start up log the Jetson gets stuck at “Starting Kernel …”
[0000.180] [TegraBoot] (version 00.00.2014.50-mobile-d44d4bf0)
[0000.186] Processing in cold boot mode Bootloader 2
[0000.190] A02 Bootrom Patch rev = 63
[0000.194] Power-up reason: on button
[0000.197] No Battery Present
[0000.200] RamCode = 0
[0000.202] Platform has Ddr4 type ram
[0000.205] max77620 disabling SD1 Remote Sense
[0000.210] Setting Ddr voltage to 1125mv
[0000.214] Serial Number of Pmic Max77663: 0x201f4
[0000.221] Entering ramdump check
[0000.224] Get RamDumpCarveOut = 0xff23f000
[0000.228] RamDumpCarveOut=0xff23f000,  RamDumperFlag=0xffffffff
[0000.234] Last reboot was clean, booting normally!
[0000.238] Sdram initialization is successful
[0000.243] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.248] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.253] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.258] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.263] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.269] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.274] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.279] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.294] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.300] Platform-DebugCarveout: 0
[0000.303] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.308] Non secure mode, and RB not enabled.
[0000.358] Using GPT Primary to query partitions
[0000.363] Loading Tboot-CPU binary
[0000.412] Verifying bootloader in OdmNonSecureSBK mode
[0000.422] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.429] Bootloader downloaded successfully.
[0000.433] Downloaded Tboot-CPU binary to 0xa0000258
[0000.438] MAX77620_GPIO1 Configured.
[0000.442] MAX77620_GPIO5 Configured.
[0000.445] CPU power rail is up
[0000.448] CPU clock enabled
[0000.452] Performing RAM repair
[0000.455] Updating A64 Warmreset Address to 0xa00002e9
[0000.483] Bootloader DTB Load Address: 0x83000000
[0000.511] Kernel DTB Load Address: 0x83100000
[0000.516] Loading cboot binary
[0000.610] Verifying bootloader in OdmNonSecureSBK mode
[0000.649] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.656] Bootloader downloaded successfully.
[0000.660] GPT: Partition NOT found !
[0000.663] Find Partition via GPT Failed
[0000.667] Find Partition via PT Failed
[0000.670] function NvTbootGetBinaryOffsets: 0x1 error
[0000.675] Error in NvTbootLoadBinary: 0x1 !
[0000.679] Next binary entry address: 0x92c00258
[0000.684] BoardId: 2180
[0000.689] dram memory type is 3
[0000.692] WB0 init successful
[0000.718] Bpmp FW successfully loaded
[0000.722] Set NvDecSticky Bits
[0000.725] GSC1 address : ff700000
[0000.729] GSC2 address ff63fffc value c0edbbcc
[0000.733] GSC2 address : ff600000
[0000.737] GSC3 address : ff500000
[0000.741] GSC4 address : ff400000
[0000.745] GSC5 address : ff300000
[0000.748] GSC MC Settings done
[0000.751] TOS plaintext Image length 28752
[0000.755]  Monitor size 28752
[0000.758]  OS size 0
[0000.761] *** Secure OS image signature not verified ***
[0000.766] Loading and Validation of Secure OS Successful
[0000.771] NvTbootPackSdramParams: start.
[0000.777] NvTbootPackSdramParams: done.
[0000.780] Tegraboot started after 160164 us
[0000.784] Basic modules init took 311490 us
[0000.788] Sec Bootdevice Read Time = 216 ms, Read Size = 9476 KB
[0000.794] Sec Bootdevice Write Time = -1940251271 ms, Write Size = -68719477 KB
[0000.801] Next stage binary read took 23844 us
[0000.806] Carveout took 207321 us
[0000.809] CPU initialization took 96676 us
[0000.813] Total time taken by TegraBoot 639331 us
[0000.817] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.2(release):cc5fd7c
NOTICE:  BL31: Built : 00:37:02, Jul 20 2017
NOTICE:  Trusty image missing.
