Hi Nvidia:
I am a new guy in nvidia tx2, how to enable dsi in tx2?
I config dts, add log in nvdisp_stub.c. find the panel_gpio is wrong.
I am puzzled in gpio, like: nvidia,dsi-panel-reset = <0x1>; config which gpio number?
this is my dts:
dsi {
compatible = “nvidia,tegra186-dsi”;
reg = <0x0 0x15300000 0x0 0x40000 0x0 0x15400000 0x0 0x40000 0x0 0x15900000 0x0 0x40000 0x0 0x15940000 0x0 0x40000 0x0 0x15880000 0x0 0x10000>;
clocks = <0xbc 0xd 0x73 0xd 0x75 0xd 0x76 0xd 0x77 0xd 0xe7 0xd 0xe8 0xd 0xe9 0xd 0xea>;
clock-names = “clk32k_in”, “dsi”, “dsia_lp”, “dsib”, “dsib_lp”, “dsic”, “dsic_lp”, “dsid”, “dsid_lp”;
resets = <0xd 0x6 0xd 0x7 0xd 0x3f 0xd 0x40 0xd 0x91>;
reset-names = “dsia”, “dsib”, “dsic”, “dsid”, “dsi_padctrl”;
nvidia,enable-hs-clk-in-lp-mode = <0x1>;
pad-controllers = <0x10 0xf 0x10 0x10 0x10 0x11 0x10 0x12>;
pad-names = “dsia”, “dsib”, “dsic”, “dsid”;
status = “okay”;
nvidia,dsi-controller-vs = <0x1>;
prod-settings {
#prod-cells = <0x3>;
dsi-padctrl-prod {
prod = <0x24 0x3f0fc3f 0x0 0x28 0x333333 0x0 0x30 0xffffff 0x0 0x34 0xffffff 0x777777 0x54 0x3f0fc3f 0x0 0x58 0x333333 0x0 0x60 0xffffff 0x0 0x64 0xffffff 0x777777 0x84 0x3f0fc3f 0x0 0x88 0x333333 0x0 0x90 0xffffff 0x0 0x94 0xffffff 0x777777 0xb4 0x3f0fc3f 0x0 0xb8 0x333333 0x0 0xc0 0xffffff 0x0 0xc4 0xffffff 0x777777>;
panel-s-wuxga-8-0 {
status = "okay";
compatible = "s,wuxga-8-0";
nvidia,dsi-instance = <0x0>;
nvidia,dsi-n-data-lanes = <0x8>;
nvidia,dsi-pixel-format = <0x3>;
nvidia,dsi-refresh-rate = <0x3c>;
nvidia,dsi-video-data-type = <0x0>;
nvidia,dsi-video-clock-mode = <0x0>;
nvidia,dsi-video-burst-mode = <0x0>;
nvidia,dsi-ganged-type = <0x1>;
nvidia,dsi-ganged-swap-links = <0x1>;
nvidia,dsi-ganged-write-to-all-links = <0x1>;
nvidia,dsi-virtual-channel = <0x0>;
nvidia,dsi-ulpm-not-support = <0x1>;
nvidia,dsi-suspend-stop-stream-late = <0x1>;
nvidia,dsi-power-saving-suspend = <0x1>;
nvidia,default_color_space = <0x0>;
nvidia,dsi-init-cmd = <0x0 0x5 0x11 0x0 0x0 0x3 0xa 0x0 0x5 0x29 0x0 0x0>;
nvidia,dsi-n-init-cmd = <0x3>;
nvidia,dsi-suspend-cmd = <0x0 0x5 0x28 0x0 0x0 0x3 0x3 0x0 0x5 0x10 0x0 0x0 0x3 0xa>;
nvidia,dsi-n-suspend-cmd = <0x4>;
nvidia,dsi-pkt-seq = <0x1 0x0 0x40000000 0xff 0x21 0x0 0x40000000 0xff 0x21 0x0 0x40000000 0xff 0x21 0x0 0x3e 0x3 0x19 0x4 0xff 0x21 0x0 0x40000000 0xff 0x21 0x0 0x3e 0x3 0x19 0x4 0xff>;
nvidia,panel-rst-gpio = <0x12 0x7b 0x1>;
nvidia,panel-bl-pwm-gpio = <0x1c 0x8 0x1>;
nvidia,panel-bl-en-gpio = <0x1c 0xb 0x1>;
nvidia,panel-en-gpio = <0xc4 0x4 0x1>;
nvidia,en-vmm-vpp-with-i2c-config;
linux,phandle = <0x129>;
phandle = <0x129>;
disp-default-out {
nvidia,out-type = <0x2>;
nvidia,out-width = <0x6b>;
nvidia,out-height = <0xac>;
nvidia,out-flags = <0x0>;
nvidia,out-parent-clk = "pll_d";
nvidia,out-xres = <0x1000>;
nvidia,out-yres = <0x870>;
display-timings {
1200x1920-32-60Hz {
clock-frequency = <0xb845d40>;
hactive = <0x4b0>;
vactive = <0x780>;
hfront-porch = <0x6b>;
hback-porch = <0x14>;
hsync-len = <0x1>;
vfront-porch = <0x1f1>;
vback-porch = <0x7>;
vsync-len = <0x1>;
nvidia,h-ref-to-sync = <0x1>;
nvidia,v-ref-to-sync = <0xb>;
smartdimmer {
status = "okay";
nvidia,turn-off-brightness = <0x0>;
nvidia,turn-on-brightness = <0xff>;
nvidia,use-auto-pwm = <0x0>;
nvidia,hw-update-delay = <0x0>;
nvidia,bin-width = <0xffffffff>;
nvidia,aggressiveness = <0x5>;
nvidia,use-vid-luma = <0x0>;
nvidia,phase-in-settings = <0x0>;
nvidia,phase-in-adjustments = <0x0>;
nvidia,k-limit-enable = <0x1>;
nvidia,k-limit = <0xc8>;
nvidia,sd-window-enable = <0x0>;
nvidia,soft-clipping-enable = <0x1>;
nvidia,soft-clipping-threshold = <0x80>;
nvidia,smooth-k-enable = <0x1>;
nvidia,smooth-k-incr = <0x4>;
nvidia,coeff = <0x5 0x9 0x2>;
nvidia,fc = <0x0 0x0>;
nvidia,blp = <0x400 0xff>;
nvidia,bltf = <0x39 0x41 0x49 0x52 0x5c 0x67 0x72 0x7d 0x8a 0x96 0xa4 0xb2 0xc1 0xd0 0xe0 0xf1>;
nvidia,lut = <0xff 0xff 0xff 0xc7 0xc7 0xc7 0x99 0x99 0x99 0x74 0x74 0x74 0x55 0x55 0x55 0x3b 0x3b 0x3b 0x24 0x24 0x24 0x11 0x11 0x11 0x0 0x0 0x0>;
nvidia,use-vpulse2 = <0x1>;
nvidia,bl-device-name = "pwm-backlight";
nvidia,sw-update-delay = <0x0>;
