Hi Wayne:
Thanks for your suggestion, I found the error. Now i have a mistake, can you help me?
This is the print message.Appeared "dvdd_lcd regulator get failed, dsi regulator get failed
[ 22.779169] dvdd_lcd regulator get failed
[ 22.779171] dsi regulator get failed
[[0;32m OK [0m] Created slice User Slice of ubuntu.
Starting User Manager for UID 1000...
[[0;32m OK [0m] Started Session c1 of user ubuntu.
Starting RealtimeKit Scheduling Policy Service...
Part of the code in the tegra210-jetson-cv-base-p2597-2180-a01.dts
host1x {
dc@54200000 {
status = "okay";
nvidia,dc-or-node = "/host1x/dsi";
dc@54240000 {
nvidia,dc-or-node = "/host1x/sor1";
dsi {
status = "okay";
panel-a-wuxga-8-0 {
status = "disabled";
panel-s-wqxga-10-1 {
status = "okay";
Part of the code in the tegra210-jetson-cv-base-p2597-2180-a00.dts
host1x {
/* tegradc.0 */
dc@54200000 {
status = "okay";
nvidia,dc-flags = <TEGRA_DC_FLAG_ENABLED>;
nvidia,emc-clk-rate = <300000000>;
nvidia,fb-bpp = <32>; /* bits per pixel */
nvidia,fb-flags = <TEGRA_FB_FLIP_ON_PROBE>;
/* tegradc.1 */
dc@54240000 {
status = "okay";
nvidia,cmu-enable = <1>;
dsi {
nvidia,dsi-controller-vs = <DSI_VS_1>;
status = "okay";
panel-a-wuxga-8-0 {
status = "okay";
nvidia,dsi-dpd-pads = <DSIC_DPD_EN DSID_DPD_EN>;
nvidia,panel-rst-gpio = <&gpio TEGRA_GPIO(V, 2) 0>; /* PV2 */
nvidia,panel-bl-pwm-gpio = <&gpio TEGRA_GPIO(V, 0) 0>; /* PV0 */
disp-default-out {
nvidia,out-flags = <TEGRA_DC_OUT_CONTINUOUS_MODE>;
status = "okay";
nvidia,panel-en-gpio = <&gpio TEGRA_GPIO(V, 1) 0>; /* PV1 */
nvidia,dsi-te-gpio = <&gpio TEGRA_GPIO(Y, 2) 0>;
disp-default-out {
Part of the code in the panel-s-wqxga-10-1
host1x {
dsi {
status = "okay";
status = "okay";
nvidia,dsi-lvds-bridge= <TEGRA_DSI_ENABLE>;
compatible = "s,wqxga-10-1";
nvidia,dsi-instance = <DSI_INSTANCE_0>;
nvidia,dsi-n-data-lanes = <4>;
nvidia,dsi-pixel-format = <TEGRA_DSI_PIXEL_FORMAT_24BIT_P>;
nvidia,dsi-refresh-rate = <61>;
nvidia,dsi-rated-refresh-rate = <60>;
nvidia,dsi-te-polarity-low = <TEGRA_DSI_ENABLE>;
nvidia,dsi-video-data-type = <TEGRA_DSI_VIDEO_TYPE_COMMAND_MODE>;
nvidia,dsi-video-clock-mode = <TEGRA_DSI_VIDEO_CLOCK_CONTINUOUS>;
nvidia,dsi-ganged-type = <TEGRA_DSI_GANGED_SYMMETRIC_LEFT_RIGHT>;
nvidia,dsi-controller-vs = <DSI_VS_1>;;