ERROR:   Error initializing runtime service trusty_fast
[0000.958] RamCode = 0
[0000.979] LPDDR4 Training: Read DT: Number of tables = 10
[0000.984] EMC Training (SRC-freq: 204000; DST-freq: 40800)
[0000.989] EMC Training Skipped
[0000.992] EMC Training (SRC-freq: 204000; DST-freq: 68000)
[0000.997] EMC Training Skipped
[0001.000] EMC Training (SRC-freq: 204000; DST-freq: 102000)
[0001.005] EMC Training Skipped
[0001.008] EMC Training (SRC-freq: 204000; DST-freq: 204000)
[0001.013] EMC Training Skipped
[0001.016] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.022] EMC Training Successful
[0001.025] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.031] EMC Training Successful
[0001.034] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.046] EMC Training Successful
[0001.049] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.072] EMC Training Successful
[0001.075] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.096] EMC Training Successful
[0001.099] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.119] EMC Training Successful
[0001.122] Switching to 800000 KHz Success
[0001.132] RamCode = 0
[0001.136] DT Write: emc-table@40800 succeeded
[0001.142] DT Write: emc-table@68000 succeeded
[0001.148] DT Write: emc-table@102000 succeeded
[0001.154] DT Write: emc-table@204000 succeeded
[0001.160] DT Write: emc-table@408000 succeeded
[0001.166] DT Write: emc-table@665600 succeeded
[0001.172] DT Write: emc-table@800000 succeeded
[0001.178] DT Write: emc-table@1065600 succeeded
[0001.184] DT Write: emc-table@1331200 succeeded
[0001.190] DT Write: emc-table@1600000 succeeded
[0001.194] LPDDR4 Training: Write DT: Number of tables = 10
[0001.230]
[0001.231] Debug Init done
[0001.234] Marked DTB cacheable
[0001.237] Bootloader DTB loaded at 0x83000000
[0001.242] Marked DTB cacheable
[0001.244] Kernel DTB loaded at 0x83100000
[0001.248] DeviceTree Init done
[0001.268] Pinmux applied successfully
[0001.274] gicd_base: 0x50041000
[0001.278] gicc_base: 0x50042000
[0001.281] Interrupts Init done
[0001.287] Using base:0x60005008 & irq:33 for tick-timer
[0001.292] Using base:0x60005000 for delay-timer
[0001.296] platform_init_timer: DONE
[0001.300] Timer(tick) Init done
[0001.305] osc freq = 38400 khz
[0001.310]
[0001.311] welcome to cboot
[0001.314]
[0001.315] Cboot Version: 00.00.2014.50-t210-fadd1be5
[0001.320] calling constructors
[0001.323] initializing heap
[0001.326] initializing threads
[0001.329] initializing timers
[0001.331] creating bootstrap completion thread
[0001.336] top of bootstrap2()
[0001.339] CPU: ARM Cortex A57
[0001.341] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.346] initializing platform
[0001.392] config for ddr50 mode completed
[0001.396] sdmmc bdev is already initialized
[0001.400] Enable APE clock
[0001.403] Un-powergate APE partition
[0001.406] of_register: registering tegra_udc to of_hal
[0001.411] of_register: registering inv20628-driver to of_hal
[0001.417] of_register: registering ads1015-driver to of_hal
[0001.423] of_register: registering lp8557-bl-driver to of_hal
[0001.428] of_register: registering bq2419x_charger to of_hal
[0001.434] of_register: registering cpc to of_hal
[0001.439] of_register: registering bq27441_fuel_gauge to of_hal
[0001.458] gpio framework initialized
[0001.461] of_register: registering tca9539_gpio to of_hal
[0001.467] of_register: registering tca9539_gpio to of_hal
[0001.472] of_register: registering i2c_bus_driver to of_hal
[0001.478] of_register: registering i2c_bus_driver to of_hal
[0001.483] of_register: registering i2c_bus_driver to of_hal
[0001.489] pmic framework initialized
[0001.492] of_register: registering max77620_pmic to of_hal
[0001.498] regulator framework initialized
[0001.502] of_register: registering tegra_xhci to of_hal
[0001.507] initializing target
[0001.516] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.527] fixed regulator driver initialized
[0001.599] initializing OF layer
[0001.602] NCK carveout not present
[0001.605] Skipping dts_overrides
[0001.609] of_children_init: Ops found for compatible string nvidia,tegra210-xhci
[0001.618] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.648] I2C Bus Init done
[0001.651] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.666] I2C Bus Init done
[0001.669] of_children_init: Ops found for compatible string ti,tca9539
[0001.683] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0001.688] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.695] of_children_init: Ops found for compatible string ti,tca9539
[0001.709] tca9539_init: i2c bus: 2, slave addr: 0xee
[0001.714] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.721] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.736] I2C Bus Init done
[0001.738] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.753] I2C Bus Init done
[0001.756] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.771] I2C Bus Init done
[0001.774] of_children_init: Ops found for compatible string maxim,max77620
[0001.789] max77620_init using irq 118
[0001.794] register 'maxim,max77620' pmic
[0001.799] gpio_driver_register: register 'max77620-gpio' driver