nvidia,gain_table = <0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4000 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x4144 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x428c 0x4250 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x43d4 0x42b4 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x451c 0x44e0 0x4304 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4664 0x4660 0x4570 0x4318 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x47ac 0x4768 0x45e8 0x433c 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f4 0x48f0 0x482c 0x4644 0x4354 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a3c 0x4a00 0x48c4 0x4688 0x4368 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4b84 0x4af4 0x4960 0x46e0 0x4388 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ccc 0x4ca8 0x4ba8 0x49c0 0x4708 0x4390 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4e14 0x4db0 0x4c60 0x4a34 0x4748 0x43ac 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f5c 0x4f48 0x4e78 0x4cd4 0x4a6c 0x475c 0x43ac 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x50a0 0x5060 0x4f44 0x4d60 0x4ac4 0x478c 0x43c0 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x51e8 0x5158 0x4ff8 0x4dd8 0x4b14 0x47b4 0x43d0 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5330 0x5314 0x5238 0x5098 0x4e44 0x4b54 0x47d8 0x43dc 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5478 0x5424 0x5300 0x5124 0x4ea4 0x4b90 0x47f8 0x43e8 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55c0 0x55b8 0x5518 0x53b4 0x51a4 0x4ef8 0x4bc4 0x4814 0x43f0 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x5708 0x56dc 0x55f4 0x5458 0x5214 0x4f44 0x4bf0 0x4828 0x43f8 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x5850 0x57e8 0x56bc 0x54e8 0x527c 0x4f88 0x4c18 0x483c 0x4400 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5998 0x5990 0x58f4 0x579c 0x559c 0x5308 0x4ff4 0x4c64 0x486c 0x4414 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ae0 0x5ab8 0x59d4 0x5840 0x5614 0x5358 0x5024 0x4c80 0x4878 0x4418 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5c28 0x5bd8 0x5ac4 0x5908 0x56b4 0x53d8 0x5084 0x4cc4 0x48a4 0x4428 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d70 0x5d68 0x5cd0 0x5b80 0x5990 0x5714 0x5418 0x50a8 0x4cd8 0x48ac 0x442c 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5eb8 0x5e9c 0x5dd4 0x5c58 0x5a40 0x57a0 0x5484 0x50fc 0x4d10 0x48cc 0x443c 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x6000 0x5fc4 0x5ecc 0x5d24 0x5ae8 0x5828 0x54ec 0x514c 0x4d48 0x48f0 0x4448 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x6144 0x60c4 0x5f8c 0x5db4 0x5b50 0x586c 0x5518 0x5160 0x4d50 0x48f0 0x4448 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x628c 0x6280 0x61cc 0x606c 0x5e6c 0x5be4 0x58e0 0x5574 0x51a4 0x4d80 0x490c 0x4454 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63d4 0x63ac 0x62cc 0x6140 0x5f1c 0x5c70 0x5950 0x55cc 0x51e4 0x4dac 0x4928 0x4460 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x651c 0x64cc 0x63c0 0x6208 0x5fc0 0x5cf8 0x59bc 0x561c 0x5220 0x4dd4 0x4940 0x446c 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x6664 0x65e0 0x64a4 0x62c8 0x605c 0x5d78 0x5a20 0x5668 0x525c 0x4dfc 0x4958 0x4474 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x67ac 0x679c 0x66e8 0x6584 0x6380 0x60f4 0x5df0 0x5a80 0x56b0 0x5290 0x4e20 0x4970 0x4480 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68f4 0x68c8 0x67e8 0x6654 0x642c 0x6180 0x5e60 0x5ad8 0x56f4 0x52c0 0x4e44 0x4984 0x4488 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x6a3c 0x69ec 0x68d8 0x6720 0x64d4 0x6208 0x5ecc 0x5b2c 0x5734 0x52f0 0x4e60 0x4994 0x4490 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b84 0x6b80 0x6b00 0x69c0 0x67e0 0x6570 0x6288 0x5f30 0x5b7c 0x5770 0x531c 0x4e80 0x49a8 0x4494 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6ccc 0x6cc4 0x6c24 0x6acc 0x68d0 0x6648 0x6344 0x5fd8 0x5c08 0x57e4 0x5378 0x4ec4 0x49d4 0x44ac 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6e14 0x6df8 0x6d28 0x6ba0 0x6980 0x66d8 0x63b8 0x6034 0x5c50 0x5818 0x539c 0x4edc 0x49e0 0x44b0 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f5c 0x6f1c 0x6e1c 0x6c6c 0x6a28 0x6760 0x6428 0x6088 0x5c90 0x584c 0x53c0 0x4ef4 0x49ec 0x44b4 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x70a0 0x7034 0x6f04 0x6d30 0x6ac8 0x67e0 0x648c 0x60d8 0x5cd0 0x5878 0x53e0 0x4f08 0x49f8 0x44bc 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x71e8 0x7160 0x7014 0x6e24 0x6ba4 0x68a4 0x6538 