[0001.805] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.820] I2C Bus Init done
[0001.825] NCK carveout not present
[0001.828] shim_invoke: No NCT, Calling dts updates
[0001.849] Find /i2c@7000c000's alias i2c0
[0001.853] get eeprom at 1-a2, size 256, type 0
[0001.857] get eeprom at 1-ae, size 256, type 0
[0001.873] Find /i2c@7000c400's alias i2c1
[0001.877] get eeprom at 2-a0, size 256, type 0
[0001.892] Find /i2c@7000c500's alias i2c2
[0001.896] get eeprom at 3-a0, size 256, type 0
[0001.900] get eeprom at 3-ae, size 256, type 0
[0001.912] Find /host1x/i2c@546c0000's alias i2c6
[0001.916] get eeprom at 7-a8, size 256, type 0
[0001.921] pm_ids_update: Updating 1,a2, size 256, type 0
[0001.926] I2C slave not started
[0001.929] I2C write failed
[0001.932] Writing offset failed
[0001.935] eeprom_init: EEPROM read failed
[0001.939] pm_ids_update: eeprom init failed
[0001.943] pm_ids_update: Updating 1,ae, size 256, type 0
[0001.948] I2C slave not started
[0001.951] I2C write failed
[0001.954] Writing offset failed
[0001.957] eeprom_init: EEPROM read failed
[0001.961] pm_ids_update: eeprom init failed
[0001.965] pm_ids_update: Updating 2,a0, size 256, type 0
[0001.970] I2C slave not started
[0001.973] I2C write failed
[0001.976] Writing offset failed
[0001.979] eeprom_init: EEPROM read failed
[0001.983] pm_ids_update: eeprom init failed
[0001.987] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.017] pm_ids_update: The pm board id is 2180-1000-410
[0002.026] Adding plugin-manager/ids/2180-1000-410=/i2c@7000c500:module@0x50
[0002.036] pm_ids_update: pm id update successful
[0002.041] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.071] pm_ids_update: The pm board id is 2597-0000-500
[0002.078] Adding plugin-manager/ids/2597-0000-500=/i2c@7000c500:module@0x57
[0002.087] pm_ids_update: pm id update successful
[0002.092] pm_ids_update: Updating 7,a8, size 256, type 0
[0002.099] I2C slave not started
[0002.102] I2C write failed
[0002.105] Writing offset failed
[0002.108] eeprom_init: EEPROM read failed
[0002.112] pm_ids_update: eeprom init failed
[0002.146] updating /chosen/nvidia,wifi-mac node 00:04:4b:66:36:b6
[0002.155] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:66:36:b7
[0002.164] updating /chosen/nvidia,ethernet-mac node 00:04:4b:66:36:b8
[0002.171] Plugin Manager: Parse ODM data 0x00084000
[0002.206] Find /i2c@7000c000's alias i2c0
[0002.210] get eeprom at 1-a2, size 256, type 0
[0002.214] get eeprom at 1-ae, size 256, type 0
[0002.230] Find /i2c@7000c400's alias i2c1
[0002.233] get eeprom at 2-a0, size 256, type 0
[0002.249] Find /i2c@7000c500's alias i2c2
[0002.253] get eeprom at 3-a0, size 256, type 0
[0002.257] get eeprom at 3-ae, size 256, type 0
[0002.269] Find /host1x/i2c@546c0000's alias i2c6
[0002.273] get eeprom at 7-a8, size 256, type 0
[0002.278] pm_ids_update: Updating 1,a2, size 256, type 0
[0002.283] I2C slave not started
[0002.286] I2C write failed
[0002.289] Writing offset failed
[0002.292] eeprom_init: EEPROM read failed
[0002.296] pm_ids_update: eeprom init failed
[0002.300] pm_ids_update: Updating 1,ae, size 256, type 0
[0002.305] I2C slave not started
[0002.308] I2C write failed
[0002.311] Writing offset failed
[0002.314] eeprom_init: EEPROM read failed
[0002.318] pm_ids_update: eeprom init failed
[0002.322] pm_ids_update: Updating 2,a0, size 256, type 0
[0002.327] I2C slave not started
[0002.330] I2C write failed
[0002.333] Writing offset failed
[0002.336] eeprom_init: EEPROM read failed
[0002.340] pm_ids_update: eeprom init failed
[0002.344] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.374] pm_ids_update: The pm board id is 2180-1000-410
[0002.382] Adding plugin-manager/ids/2180-1000-410=/i2c@7000c500:module@0x50
[0002.389] pm_ids_update: pm id update successful
[0002.393] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.423] pm_ids_update: The pm board id is 2597-0000-500
[0002.431] Adding plugin-manager/ids/2597-0000-500=/i2c@7000c500:module@0x57
[0002.438] pm_ids_update: pm id update successful
[0002.443] pm_ids_update: Updating 7,a8, size 256, type 0
[0002.450] I2C slave not started
[0002.453] I2C write failed
[0002.456] Writing offset failed
[0002.459] eeprom_init: EEPROM read failed
[0002.463] pm_ids_update: eeprom init failed
[0002.496] Chip UID is 00000001640d06c90000000008020080
[0002.504] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0    androidboot.modem=none androidboot.serialno=03232161297310800002 androidboot.security=non-secure
[0002.528] Add serial number:03232161297310800002 as DT property
[0002.536] calling apps_init()
[0002.540] Found 18 GPT partitions in "sdmmc3_user"
[0002.545] Proceeding to Cold Boot
[0002.548] starting app android_boot_app
[0002.552] Device state: unlocked
[0002.555] display console init
[0002.560] skip-display-init in bootloader
[0002.564] set_instance_and_out_type: invalid out_type
[0002.569] display_console_init: No display init
[0002.580] Gpio keyboard init success
[0002.583] bct_init bctinit
[0002.586] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0002.593] BMP partition read failed!