0x616c 0x5d4c 0x58e0 0x5430 0x4f44 0x4a20 0x44cc 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7330 0x7320 0x7264 0x70ec 0x6ed4 0x6c34 0x6918 0x6594 0x61b4 0x5d84 0x5908 0x544c 0x4f54 0x4a2c 0x44d0 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x7478 0x745c 0x7384 0x71f0 0x6fc0 0x6d04 0x69d4 0x6638 0x6244 0x5dfc 0x5968 0x5498 0x4f90 0x4a50 0x44e0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x75c0 0x7580 0x7474 0x72b8 0x7064 0x6d88 0x6a3c 0x668c 0x6280 0x5e28 0x598c 0x54b0 0x4f9c 0x4a58 0x44e4 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x7708 0x76b0 0x758c 0x73b4 0x7144 0x6e54 0x6af0 0x6728 0x6308 0x5e9c 0x59e8 0x54f8 0x4fd4 0x4a78 0x44f4 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x7850 0x77c0 0x766c 0x746c 0x71d8 0x6ec8 0x6b4c 0x6770 0x6340 0x5ec4 0x5a04 0x550c 0x4fdc 0x4a80 0x44f8 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7998 0x7990 0x78e4 0x7774 0x755c 0x72b0 0x6f88 0x6bf8 0x6804 0x63c0 0x5f30 0x5a5c 0x5550 0x5010 0x4aa0 0x4504 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ae0 0x7ac0 0x79e0 0x7844 0x7604 0x7338 0x6ff4 0x6c48 0x6844 0x63ec 0x5f50 0x5a74 0x5560 0x5018 0x4aa4 0x4508 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7c28 0x7bf8 0x7afc 0x7940 0x76e8 0x7404 0x70ac 0x6cec 0x68d0 0x6468 0x5fb8 0x5ac8 0x55a0 0x5048 0x4ac4 0x4514 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d70 0x7d2c 0x7c10 0x7a3c 0x77cc 0x74d0 0x7160 0x6d8c 0x695c 0x64dc 0x601c 0x5b18 0x55e0 0x5078 0x4ae0 0x4524 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7eb8 0x7e40 0x7cf4 0x7af4 0x785c 0x7544 0x71bc 0x6dd0 0x6990 0x6504 0x6034 0x5b28 0x55ec 0x507c 0x4ae4 0x4524 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x7ffc 0x7f68 0x7e00 0x7be4 0x7938 0x7608 0x7268 0x6e68 0x6a14 0x6574 0x6094 0x5b78 0x5628 0x50a8 0x4b00 0x4530>;
nvidia,backlight_table = <0xff 0xf3 0xe8 0xde 0xd4 0xcb 0xc2 0xba 0xb3 0xab 0xa5 0x9e 0x98 0x92 0x8d 0x88 0x83 0x7e 0x7a 0x76 0x72 0x6e 0x6a 0x67 0x64 0x60 0x5d 0x5a 0x58 0x55 0x53 0x50 0x4e 0x4c 0x49 0x47 0x45 0x43 0x42 0x40 0x3e 0x3d 0x3b 0x3a 0x38 0x37 0x35 0x34 0x33 0x31 0x30>;
cmu {
nvidia,cmu-csc = <0x100 0x0 0x0 0x0 0x100 0x0 0x0 0x0 0x100>;
nvidia,cmu-lut2 = <0x0 0x1 0x2 0x2 0x3 0x4 0x5 0x6 0x6 0x7 0x8 0x9 0xa 0xa 0xb 0xc 0xd 0xd 0xe 0xf 0xf 0x10 0x10 0x11 0x12 0x12 0x13 0x13 0x14 0x14 0x15 0x15 0x16 0x16 0x17 0x17 0x17 0x18 0x18 0x19 0x19 0x19 0x1a 0x1a 0x1b 0x1b 0x1b 0x1c 0x1c 0x1d 0x1d 0x1d 0x1e 0x1e 0x1e 0x1f 0x1f 0x1f 0x20 0x20 0x20 0x21 0x21 0x21 0x22 0x22 0x22 0x22 0x23 0x23 0x23 0x24 0x24 0x24 0x25 0x25 0x25 0x25 0x26 0x26 0x26 0x26 0x27 0x27 0x27 0x28 0x28 0x28 0x28 0x29 0x29 0x29 0x29 0x2a 0x2a 0x2a 0x2a 0x2b 0x2b 0x2b 0x2b 0x2b 0x2c 0x2c 0x2c 0x2c 0x2d 0x2d 0x2d 0x2d 0x2e 0x2e 0x2e 0x2e 0x2e 0x2f 0x2f 0x2f 0x2f 0x30 0x30 0x30 0x30 0x30 0x31 0x31 0x31 0x31 0x31 0x32 0x32 0x32 0x32 0x32 0x33 0x33 0x33 0x33 0x33 0x34 0x34 0x34 0x34 0x34 0x35 0x35 0x35 0x35 0x35 0x36 0x36 0x36 0x36 0x36 0x37 0x37 0x37 0x37 0x37 0x37 0x38 0x38 0x38 0x38 0x38 0x39 0x39 0x39 0x39 0x39 0x39 0x3a 0x3a 0x3a 0x3a 0x3a 0x3a 0x3b 0x3b 0x3b 0x3b 0x3b 0x3b 0x3c 0x3c 0x3c 0x3c 0x3c 0x3c 0x3d 0x3d 0x3d 0x3d 0x3d 0x3d 0x3e 0x3e 0x3e 0x3e 0x3e 0x3e 0x3f 0x3f 0x3f 0x3f 0x3f 0x3f 0x40 0x40 0x40 0x40 0x40 0x40 0x40 0x41 0x41 0x41 0x41 0x41 0x41 0x42 0x42 0x42 0x42 0x42 0x42 0x42 0x43 0x43 0x43 0x43 0x43 0x43 0x43 0x44 0x44 0x44 0x44 0x44 0x44 0x44 0x45 0x45 0x45 0x45 0x45 0x45 0x45 0x46 0x46 0x46 0x46 0x46 0x46 0x46 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x48 0x48 0x48 0x48 0x48 0x48 0x48 0x48 0x49 0x49 0x49 0x49 0x49 0x49 0x49 0x4a 0x4a 0x4a 0x4a 0x4a 0x4a 0x4a 0x4a 0x4b 0x4b 0x4b 0x4b 0x4b 0x4b 0x4b 0x4b 0x4c 0x4c 0x4c 0x4c 0x4c 0x4c 0x4c 0x4d 0x4d 0x4d 0x4d 0x4d 0x4d 0x4d 0x4d 0x4e 0x4e 0x4e 0x4e 0x4e 0x4e 0x4e 0x4e 0x4e 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x50 0x50 0x50 0x50 0x50 0x50 0x50 0x50 0x51 0x51 0x51 0x51 0x51 0x51 0x51 0x51 0x51 0x52 0x52 0x52 0x52 0x52 0x52 0x52 0x52 0x53 0x53 0x53 0x53 0x53 0x53 0x53 0x53 0x53 0x54 0x54 0x54 0x54 0x54 0x54 0x54 0x54 0x54 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x56 0x56 0x56 0x56 0x56 0x56 0x56 0x56 0x56 0x57 0x57 0x57 0x57 0x57 0x57 0x57 0x57 0x57 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x58 0x59 0x59 0x59 0x59 0x59 0x59 0x59 0x59 0x59 