[0002.597] blob_init: blob-partition BMP header readDT entry for leds-pwm not found
 [0002.613] failed
[0002.614] load_bmp_blob: BMP blob initialization failed
[0002.619] Could not load/initialize BMP blob...ignoring
[0002.625] bl_battery_charging: connected to external power supply
[0002.636] fastboot: usb cable is not connected
[0002.640] display_console_ioctl: No display init
[0002.645] switch_backlight failed
[0002.648] bct_init bctinit
[0002.650] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0002.658] MSC Partition not found
[0002.661] bct_init bctinit
[0002.664] bct_init bctinit
[0002.667] blob_init: USP partition does not have valid Blob
[0002.673] Loading android kernel
[0002.677] Default: NOT skip verified boot.
[0002.681] Verified boot state = Orange
[0002.687] display_console_clear: No display init
[0002.691] kernel load address: 0x80080000, size: 503741 bytes
[0002.697] ramdisk load address: 0x84100000, size: 0 bytes
[0002.703] load kernel from storage
[0002.707] decompressor handler not found
[0002.717] Successfully loaded kernel and ramdisk images
[0002.725] bct_init bctinit
[0002.728] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0002.735] BMP partition read failed!
[0002.739] blob_init: blob-partition BMP header read failed
[0002.744] load_bmp_blob: BMP blob initialization failed
[0002.749] bmp blob is not loaded and initialized
[0002.754] Failed to display boot-logo
[0002.758] NCK carveout not present
[0002.761] Skipping dts_overrides
[0002.764] NCK carveout not present
[0002.767] shim_invoke: No NCT, Calling dts updates
[0002.789] Find /i2c@7000c000's alias i2c0
[0002.793] get eeprom at 1-a2, size 256, type 0
[0002.797] get eeprom at 1-ae, size 256, type 0
[0002.813] Find /i2c@7000c400's alias i2c1
[0002.817] get eeprom at 2-a0, size 256, type 0
[0002.833] Find /i2c@7000c500's alias i2c2
[0002.837] get eeprom at 3-a0, size 256, type 0
[0002.842] get eeprom at 3-ae, size 256, type 0
[0002.854] Find /host1x/i2c@546c0000's alias i2c6
[0002.858] get eeprom at 7-a8, size 256, type 0
[0002.863] pm_ids_update: Updating 1,a2, size 256, type 0
[0002.868] I2C slave not started
[0002.871] I2C write failed
[0002.874] Writing offset failed
[0002.877] eeprom_init: EEPROM read failed
[0002.881] pm_ids_update: eeprom init failed
[0002.885] pm_ids_update: Updating 1,ae, size 256, type 0
[0002.890] I2C slave not started
[0002.893] I2C write failed
[0002.896] Writing offset failed
[0002.899] eeprom_init: EEPROM read failed
[0002.903] pm_ids_update: eeprom init failed
[0002.907] pm_ids_update: Updating 2,a0, size 256, type 0
[0002.912] I2C slave not started
[0002.915] I2C write failed
[0002.918] Writing offset failed
[0002.921] eeprom_init: EEPROM read failed
[0002.925] pm_ids_update: eeprom init failed
[0002.929] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.959] pm_ids_update: The pm board id is 2180-1000-410
[0002.968] Adding plugin-manager/ids/2180-1000-410=/i2c@7000c500:module@0x50
[0002.978] pm_ids_update: pm id update successful
[0002.983] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.013] pm_ids_update: The pm board id is 2597-0000-500
[0003.020] Adding plugin-manager/ids/2597-0000-500=/i2c@7000c500:module@0x57
[0003.029] pm_ids_update: pm id update successful
[0003.034] pm_ids_update: Updating 7,a8, size 256, type 0
[0003.041] I2C slave not started
[0003.044] I2C write failed
[0003.047] Writing offset failed
[0003.050] eeprom_init: EEPROM read failed
[0003.054] pm_ids_update: eeprom init failed
[0003.088] updating /chosen/nvidia,wifi-mac node 00:04:4b:66:36:b6
[0003.097] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:66:36:b7
[0003.106] updating /chosen/nvidia,ethernet-mac node 00:04:4b:66:36:b8
[0003.113] Plugin Manager: Parse ODM data 0x00084000
[0003.134] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0    androidboot.modem=none androidboot.serialno=03232161297310800002 androidboot.security=non-secure
[0003.158] Add serial number:03232161297310800002 as DT property
[0003.166] Updated bpmp info to DTB
[0003.173] Updated initrd info to DTB
[0003.176] "proc-board" doesn't exist, creating
[0003.184] Updated board info to DTB
[0003.187] "pmu-board" doesn't exist, creating
[0003.195] Updated board info to DTB
[0003.198] "display-board" doesn't exist, creating
[0003.204] Updated board info to DTB
[0003.208] "reset" doesn't exist, creating
[0003.213] Updated reset info to DTB
[0003.216] display_console_ioctl: No display init
[0003.221] display_console_ioctl: No display init
[0003.225] display_console_ioctl: No display init
[0003.232] display_console_ioctl: No display init
[0003.240] Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03232161297310800002 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange
[0003.313] Updated bootarg info to DTB
[0003.319] Updated memory info to DTB
[0003.329] set vdd_core voltage to 1075 mv
[0003.333] setting 'vdd-core' regulator to 1075000 micro volts
[0003.338] nvdumper Carveout: Base = 0xff23f000 and Size = 0x80000
[0003.345] bct_init bctinit
[0003.348] Starting Bpmp FW
[0003.351] BPMP-FW Carveout: Base = 0xff2c0000 and Size = 0x40000
U-Boot 2016.07-g0ce7ca2 (Jul 20 2017 - 00:37:03 -0700)
TEGRA210
Model: NVIDIA P2371-2180
Board: NVIDIA P2371-2180
DRAM:  4 GiB
MC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
223 bytes read in 100 ms (2 KiB/s)
p2371-2180 eMMC boot options
1:      primary kernel
Enter choice: 1:        primary kernel
Retrieving file: /boot/initrd
0 bytes read in 93 ms (0 Bytes/s)
Retrieving file: /boot/Image
20935216 bytes read in 526 ms (38 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03232161297310800002 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
   reserving fdt memory region: addr=80000000 size=20000
   Using Device Tree in place at 0000000083100000, end 00000000831aee6c
Starting kernel ...