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5a 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5b 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5c 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5d 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5e 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x5f 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x61 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x62 0x63 0x63 0x63 0x63 0x63 0x63 0x63 0x64 0x65 0x65 0x66 0x67 0x67 0x68 0x69 0x69 0x6a 0x6b 0x6b 0x6c 0x6d 0x6d 0x6e 0x6f 0x6f 0x70 0x71 0x71 0x72 0x73 0x73 0x74 0x74 0x75 0x76 0x76 0x77 0x77 0x78 0x78 0x79 0x7a 0x7a 0x7b 0x7b 0x7c 0x7c 0x7d 0x7e 0x7e 0x7f 0x7f 0x80 0x80 0x81 0x81 0x82 0x82 0x83 0x83 0x84 0x84 0x85 0x85 0x86 0x86 0x87 0x87 0x88 0x88 0x89 0x89 0x8a 0x8a 0x8b 0x8b 0x8c 0x8c 0x8d 0x8d 0x8e 0x8e 0x8f 0x8f 0x90 0x90 0x91 0x91 0x91 0x92 0x92 0x93 0x93 0x94 0x94 0x95 0x95 0x96 0x96 0x96 0x97 0x97 0x98 0x98 0x99 0x99 0x99 0x9a 0x9a 0x9b 0x9b 0x9c 0x9c 0x9c 0x9d 0x9d 0x9e 0x9e 0x9e 0x9f 0x9f 0xa0 0xa0 0xa0 0xa1 0xa1 0xa2 0xa2 0xa2 0xa3 0xa3 0xa4 0xa4 0xa4 0xa5 0xa5 0xa6 0xa6 0xa6 0xa7 0xa7 0xa7 0xa8 0xa8 0xa9 0xa9 0xa9 0xaa 0xaa 0xaa 0xab 0xab 0xac 0xac 0xac 0xad 0xad 0xad 0xae 0xae 0xae 0xaf 0xaf 0xb0 0xb0 0xb0 0xb1 0xb1 0xb1 0xb2 0xb2 0xb2 0xb3 0xb3 0xb3 0xb4 0xb4 0xb4 0xb5 0xb5 0xb6 0xb6 0xb6 0xb7 0xb7 0xb7 0xb8 0xb8 0xb8 0xb9 0xb9 0xb9 0xba 0xba 0xba 0xbb 0xbb 0xbb 0xbc 0xbc 0xbc 0xbd 0xbd 0xbd 0xbd 0xbe 0xbe 0xbe 0xbf 0xbf 0xbf 0xc0 0xc0 0xc0 0xc1 0xc1 0xc1 0xc2 0xc2 0xc2 0xc3 0xc3 0xc3 0xc4 0xc4 0xc4 0xc4 0xc5 0xc5 0xc5 0xc6 0xc6 0xc6 0xc7 0xc7 0xc7 0xc8 0xc8 0xc8 0xc8 0xc9 0xc9 0xc9 0xca 0xca 0xca 0xca 0xcb 0xcb 0xcb 0xcc 0xcc 0xcc 0xcd 0xcd 0xcd 0xcd 0xce 0xce 0xce 0xcf 0xcf 0xcf 0xcf 0xd0 0xd0 0xd0 0xd1 0xd1 0xd1 0xd1 0xd2 0xd2 0xd2 0xd3 0xd3 0xd3 0xd3 0xd4 0xd4 0xd4 0xd5 0xd5 0xd5 0xd5 0xd6 0xd6 0xd6 0xd6 0xd7 0xd7 0xd7 0xd8 0xd8 0xd8 0xd8 0xd9 0xd9 0xd9 0xd9 0xda 0xda 0xda 0xdb 0xdb 0xdb 0xdb 0xdc 0xdc 0xdc 0xdc 0xdd 0xdd 0xdd 0xdd 0xde 0xde 0xde 0xdf 0xdf 0xdf 0xdf 0xe0 0xe0 0xe0 0xe0 0xe1 0xe1 0xe1 0xe1 0xe2 0xe2 0xe2 0xe2 0xe3 0xe3 0xe3 0xe3 0xe4 0xe4 0xe4 0xe4 0xe5 0xe5 0xe5 0xe5 0xe6 0xe6 0xe6 0xe6 0xe7 0xe7 0xe7 0xe7 0xe8 0xe8 0xe8 0xe8 0xe9 0xe9 0xe9 0xe9 0xea 0xea 0xea 0xea 0xeb 0xeb 0xeb 0xeb 0xec 0xec 0xec 0xec 0xed 0xed 0xed 0xed 0xee 0xee 0xee 0xee 0xef 0xef 0xef 0xef 0xf0 0xf0 0xf0 0xf0 0xf0 0xf1 0xf1 0xf1 0xf1 0xf2 0xf2 0xf2 0xf2 0xf3 0xf3 0xf3 0xf3 0xf4 0xf4 0xf4 0xf4 0xf4 0xf5 0xf5 0xf5 0xf5 0xf6 0xf6 0xf6 0xf6 0xf7 0xf7 0xf7 0xf7 0xf7 0xf8 0xf8 0xf8 0xf8 0xf9 0xf9 0xf9 0xf9 0xf9 0xfa 0xfa 0xfa 0xfa 0xfb 0xfb 0xfb 0xfb 0xfb 0xfc 0xfc 0xfc 0xfc 0xfd 0xfd 0xfd 0xfd 0xfd 0xfe 0xfe 0xfe 0xfe 0xff 0xff>;
nvdisp-cmu {
nvidia,panel-csc = <0xd581 0x2979 0xc5 0x0 0x831 0xcac1 0x20c 0x0 0x189 0x625 0xcc4a 0x0>;
nvidia,cmu-lut = <0x6000 0x6000 0x6000 0x6191 0x6191 0x6191 0x6322 0x6322 0x6322 0x643b 0x643b 0x643b 0x64ba 0x64ba 0x64ba 0x6539 0x6539 0x6539 0x65b8 0x65b8 0x65b8 0x6637 0x6637 0x6637 0x66b6 0x66b6 0x66b6 0x6735 0x6735 0x6735 0x67b4 0x67b4 0x67b4 0x6826 0x6826 0x6826 0x687d 0x687d 0x687d 0x68d4 0x68d4 0x68d4 0x692b 0x692b 0x692b 0x6983 0x6983 0x6983 0x69da 0x69da 0x69da 0x6a31 0x6a31 0x6a31 0x6a88 0x6a88 0x6a88 0x6ae0 0x6ae0 0x6ae0 0x6b37 0x6b37 0x6b37 0x6b8e 0x6b8e 0x6b8e 0x6be5 0x6be5 0x6be5 0x6c28 0x6c28 0x6c28 0x6c5b 0x6c5b 0x6c5b 0x6c8e 0x6c8e 0x6c8e 0x6cc1 0x6cc1 0x6cc1 0x6cf4 0x6cf4 0x6cf4 0x6d27 0x6d27 0x6d27 0x6d5a 0x6d5a 0x6d5a 0x6d8d 0x6d8d 0x6d8d 0x6dbf 0x6dbf 0x6dbf 0x6df2 0x6df2 0x6df2 0x6e25 0x6e25 0x6e25 0x6e58 0x6e58 0x6e58 0x6e8b 0x6e8b 0x6e8b 0x6ebe 0x6ebe 0x6ebe 0x6ef1 0x6ef1 0x6ef1 0x6f24 0x6f24 0x6f24 0x6f57 0x6f57 0x6f57 0x6f8a 0x6f8a 0x6f8a 0x6fbd 0x6fbd 0x6fbd 0x6ff0 0x6ff0 0x6ff0 0x701a 0x701a 0x701a 0x7037 0x7037 0x7037 0x7053 0x7053 0x7053 0x706f 0x706f 0x706f 0x708c 0x708c 0x708c 0x70a8 0x70a8 0x70a8 0x70c5 0x70c5 0x70c5 0x70e1 0x70e1 0x70e1 0x70fe 0x70fe 0x70fe 0x711a 0x711a 0x711a 0x7136 0x7136 0x7136 0x7153 0x7153 0x7153 0x716f 0x716f 0x716f 0x718c 0x718c 0x718c 0x71a8 0x71a8 0x71a8 0x71c4 0x71c4 0x71c4 0x71e1 0x71e1 0x71e1 0x71fd 0x71fd 0x71fd 0x721a 0x721a 0x721a 0x7236 0x7236 0x7236 0x7253 0x7253 0x7253 0x726f 0x726f 0x726f 0x728b 0x728b 0x728b 0x72a8 0x72a8 0x72a8 0x72c4 0x72c4 0x72c4 0x72e1 0x72e1 0x72e1 0x72fd 0x72fd 0x72fd 0x731a 0x731a 0x731a 0x7336 0x7336 0x7336 0x7352 0x7352 0x7352 0x736f 0x736f 0x736f 0x738b 0x738b 0x738b 0x73a8 0x73a8 0x73a8 0x73c4 0x73c4 0x73c4 0x73e1 0x73e1 0x73e1 0x73fd 0x73fd 0x73fd 0x741b 0x741b 0x741b 0x743f 0x743f 0x743f 0x7463 0x7463 0x7463 0x7486 0x7486 0x7486 0x74aa 0x74aa 0x74aa 0x74ce 0x74ce 0x74ce 0x74f2 0x74f2 0x74f2 0x7516 0x7516 0x7516 0x753a 0x753a 0x753a 0x755d 0x755d 0x755d 0x7581 0x7581 0x7581 0x75a5 0x75a5 0x75a5 0x75c9 0x75c9 0x75c9 0x75ed 0x75ed 0x75ed 0x7611 0x7611 0x7611 0x7634 0x7634 0x7634 0x7658 0x7658 0x7658 0x767c 0x767c 0x767c 0x76a0 0x76a0 0x76a0 0x76c4 0x76c4 0x76c4 0x76e8 0x76e8 0x76e8 0x770b 0x770b 0x770b 0x772f 0x772f 0x772f 0x7753 0x7753 0x7753 0x7777 0x7777 0x7777 0x779b 0x779b 0x779b 0x77bf 0x77bf 0x77bf 0x77e2 0x77e2 0x77e2 0x7806 0x7806 0x7806 0x7825 0x7825 0x7825 0x7840 0x7840 0x7840 0x785b 0x785b 0x785b 0x7876 0x7876 0x7876 0x7891 0x7891 0x7891 0x78ac 0x78ac 0x78ac 0x78c7 0x78c7 0x78c7 0x78e2 0x78e2 0x78e2 0x78fd 0x78fd 0x78fd 0x7918 0x7918 0x7918 0x7933 0x7933 0x7933 0x794e 0x794e 0x794e 0x7969 0x7969 0x7969 0x7984 0x7984 0x7984 0x799f 0x799f 0x799f 0x79ba 0x79ba 0x79ba 0x79d5 0x79d5 0x79d5 0x79f0 0x79f0 0x79f0 0x7a0b 0x7a0b 0x7a0b 0x7a26 0x7a26 0x7a26 0x7a41 0x7a41 0x7a41 0x7a5c 0x7a5c 0x7a5c 0x7a77 0x7a77 0x7a77 0x7a92 0x7a92 0x7a92 0x7aad 0x7aad 0x7aad 0x7ac8 0x7ac8 0x7ac8 0x7ae3 0x7ae3 0x7ae3 0x7afe 0x7afe 0x7afe 0x7b19 0x7b19 0x7b19 0x7b34 0x7b34 0x7b34 0x7b4f 0x7b4f 0x7b4f 0x7b6a 0x7b6a 0x7b6a 0x7b85 0x7b85 0x7b85 0x7ba0 0x7ba0 0x7ba0 0x7bbb 0x7bbb 0x7bbb 0x7bd5 0x7bd5 0x7bd5 0x7bf0 0x7bf0 0x7bf0 0x7c0b 0x7c0b 0x7c0b 0x7c23 0x7c23 0x7c23 0x7c35 0x7c35 0x7c35 0x7c47 0x7c47 0x7c47 0x7c59 0x7c59 0x7c59 0x7c6b 0x7c6b 0x7c6b 0x7c7d 0x7c7d 0x7c7d 0x7c90 0x7c90 0x7c90 0x7ca2 0x7ca2 0x7ca2 0x7cb4 0x7cb4 0x7cb4 0x7cc6 0x7cc6 0x7cc6 0x7cd8 0x7cd8 0x7cd8 0x7cea 0x7cea 0x7cea 0x7cfc 0x7cfc 0x7cfc 0x7d0f 0x7d0f 0x7d0f 0x7d21 0x7d21 0x7d21 0x7d33 0x7d33 0x7d33 0x7d45 0x7d45 0x7d45 0x7d57 0x7d57 0x7d57 0x7d69 0x7d69 0x7d69 0x7d7b 0x7d7b 0x7d7b 0x7d8e 0x7d8e 0x7d8e 0x7da0 0x7da0 0x7da0 0x7db2 0x7db2 0x7db2 0x7dc4 0x7dc4 0x7dc4 0x7dd6 0x7dd6 0x7dd6 0x7de8 0x7de8 0x7de8 0x7dfa 0x7dfa 0x7dfa 0x7e0d 0x7e0d 0x7e0d 0x7e1f 0x7e1f 0x7e1f 0x7e31 0x7e31 0x7e31 0x7e43 0x7e43 0x7e43 0x7e55 0x7e55 0x7e55 0x7e67 0x7e67 0x7e67 0x7e79 0x7e79 0x7e79 0x7e8c 0x7e8c 0x7e8c 0x7e9e 0x7e9e 0x7e9e 0x7eb0 0x7eb0 0x7eb0 0x7ec2 0x7ec2 0x7ec2 0x7ed4 0x7ed4 0x7ed4 0x7ee6 0x7ee6 0x7ee6 0x7ef8 0x7ef8 0x7ef8 0x7f0b 0x7f0b 0x7f0b 0x7f1d 0x7f1d 0x7f1d 0x7f2f 0x7f2f 0x7f2f 0x7f41 0x7f41 0x7f41 0x7f53 0x7f53 0x7f53 0x7f65 0x7f65 0x7f65 0x7f77 0x7f77 0x7f77 0x7f8a 0x7f8a 0x7f8a 0x7f9c 0x7f9c 0x7f9c 0x7fae 0x7fae 0x7fae 0x7fc0 0x7fc0 0x7fc0 0x7fd2 0x7fd2 0x7fd2 0x7fe4 0x7fe4 0x7fe4 0x7ff7 0x7ff7 0x7ff7 0x8009 0x8009 0x8009 0x801b 0x801b 0x801b 0x802b 0x802b 0x802b 0x803a 0x803a 0x803a 0x804a 0x804a 0x804a 0x8059 0x8059 0x8059 0x8069 0x8069 0x8069 0x8078 0x8078 0x8078 0x8087 0x8087 0x8087 0x8097 0x8097 0x8097 0x80a6 0x80a6 0x80a6 0x80b6 0x80b6 0x80b6 0x80c5 0x80c5 0x80c5 0x80d5 0x80d5 0x80d5 0x80e4 0x80e4 0x80e4 0x80f4 0x80f4 0x80f4 0x8103 0x8103 0x8103 0x8112 0x8112 0x8112 0x8122 0x8122 0x8122 0x8131 0x8131 0x8131 0x8141 0x8141 0x8141 0x8150 0x8150 0x8150 0x8160 0x8160 0x8160 0x816f 0x816f 0x816f 0x817e 0x817e 0x817e 0x818e 0x818e 0x818e 0x819d 0x819d 0x819d 0x81ad 0x81ad 0x81ad 0x81bc 0x81bc 0x81bc 0x81cc 0x81cc 0x81cc 0x81db 0x81db 0x81db 0x81eb 0x81eb 0x81eb 0x81fa 0x81fa 0x81fa 0x8209 0x8209 0x8209 0x8219 0x8219 0x8219 0x8228 0x8228 0x8228 0x8238 0x8238 0x8238 0x8247 0x8247 0x8247 0x8257 0x8257 0x8257 0x8266 0x8266 0x8266 0x8275 0x8275 0x8275 0x8285 0x8285 0x8285 0x8294 0x8294 0x8294 0x82a4 0x82a4 0x82a4 0x82b3 0x82b3 0x82b3 0x82c3 0x82c3 0x82c3 0x82d2 0x82d2 0x82d2 0x82e2 0x82e2 0x82e2 0x82f1 0x82f1 0x82f1 0x8300 0x8300 0x8300 0x8310 0x8310 0x8310 0x831f 0x831f 0x831f 0x832f 0x832f 0x832f 0x833e 0x833e 0x833e 0x834e 0x834e 0x834e 0x835d 0x835d 0x835d 0x836c 0x836c 0x836c 0x837c 0x837c 0x837c 0x838b 0x838b 0x838b 0x839b 0x839b 0x839b 0x83aa 0x83aa 0x83aa 0x83ba 0x83ba 0x83ba 0x83c9 0x83c9 0x83c9 0x83d8 0x83d8 0x83d8 0x83e8 0x83e8 0x83e8 0x83f7 0x83f7 0x83f7 0x8407 0x8407 0x8407 0x8416 0x8416 0x8416 0x8425 0x8425 0x8425 0x8431 0x8431 0x8431 0x843d 0x843d 0x843d 0x8449 0x8449 0x8449 