Here is also the extracted tegra210-jetson-cv-base-p2597-2180-a00.dts
dsi {
			compatible = "nvidia,tegra210-dsi";
			reg = <0x0 0x54300000 0x0 0x40000 0x0 0x54400000 0x0 0x40000>;
			clocks = <0x41 0x30 0x41 0x93 0x41 0x52 0x41 0x94 0x41 0xf6 0x41 0xb1>;
			clock-names = "dsi", "dsia_lp", "dsib", "dsib_lp", "pll_p_out3", "clk72mhz";
			resets = <0x41 0x30 0x41 0x52>;
			reset-names = "dsia", "dsib";
			pad-controllers = <0x5b 0xf 0x5b 0x10 0x5b 0x11 0x5b 0x12>;
			pad-names = "dsia", "dsib", "dsic", "dsid";
			status = "okay";
			nvidia,dsi-controller-vs = <0x1>;
			panel-a-wuxga-8-0 {
				status = "okay";
				compatible = "a,wuxga-8-0";
				nvidia,dsi-instance = <0x0>;
				nvidia,dsi-n-data-lanes = <0x4>;
				nvidia,dsi-pixel-format = <0x3>;
				nvidia,dsi-refresh-rate = <0x3c>;
				nvidia,dsi-video-data-type = <0x0>;
				nvidia,dsi-video-clock-mode = <0x1>;
				nvidia,dsi-video-burst-mode = <0x0>;
				nvidia,dsi-virtual-channel = <0x0>;
				nvidia,dsi-panel-reset = <0x1>;
				nvidia,dsi-power-saving-suspend = <0x1>;
				nvidia,dsi-ulpm-not-support = <0x1>;
				nvidia,dsi-dpd-pads = <0x4 0x8>;
				nvidia,panel-rst-gpio = <0x7b 0xaa 0x0>;
				nvidia,panel-bl-pwm-gpio = <0x7b 0xa8 0x0>;
				disp-default-out {
					nvidia,out-type = <0x2>;
					nvidia,out-width = <0x6b>;
					nvidia,out-height = <0xac>;
					nvidia,out-flags = <0x0>;
					nvidia,out-parent-clk = "pll_d_out0";
					nvidia,out-xres = <0x4b0>;
					nvidia,out-yres = <0x780>;
				display-timings {
					1200x1920-32 {
						clock-frequency = <0x948edc0>;
						hactive = <0x4b0>;
						vactive = <0x780>;
						hfront-porch = <0x40>;
						hback-porch = <0x36>;
						hsync-len = <0xa>;
						vfront-porch = <0x3>;
						vback-porch = <0x1e>;
						vsync-len = <0x2>;
						nvidia,h-ref-to-sync = <0x4>;
						nvidia,v-ref-to-sync = <0x1>;
				smartdimmer {
					status = "okay";
					nvidia,turn-off-brightness = <0x32>;
					nvidia,turn-on-brightness = <0x4b>;
					nvidia,use-auto-pwm = <0x0>;
					nvidia,hw-update-delay = <0x0>;
					nvidia,bin-width = <0xffffffff>;
					nvidia,aggressiveness = <0x5>;
					nvidia,use-vid-luma = <0x0>;
					nvidia,phase-in-settings = <0x0>;
					nvidia,phase-in-adjustments = <0x0>;
					nvidia,k-limit-enable = <0x1>;
					nvidia,k-limit = <0xc8>;
					nvidia,sd-window-enable = <0x0>;
					nvidia,soft-clipping-enable = <0x1>;
					nvidia,soft-clipping-threshold = <0x80>;
					nvidia,smooth-k-enable = <0x1>;
					nvidia,smooth-k-incr = <0x4>;