0x8455 0x8455 0x8455 0x8462 0x8462 0x8462 0x846e 0x846e 0x846e 0x847a 0x847a 0x847a 0x8486 0x8486 0x8486 0x8492 0x8492 0x8492 0x849e 0x849e 0x849e 0x84aa 0x84aa 0x84aa 0x84b6 0x84b6 0x84b6 0x84c2 0x84c2 0x84c2 0x84ce 0x84ce 0x84ce 0x84da 0x84da 0x84da 0x84e7 0x84e7 0x84e7 0x84f3 0x84f3 0x84f3 0x84ff 0x84ff 0x84ff 0x850b 0x850b 0x850b 0x8517 0x8517 0x8517 0x8523 0x8523 0x8523 0x852f 0x852f 0x852f 0x853b 0x853b 0x853b 0x8547 0x8547 0x8547 0x8553 0x8553 0x8553 0x855f 0x855f 0x855f 0x856c 0x856c 0x856c 0x8578 0x8578 0x8578 0x8584 0x8584 0x8584 0x8590 0x8590 0x8590 0x859c 0x859c 0x859c 0x85a8 0x85a8 0x85a8 0x85b4 0x85b4 0x85b4 0x85c0 0x85c0 0x85c0 0x85cc 0x85cc 0x85cc 0x85d8 0x85d8 0x85d8 0x85e4 0x85e4 0x85e4 0x85f0 0x85f0 0x85f0 0x85fd 0x85fd 0x85fd 0x8609 0x8609 0x8609 0x8615 0x8615 0x8615 0x8621 0x8621 0x8621 0x862d 0x862d 0x862d 0x8639 0x8639 0x8639 0x8645 0x8645 0x8645 0x8651 0x8651 0x8651 0x865d 0x865d 0x865d 0x8669 0x8669 0x8669 0x8675 0x8675 0x8675 0x8682 0x8682 0x8682 0x868e 0x868e 0x868e 0x869a 0x869a 0x869a 0x86a6 0x86a6 0x86a6 0x86b2 0x86b2 0x86b2 0x86be 0x86be 0x86be 0x86ca 0x86ca 0x86ca 0x86d6 0x86d6 0x86d6 0x86e2 0x86e2 0x86e2 0x86ee 0x86ee 0x86ee 0x86fa 0x86fa 0x86fa 0x8707 0x8707 0x8707 0x8713 0x8713 0x8713 0x871f 0x871f 0x871f 0x872b 0x872b 0x872b 0x8737 0x8737 0x8737 0x8743 0x8743 0x8743 0x874f 0x874f 0x874f 0x875b 0x875b 0x875b 0x8767 0x8767 0x8767 0x8773 0x8773 0x8773 0x877f 0x877f 0x877f 0x878b 0x878b 0x878b 0x8798 0x8798 0x8798 0x87a4 0x87a4 0x87a4 0x87b0 0x87b0 0x87b0 0x87bc 0x87bc 0x87bc 0x87c8 0x87c8 0x87c8 0x87d4 0x87d4 0x87d4 0x87e0 0x87e0 0x87e0 0x87ec 0x87ec 0x87ec 0x87f8 0x87f8 0x87f8 0x8804 0x8804 0x8804 0x8810 0x8810 0x8810 0x881d 0x881d 0x881d 0x8829 0x8829 0x8829 0x8834 0x8834 0x8834 0x883f 0x883f 0x883f 0x884b 0x884b 0x884b 0x8856 0x8856 0x8856 0x8862 0x8862 0x8862 0x886d 0x886d 0x886d 0x8879 0x8879 0x8879 0x8884 0x8884 0x8884 0x8890 0x8890 0x8890 0x889b 0x889b 0x889b 0x88a6 0x88a6 0x88a6 0x88b2 0x88b2 0x88b2 0x88bd 0x88bd 0x88bd 0x88c9 0x88c9 0x88c9 0x88d4 0x88d4 0x88d4 0x88e0 0x88e0 0x88e0 0x88eb 0x88eb 0x88eb 0x88f6 0x88f6 0x88f6 0x8902 0x8902 0x8902 0x890d 0x890d 0x890d 0x8919 0x8919 0x8919 0x8924 0x8924 0x8924 0x8930 0x8930 0x8930 0x893b 0x893b 0x893b 0x8947 0x8947 0x8947 0x8952 0x8952 0x8952 0x895d 0x895d 0x895d 0x8969 0x8969 0x8969 0x8974 0x8974 0x8974 0x8980 0x8980 0x8980 0x898b 0x898b 0x898b 0x8997 0x8997 0x8997 0x89a2 0x89a2 0x89a2 0x89ae 0x89ae 0x89ae 0x89b9 0x89b9 0x89b9 0x89c4 0x89c4 0x89c4 0x89d0 0x89d0 0x89d0 0x89db 0x89db 0x89db 0x89e7 0x89e7 0x89e7 0x89f2 0x89f2 0x89f2 0x89fe 0x89fe 0x89fe 0x8a09 0x8a09 0x8a09 0x8a15 0x8a15 0x8a15 0x8a20 0x8a20 0x8a20 0x8a2b 0x8a2b 0x8a2b 0x8a37 0x8a37 0x8a37 0x8a42 0x8a42 0x8a42 0x8a4e 0x8a4e 0x8a4e 0x8a59 0x8a59 0x8a59 0x8a65 0x8a65 0x8a65 0x8a70 0x8a70 0x8a70 0x8a7b 0x8a7b 0x8a7b 0x8a87 0x8a87 0x8a87 0x8a92 0x8a92 0x8a92 0x8a9e 0x8a9e 0x8a9e 0x8aa9 0x8aa9 0x8aa9 0x8ab5 0x8ab5 0x8ab5 0x8ac0 0x8ac0 0x8ac0 0x8acc 0x8acc 0x8acc 0x8ad7 0x8ad7 0x8ad7 0x8ae2 0x8ae2 0x8ae2 0x8aee 0x8aee 0x8aee 0x8af9 0x8af9 0x8af9 0x8b05 0x8b05 0x8b05 0x8b10 0x8b10 0x8b10 0x8b1c 0x8b1c 0x8b1c 0x8b27 0x8b27 0x8b27 0x8b33 0x8b33 0x8b33 0x8b3e 0x8b3e 0x8b3e 0x8b49 0x8b49 0x8b49 0x8b55 0x8b55 0x8b55 0x8b60 0x8b60 0x8b60 0x8b6c 0x8b6c 0x8b6c 0x8b77 0x8b77 0x8b77 0x8b83 0x8b83 0x8b83 0x8b8e 0x8b8e 0x8b8e 0x8b99 0x8b99 0x8b99 0x8ba5 0x8ba5 0x8ba5 0x8bb0 0x8bb0 0x8bb0 0x8bbc 0x8bbc 0x8bbc 0x8bc7 0x8bc7 0x8bc7 0x8bd3 0x8bd3 0x8bd3 0x8bde 0x8bde 0x8bde 0x8bea 0x8bea 0x8bea 0x8bf5 0x8bf5 0x8bf5 0x8c00 0x8c00 0x8c00 0x8c0c 0x8c0c 0x8c0c 0x8c17 0x8c17 0x8c17 0x8c23 0x8c23 0x8c23 0x8c2e 0x8c2e 0x8c2e 0x8c38 0x8c38 0x8c38 0x8c43 0x8c43 0x8c43 0x8c4d 0x8c4d 0x8c4d 0x8c58 0x8c58 0x8c58 0x8c62 0x8c62 0x8c62 0x8c6c 0x8c6c 0x8c6c 0x8c77 0x8c77 0x8c77 0x8c81 0x8c81 0x8c81 0x8c8c 0x8c8c 0x8c8c 0x8c96 0x8c96 0x8c96 0x8ca0 0x8ca0 0x8ca0 0x8cab 0x8cab 0x8cab 0x8cb5 0x8cb5 0x8cb5 0x8cc0 0x8cc0 0x8cc0 0x8cca 0x8cca 0x8cca 0x8cd4 0x8cd4 0x8cd4 0x8cdf 0x8cdf 0x8cdf 0x8ce9 0x8ce9 0x8ce9 0x8cf4 0x8cf4 0x8cf4 0x8cfe 0x8cfe 0x8cfe 0x8d09 0x8d09 0x8d09 0x8d13 0x8d13 0x8d13 0x8d1d 0x8d1d 0x8d1d 0x8d28 0x8d28 0x8d28 0x8d32 0x8d32 0x8d32 0x8d3d 0x8d3d 0x8d3d 0x8d47 0x8d47 0x8d47 0x8d51 0x8d51 0x8d51 0x8d5c 0x8d5c 0x8d5c 0x8d66 0x8d66 0x8d66 0x8d71 0x8d71 0x8d71 0x8d7b 0x8d7b 0x8d7b 0x8d85 0x8d85 0x8d85 0x8d90 0x8d90 0x8d90 0x8d9a 0x8d9a 0x8d9a 0x8da5 0x8da5 0x8da5 0x8daf 0x8daf 0x8daf 0x8db9 0x8db9 0x8db9 0x8dc4 0x8dc4 0x8dc4 0x8dce 0x8dce 0x8dce 0x8dd9 0x8dd9 0x8dd9 0x8de3 0x8de3 0x8de3 0x8ded 0x8ded 0x8ded 0x8df8 0x8df8 0x8df8 0x8e02 0x8e02 0x8e02 0x8e0d 0x8e0d 0x8e0d 0x8e17 0x8e17 0x8e17 0x8e22 0x8e22 0x8e22 0x8e2c 0x8e2c 0x8e2c 0x8e36 0x8e36 0x8e36 0x8e41 0x8e41 0x8e41 0x8e4b 0x8e4b 0x8e4b 0x8e56 0x8e56 0x8e56 0x8e60 0x8e60 0x8e60 0x8e6a 0x8e6a 0x8e6a 0x8e75 0x8e75 0x8e75 0x8e7f 0x8e7f 0x8e7f 0x8e8a 0x8e8a 0x8e8a 0x8e94 0x8e94 0x8e94 0x8e9e 0x8e9e 0x8e9e 0x8ea9 0x8ea9 0x8ea9 0x8eb3 0x8eb3 0x8eb3 0x8ebe 0x8ebe 0x8ebe 0x8ec8 0x8ec8 0x8ec8 0x8ed2 0x8ed2 0x8ed2 0x8edd 0x8edd 0x8edd 0x8ee7 0x8ee7 0x8ee7 0x8ef2 0x8ef2 0x8ef2 0x8efc 0x8efc 0x8efc 0x8f07 0x8f07 0x8f07 0x8f11 0x8f11 0x8f11 0x8f1b 0x8f1b 0x8f1b 0x8f26 0x8f26 0x8f26 0x8f30 0x8f30 0x8f30 0x8f3b 0x8f3b 0x8f3b 0x8f45 0x8f45 0x8f45 0x8f4f 0x8f4f 0x8f4f 0x8f5a 0x8f5a 0x8f5a 0x8f64 0x8f64 0x8f64 0x8f6f 0x8f6f 0x8f6f 0x8f79 0x8f79 0x8f79 0x8f83 0x8f83 0x8f83 0x8f8e 0x8f8e 0x8f8e 0x8f98 0x8f98 0x8f98 0x8fa3 0x8fa3 0x8fa3 0x8fad 0x8fad 0x8fad 0x8fb7 0x8fb7 0x8fb7 0x8fc2 0x8fc2 0x8fc2 0x8fcc 0x8fcc 0x8fcc 0x8fd7 0x8fd7 0x8fd7 0x8fe1 0x8fe1 0x8fe1 0x8feb 0x8feb 0x8feb 0x8ff6 0x8ff6 0x8ff6 0x9000 0x9000 0x9000 0x900b 0x900b 0x900b 0x9015 0x9015 0x9015 0x9020 0x9020 0x9020 0x902a 0x902a 0x902a 0x9034 0x9034 0x9034 0x903e 0x903e 0x903e 0x9048 0x9048 0x9048 0x9052 0x9052 0x9052 0x905c 0x905c 0x905c 0x9066 0x9066 0x9066 0x9070 0x9070 0x9070 0x907a 0x907a 0x907a 0x9084 0x9084 0x9084 0x908e 0x908e 0x908e 0x9098 0x9098 0x9098 0x90a2 0x90a2 0x90a2 0x90ac 0x90ac 0x90ac 0x90b6 0x90b6 0x90b6 0x90c0 0x90c0 0x90c0 0x90ca 0x90ca 0x90ca 0x90d4 0x90d4 0x90d4 0x90de 0x90de 0x90de 0x90e8 0x90e8 0x90e8 0x90f2 0x90f2 0x90f2 0x90fc 0x90fc 0x90fc 0x9106 0x9106 0x9106 0x9110 0x9110 0x9110 0x911a 0x911a 0x911a 0x9123 0x9123 0x9123 0x912d 0x912d 0x912d 0x9137 0x9137 0x9137 0x9141 0x9141 0x9141 0x914b 0x914b 0x914b 0x9155 0x9155 0x9155 0x915f 0x915f 0x915f 0x9169 0x9169 0x9169 0x9173 0x9173 0x9173 0x917d 0x917d 0x917d 0x9187 0x9187 0x9187 0x9191 0x9191 0x9191 0x919b 0x919b 0x919b 0x91a5 0x91a5 0x91a5 0x91af 0x91af 0x91af 0x91b9 0x91b9 0x91b9 0x91c3 0x91c3 0x91c3 0x91cd 0x91cd 0x91cd 0x91d7 0x91d7 0x91d7 0x91e1 0x91e1 0x91e1 0x91eb 0x91eb 0x91eb 0x91f5 0x91f5 0x91f5 0x91ff 0x91ff 0x91ff 0x9209 0x9209 0x9209 0x9213 0x9213 0x9213 0x921d 0x921d 0x921d 0x9227 0x9227 0x9227 0x9231 0x9231 0x9231 0x923b 0x923b 0x923b 0x9245 0x9245 0x9245 0x924f 0x924f 0x924f 0x9259 0x9259 0x9259 0x9263 0x9263 0x9263 0x926d 0x926d 0x926d 0x9277 0x9277 0x9277 0x9281 0x9281 0x9281 0x928b 0x928b 0x928b 0x9295 0x9295 0x9295 0x929f 0x929f 0x929f 0x92a8 0x92a8 0x92a8 0x92b2 0x92b2 0x92b2 0x92bc 0x92bc 0x92bc 0x92c6 0x92c6 0x92c6 0x92d0 0x92d0 0x92d0 0x92da 0x92da 0x92da 0x92e4 0x92e4 0x92e4 0x92ee 0x92ee 0x92ee 0x92f8 0x92f8 0x92f8 0x9302 0x9302 0x9302 0x930c 0x930c 0x930c 0x9316 0x9316 0x9316 0x9320 0x9320 0x9320 0x932a 0x932a 0x932a 0x9334 0x9334 0x9334 0x933e 0x933e 0x933e 0x9348 0x9348 0x9348 0x9352 0x9352 0x9352 0x935c 0x935c 0x935c 0x9366 0x9366 0x9366 0x9370 0x9370 0x9370 0x937a 0x937a 0x937a 0x9384 0x9384 0x9384 0x938e 0x938e 0x938e 0x9398 0x9398 0x9398 0x93a2 0x93a2 0x93a2 0x93ac 0x93ac 0x93ac 0x93b6 0x93b6 0x93b6 0x93c0 0x93c0 0x93c0 0x93ca 0x93ca 0x93ca 0x93d4 0x93d4 0x93d4 0x93de 0x93de 0x93de 0x93e8 0x93e8 0x93e8 0x93f2 0x93f2 0x93f2 0x93fc 0x93fc 0x93fc 0x9406 0x9406 0x9406 0x9410 0x9410 0x9410 0x941a 0x941a 0x941a 0x9423 0x9423 0x9423 0x942d 0x942d 0x942d 0x9437 0x9437 0x9437 0x9440 0x9440 0x9440 0x9449 0x9449 0x9449 0x9451 0x9451 0x9451 0x945a 0x945a 0x945a 0x9463 0x9463 0x9463 0x946c 0x946c 0x946c 0x9475 0x9475 0x9475 0x947e 0x947e 0x947e 0x9486 0x9486 0x9486 0x948f 0x948f 0x948f 0x9498 0x9498 0x9498 0x94a1 0x94a1 0x94a1 0x94aa 0x94aa 0x94aa 0x94b3 0x94b3 0x94b3 0x94bb 0x94bb 0x94bb 0x94c4 0x94c4 0x94c4 0x94cd 0x94cd 0x94cd 0x94d6 0x94d6 0x94d6 0x94df 0x94df 0x94df 0x94e8 0x94e8 0x94e8 0x94f0 0x94f0 0x94f0 0x94f9 0x94f9 0x94f9 0x9502 0x9502 0x9502 0x950b 0x950b 0x950b 0x9514 0x9514 0x9514 0x951d 0x951d 0x951d 0x9525 0x9525 0x9525 0x952e 0x952e 0x952e 0x9537 0x9537 0x9537 0x9540 0x9540 0x9540 0x9549 0x9549 0x9549 0x9552 0x9552 0x9552 0x955a 0x955a 0x955a 0x9563 0x9563 0x9563 