					nvidia,coeff = <0x5 0x9 0x2>;
					nvidia,fc = <0x0 0x0>;
					nvidia,blp = <0x400 0xff>;
					nvidia,bltf = <0x39 0x41 0x49 0x52 0x5c 0x67 0x72 0x7d 0x8a 0x96 0xa4 0xb2 0xc1 0xd0 0xe0 0xf1>;
					nvidia,lut = <0xff 0xff 0xff 0xc7 0xc7 0xc7 0x99 0x99 0x99 0x74 0x74 0x74 0x55 0x55 0x55 0x3b 0x3b 0x3b 0x24 0x24 0x24 0x11 0x11 0x11 0x0 0x0 0x0>;
					nvidia,use-vpulse2 = <0x1>;
					nvidia,bl-device-name = "pwm-backlight";
				cmu {
					nvidia,cmu-csc = <0xf7 0x3f2 0x16 0x3f4 0x101 0x3e2 0x3ff 0x3ff 0xde>;
					nvidia,cmu-lut2 = <0x0 0x1 0x3 0x4 0x6 0x7 0x8 0x9 0xb 0xc 0xd 0xe 0xf 0x10 0x11 0x12 0x13 0x13 0x14 0x15 0x16 0x16 0x17 0x17 0x18 0x19 0x19 0x1a 0x1a 0x1a 0x1b 0x1b 0x1c 0x1c 0x1c 0x1d 0x1d 0x1d 0x1e 0x1e 0x1e 0x1f 0x1f 0x1f 0x1f 0x20 0x20 0x20 0x21 0x21 0x21 0x21 0x22 0x22 0x22 0x23 0x23 0x23 0x23 0x24 0x24 0x24 0x25 0x25 0x25 0x25 0x26 0x26 0x26 0x26 0x27 0x27 0x27 0x28 0x28 0x28 0x28 0x29 0x29 0x29 0x2a 0x2a 0x2a 0x2a 0x2b 0x2b 0x2b 0x2b 0x2c 0x2c 0x2c 0x2c 0x2d 0x2d 0x2d 0x2d 0x2e 0x2e 0x2e 0x2e 0x2f 0x2f 0x2f 0x2f 0x30 0x30 0x30 0x30 0x31 0x31 0x31 0x31 0x32 0x32 0x32 0x32 0x32 0x33 0x33 0x33 0x33 0x34 0x34 0x34 0x34 0x34 0x35 0x35 0x35 0x35 0x35 0x36 0x36 0x36 0x36 0x36 0x37 0x37 0x37 0x37 0x37 0x37 0x38 0x38 0x38 0x38 0x38 0x39 0x39 0x39 0x39 0x39 0x39 0x3a 0x3a 0x3a 0x3a 0x3a 0x3a 0x3b 0x3b 0x3b 0x3b 0x3b 0x3b 0x3c 0x3c 0x3c 0x3c 0x3c 0x3c 0x3d 0x3d 0x3d 0x3d 0x3d 0x3d 0x3e 0x3e 0x3e 0x3e 0x3e 0x3e 0x3f 0x3f 0x3f 0x3f 0x3f 0x3f 0x3f 0x40 0x40 0x40 0x40 0x40 0x40 0x41 0x41 0x41 0x41 0x41 0x41 0x41 0x42 0x42 0x42 0x42 0x42 0x42 0x43 0x43 0x43 0x43 0x43 0x43 0x43 0x44 0x44 0x44 0x44 0x44 0x44 0x44 0x45 0x45 0x45 0x45 0x45 0x45 0x46 0x46 0x46 0x46 0x46 0x46 0x46 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x48 0x48 0x48 0x48 0x48 0x48 0x48 0x49 0x49 0x49 0x49 0x49 0x49 0x49 0x4a 0x4a 0x4a 0x4a 0x4a 0x4a 0x4a 0x4a 0x4b 0x4b 0x4b 0x4b 0x4b 0x4b 0x4b 0x4c 0x4c 0x4c 0x4c 0x4c 0x4c 0x4c 0x4d 0x4d 0x4d 0x4d 0x4d 0x4d 0x4d 0x4d 0x4e 0x4e 0x4e 0x4e 0x4e 0x4e 0x4e 0x4e 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x50 0x50 0x50 0x50 0x50 0x50 0x50 0x50 0x51 0x51 0x51 0x51 0x51 0x51 0x51 0x51 0x51 0x52 0x52 0x52 0x52 0x52 0x52 0x52 0x52 0x52 0x53 0x53 0x53 0x53 0x53 0x53 0x53 0x53 0x53 0x54 0x54 0x54 0x54 0x54 0x54 0x54 0x54 0x54 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x56 0x56 0x56 0x56 0x56 0x56 0x56 0x56 0x56 0x56 0x57 0x57 0x57 0x57 0x57 0x57 0x57 0x57 0x57 0x57 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x59 0x59 0x59 0x59 0x59 0x59 0x59 0x59 0x59 0x59 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x63 0x63 0x63 0x63 0x63 0x63 0x63 0x63 0x63 0x63 0x63 0x64 0x64 0x64 0x64 0x65 0x66 0x67 0x67 0x68 0x69 0x69 0x6a 0x6b 0x6c 0x6c 0x6d 0x6e 0x6e 0x6f 0x70 0x70 0x71 0x72 0x72 0x73 0x73 0x74 0x75 0x75 0x76 0x77 0x77 0x78 0x78 0x79 0x79 0x7a 0x7b 0x7b 0x7c 0x7c 0x7d 0x7d 0x7e 0x7e 0x7f 0x7f 0x80 0x80 0x81 0x81 0x82 0x82 0x83 0x83 0x84 0x84 0x85 0x85 0x86 0x86 0x87 0x87 0x88 0x88 0x89 0x89 0x89 0x8a 0x8a 0x8b 0x8b 0x8c 0x8c 0x8d 0x8d 0x8e 0x8e 0x8e 0x8f 0x8f 0x90 0x90 0x91 0x91 0x92 0x92 0x93 0x93 0x94 0x94 0x95 0x95 0x95 0x96 0x96 0x97 0x97 0x98 0x98 0x99 0x99 0x9a 0x9a 0x9a 0x9b 0x9b 0x9c 0x9c 0x9d 0x9d 0x9e 0x9e 0x9e 0x9f 0x9f 0xa0 0xa0 0xa0 0xa1 0xa1 0xa2 0xa2 0xa2 0xa3 0xa3 0xa3 0xa4 0xa4 0xa5 0xa5 0xa5 0xa6 0xa6 0xa6 0xa7 0xa7 0xa7 0xa8 0xa8 0xa8 0xa9 0xa9 0xa9 0xaa 0xaa 0xaa 0xab 0xab 0xab 0xac 0xac 0xac 0xad 0xad 0xad 0xae 0xae 0xae 0xaf 0xaf 0xaf 0xb0 0xb0 0xb1 0xb1 0xb1 0xb2 0xb2 0xb2 0xb3 0xb3 0xb3 0xb4 0xb4 0xb5 0xb5 0xb5 0xb6 0xb6 0xb7 0xb7 0xb7 0xb8 0xb8 0xb8 0xb9 0xb9 0xba 0xba 0xba 0xbb 0xbb 0xbc 0xbc 0xbc 0xbd 0xbd 0xbd 0xbe 0xbe 0xbf 0xbf 0xbf 0xc0 0xc0 0xc0 0xc1 0xc1 0xc1 0xc2 0xc2 0xc2 0xc3 0xc3 0xc4 0xc4 0xc4 0xc5 0xc5 0xc5 0xc6 0xc6 0xc6 0xc6 0xc7 0xc7 0xc7 0xc8 0xc8 0xc8 0xc9 0xc9 0xc9 0xca 0xca 0xca 0xcb 0xcb 0xcb 0xcb 0xcc 0xcc 0xcc 0xcd 0xcd 0xcd 0xcd 0xce 0xce 0xce 0xcf 0xcf 0xcf 0xcf 0xd0 0xd0 0xd0 0xd1 0xd1 0xd1 0xd1 0xd2 0xd2 0xd2 0xd3 0xd3 0xd3 0xd3 0xd4 0xd4 0xd4 0xd4 0xd5 0xd5 0xd5 0xd6 0xd6 0xd6 0xd6 0xd7 0xd7 0xd7 0xd7 0xd8 0xd8 0xd8 0xd9 0xd9 0xd9 0xd9 0xda 0xda 0xda 0xda 0xdb 0xdb 0xdb 0xdb 0xdc 0xdc 0xdc 0xdc 0xdd 0xdd 0xdd 0xde 0xde 0xde 0xde 0xdf 0xdf 0xdf 0xdf 0xe0 0xe0 0xe0 0xe0 0xe1 0xe1 0xe1 0xe1 0xe2 0xe2 0xe2 0xe2 0xe3 0xe3 0xe3 0xe3 0xe4 0xe4 0xe4 0xe4 0xe5 0xe5 0xe5 0xe6 0xe6 0xe6 0xe6 0xe7 0xe7 0xe7 0xe7 0xe8 0xe8 0xe8 0xe8 0xe9 0xe9 0xe9 0xe9 0xea 0xea 0xea 0xea 0xeb 0xeb 0xeb 0xeb 0xec 0xec 0xec 0xec 0xed 0xed 0xed 0xed 0xee 0xee 0xee 0xee 0xee 0xef 0xef 0xef 0xef 0xf0 0xf0 0xf0 0xf0 0xf1 0xf1 0xf1 0xf1 0xf2 0xf2 0xf2 0xf2 0xf3 0xf3 0xf3 0xf3 0xf3 0xf4 0xf4 0xf4 0xf4 0xf5 0xf5 0xf5 0xf5 0xf6 0xf6 0xf6 0xf6 0xf6 0xf7 0xf7 0xf7 0xf7 0xf8 0xf8 0xf8 0xf8 0xf8 0xf9 0xf9 0xf9 0xf9 0xf9 0xfa 0xfa 0xfa 0xfa 0xfb 0xfb 0xfb 0xfb 0xfb 0xfc 0xfc 0xfc 0xfc 0xfc 0xfd 0xfd 0xfd 0xfd 0xfd 0xfe 0xfe 0xfe 0xfe 0xfe 0xff 0xff 0xff 0xff 0xff>;
here is the tegra210-jetson-tx1-p2597-2180-a01-devkit.dts file.
dsi {
			status = "okay";
			panel-a-wuxga-8-0 {
				status = "okay";
				disp-default-out {
					nvidia,out-width = <0x200>;
					nvidia,out-height = <0x120>;
					nvidia,out-xres = <0x500>;
					nvidia,out-yres = <0x2d0>;
				display-timings {
					1280x720-32 {
						clock-frequency = <0x46cf710>;
						hactive = <0x500>;
						vactive = <0x2d0>;
						hfront-porch = <0x6e>;
						hsync-len = <0xb4>;
						vfront-porch = <0x5>;
						vback-porch = <0x14>;
						vsync-len = <0x5>;
						nvidia,h-ref-to-sync = <0x0>;
						nvidia,v-ref-to-sync = <0x0>;
				smartdimmer {
					status = "okay";
				cmu {
Do I need to disable the HDMI port?
sor1 {
			compatible = "nvidia,tegra210-sor1";
			reg = <0x0 0x54580000 0x0 0x40000>;
			reg-names = "sor";
			interrupts = <0x0 0x4c 0x4>;
			status = "okay";
			nvidia,xbar-ctrl = <0x2 0x1 0x0 0x3 0x4>;
			clocks = <0x41 0xb7 0x41 0xde 0x41 0x16e 0x41 0x16f 0x41 0xf3 0x41 0xca 0x41 0x7d 0x41 0x6f 0x41 0x80>;
			clock-names = "sor1", "sor_safe", "sor1_brick", "sor1_src", "pll_p", "maud", "hda", "hda2codec_2x", "hda2hdmi";
			resets = <0x41 0xb7 0x41 0x7d 0x41 0x6f 0x41 0x80>;
			reset-names = "sor1", "hda_rst", "hda2codec_2x_rst", "hda2hdmi_rst";
			pad-controllers = <0x5b 0x17>;
			pad-names = "hdmi";
			nvidia,ddc-i2c-bus = <0x92>;
			nvidia,hpd-gpio = <0x7b 0xe1 0x1>;
			hdmi-display {
				status = "okay";
				compatible = "hdmi,display";
				disp-default-out {
					nvidia,out-xres = <0x1000>;
					nvidia,out-yres = <0x870>;
					nvidia,out-type = <0x1>;
					nvidia,out-flags = <0x2>;
					nvidia,out-parent-clk = "pll_d2";
					nvidia,out-align = <0x0>;
					nvidia,out-order = <0x0>;
			prod-settings {
				#prod-cells = <0x3>;
				prod_list_hdmi_soc = "prod_c_hdmi_0m_54m", "prod_c_hdmi_54m_111m", "prod_c_hdmi_111m_223m", "prod_c_hdmi_223m_300m", "prod_c_hdmi_300m_600m";
				prod_list_hdmi_board = "prod_c_hdmi_0m_54m", "prod_c_hdmi_54m_75m", "prod_c_hdmi_75m_150m", "prod_c_hdmi_150m_300m", "prod_c_hdmi_300m_600m";
				prod {
					prod = <0x3a0 0x1 0x1 0x5c 0xf000700 0x1000000 0x60 0xf01f00 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x401000>;
				prod_c_hdmi_0m_54m {
					prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x1000000 0x60 0xf01f00 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x401000>;
					board {
						prod = <0x5c 0xf000700 0x1000000 0x60 0xf01f00 0x301300 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x401000>;
				prod_c_hdmi_54m_111m {
					prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x1000100 0x60 0xf01f00 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x404000>;
				prod_c_hdmi_111m_223m {
					prod = <0x3a0 0x2 0x0 0x5c 0xf000700 0x1000300 0x60 0xff0fe0ff 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x406600>;
				prod_c_hdmi_223m_300m {
					prod = <0x3a0 0x2 0x0 0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x401380 0x68 0xf000000 0xa000000 0x138 0xffffffff 0x333f3f3f 0x148 0xffffffff 0x171717 0x170 0x40ff00 0x406600>;
				prod_c_hdmi_300m_600m {
					prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333f3f3f 0x148 0xffffffff 0x0 0x170 0x40ff00 0x406600>;
					board {
						prod = <0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x301f00 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333e3e3e 0x148 0xffffffff 0x70707 0x170 0x40ff00 0x406600>;
				prod_c_54M {
				prod_c_75M {
				prod_c_150M {
				prod_c_300M {
				prod_c_600M {
				prod_c_dp {
					prod = <0x5c 0xf000f10 0x1000310 0x60 0x3f00100 0x400100 0x68 0x2000 0x2000 0x70 0xffffffff 0x0 0x180 0x1 0x1>;
				prod_c_hdmi_54m_75m {
					board {
						prod = <0x5c 0xf000700 0x1000100 0x60 0xf01f00 0x301300 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x404000>;
				prod_c_hdmi_75m_150m {
					board {
						prod = <0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x301300 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x406600>;
				prod_c_hdmi_150m_300m {
					board {
						prod = <0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x301300 0x68 0xf000000 0xa000000 0x138 0xffffffff 0x333f3f3f 0x148 0xffffffff 0x171717 0x170 0x40ff00 0x406600>;