0x956c 0x956c 0x956c 0x9575 0x9575 0x9575 0x957e 0x957e 0x957e 0x9587 0x9587 0x9587 0x958f 0x958f 0x958f 0x9598 0x9598 0x9598 0x95a1 0x95a1 0x95a1 0x95aa 0x95aa 0x95aa 0x95b3 0x95b3 0x95b3 0x95bc 0x95bc 0x95bc 0x95c4 0x95c4 0x95c4 0x95cd 0x95cd 0x95cd 0x95d6 0x95d6 0x95d6 0x95df 0x95df 0x95df 0x95e8 0x95e8 0x95e8 0x95f1 0x95f1 0x95f1 0x95f9 0x95f9 0x95f9 0x9602 0x9602 0x9602 0x960b 0x960b 0x960b 0x9614 0x9614 0x9614 0x961d 0x961d 0x961d 0x9626 0x9626 0x9626 0x962e 0x962e 0x962e 0x9637 0x9637 0x9637 0x9640 0x9640 0x9640 0x9649 0x9649 0x9649 0x9652 0x9652 0x9652 0x965b 0x965b 0x965b 0x9663 0x9663 0x9663 0x966c 0x966c 0x966c 0x9675 0x9675 0x9675 0x967e 0x967e 0x967e 0x9687 0x9687 0x9687 0x9690 0x9690 0x9690 0x9698 0x9698 0x9698 0x96a1 0x96a1 0x96a1 0x96aa 0x96aa 0x96aa 0x96b3 0x96b3 0x96b3 0x96bc 0x96bc 0x96bc 0x96c5 0x96c5 0x96c5 0x96cd 0x96cd 0x96cd 0x96d6 0x96d6 0x96d6 0x96df 0x96df 0x96df 0x96e8 0x96e8 0x96e8 0x96f1 0x96f1 0x96f1 0x96f9 0x96f9 0x96f9 0x9702 0x9702 0x9702 0x970b 0x970b 0x970b 0x9714 0x9714 0x9714 0x971d 0x971d 0x971d 0x9726 0x9726 0x9726 0x972e 0x972e 0x972e 0x9737 0x9737 0x9737 0x9740 0x9740 0x9740 0x9749 0x9749 0x9749 0x9752 0x9752 0x9752 0x975b 0x975b 0x975b 0x9763 0x9763 0x9763 0x976c 0x976c 0x976c 0x9775 0x9775 0x9775 0x977e 0x977e 0x977e 0x9787 0x9787 0x9787 0x9790 0x9790 0x9790 0x9798 0x9798 0x9798 0x97a1 0x97a1 0x97a1 0x97aa 0x97aa 0x97aa 0x97b3 0x97b3 0x97b3 0x97bc 0x97bc 0x97bc 0x97c5 0x97c5 0x97c5 0x97cd 0x97cd 0x97cd 0x97d6 0x97d6 0x97d6 0x97df 0x97df 0x97df 0x97e8 0x97e8 0x97e8 0x97f1 0x97f1 0x97f1 0x97fa 0x97fa 0x97fa 0x9802 0x9802 0x9802 0x980b 0x980b 0x980b 0x9814 0x9814 0x9814 0x981d 0x981d 0x981d 0x9826 0x9826 0x9826 0x982f 0x982f 0x982f 0x9837 0x9837 0x9837 0x983f 0x983f 0x983f 0x9847 0x9847 0x9847 0x984f 0x984f 0x984f 0x9857 0x9857 0x9857 0x985f 0x985f 0x985f 0x9867 0x9867 0x9867 0x986e 0x986e 0x986e 0x9876 0x9876 0x9876 0x987e 0x987e 0x987e 0x9886 0x9886 0x9886 0x988e 0x988e 0x988e 0x9896 0x9896 0x9896 0x989e 0x989e 0x989e 0x98a5 0x98a5 0x98a5 0x98ad 0x98ad 0x98ad 0x98b5 0x98b5 0x98b5 0x98bd 0x98bd 0x98bd 0x98c5 0x98c5 0x98c5 0x98cd 0x98cd 0x98cd 0x98d5 0x98d5 0x98d5 0x98dc 0x98dc 0x98dc 0x98e4 0x98e4 0x98e4 0x98ec 0x98ec 0x98ec 0x98f4 0x98f4 0x98f4 0x98fc 0x98fc 0x98fc 0x9904 0x9904 0x9904 0x990c 0x990c 0x990c 0x9913 0x9913 0x9913 0x991b 0x991b 0x991b 0x9923 0x9923 0x9923 0x992b 0x992b 0x992b 0x9933 0x9933 0x9933 0x993b 0x993b 0x993b 0x9943 0x9943 0x9943 0x994a 0x994a 0x994a 0x9952 0x9952 0x9952 0x995a 0x995a 0x995a 0x9962 0x9962 0x9962 0x996a 0x996a 0x996a 0x9972 0x9972 0x9972 0x997a 0x997a 0x997a 0x9981 0x9981 0x9981 0x9989 0x9989 0x9989 0x9991 0x9991 0x9991 0x9999 0x9999 0x9999 0x99a1 0x99a1 0x99a1 0x99a9 0x99a9 0x99a9 0x99b1 0x99b1 0x99b1 0x99b8 0x99b8 0x99b8 0x99c0 0x99c0 0x99c0 0x99c8 0x99c8 0x99c8 0x99d0 0x99d0 0x99d0 0x99d8 0x99d8 0x99d8 0x99e0 0x99e0 0x99e0 0x99e8 0x99e8 0x99e8 0x99ef 0x99ef 0x99ef 0x99f7 0x99f7 0x99f7 0x99ff 0x99ff 0x99ff 0x9a07 0x9a07 0x9a07 0x9a0f 0x9a0f 0x9a0f 0x9a17 0x9a17 0x9a17 0x9a1f 0x9a1f 0x9a1f 0x9a26 0x9a26 0x9a26 0x9a2e 0x9a2e 0x9a2e 0x9a36 0x9a36 0x9a36 0x9a3e 0x9a3e 0x9a3e 0x9a46 0x9a46 0x9a46 0x9a4e 0x9a4e 0x9a4e 0x9a56 0x9a56 0x9a56 0x9a5d 0x9a5d 0x9a5d 0x9a65 0x9a65 0x9a65 0x9a6d 0x9a6d 0x9a6d 0x9a75 0x9a75 0x9a75 0x9a7d 0x9a7d 0x9a7d 0x9a85 0x9a85 0x9a85 0x9a8d 0x9a8d 0x9a8d 0x9a94 0x9a94 0x9a94 0x9a9c 0x9a9c 0x9a9c 0x9aa4 0x9aa4 0x9aa4 0x9aac 0x9aac 0x9aac 0x9ab4 0x9ab4 0x9ab4 0x9abc 0x9abc 0x9abc 0x9ac4 0x9ac4 0x9ac4 0x9acb 0x9acb 0x9acb 0x9ad3 0x9ad3 0x9ad3 0x9adb 0x9adb 0x9adb 0x9ae3 0x9ae3 0x9ae3 0x9aeb 0x9aeb 0x9aeb 0x9af3 0x9af3 0x9af3 0x9afb 0x9afb 0x9afb 0x9b02 0x9b02 0x9b02 0x9b0a 0x9b0a 0x9b0a 0x9b12 0x9b12 0x9b12 0x9b1a 0x9b1a 0x9b1a 0x9b22 0x9b22 0x9b22 0x9b2a 0x9b2a 0x9b2a 0x9b32 0x9b32 0x9b32 0x9b39 0x9b39 0x9b39 0x9b41 0x9b41 0x9b41 0x9b49 0x9b49 0x9b49 0x9b51 0x9b51 0x9b51 0x9b59 0x9b59 0x9b59 0x9b61 0x9b61 0x9b61 0x9b69 0x9b69 0x9b69 0x9b70 0x9b70 0x9b70 0x9b78 0x9b78 0x9b78 0x9b80 0x9b80 0x9b80 0x9b88 0x9b88 0x9b88 0x9b90 0x9b90 0x9b90 0x9b98 0x9b98 0x9b98 0x9ba0 0x9ba0 0x9ba0 0x9ba7 0x9ba7 0x9ba7 0x9baf 0x9baf 0x9baf 0x9bb7 0x9bb7 0x9bb7 0x9bbf 0x9bbf 0x9bbf 0x9bc7 0x9bc7 0x9bc7 0x9bcf 0x9bcf 0x9bcf 0x9bd7 0x9bd7 0x9bd7 0x9bde 0x9bde 0x9bde 0x9be6 0x9be6 0x9be6 0x9bee 0x9bee 0x9bee 0x9bf6 0x9bf6 0x9bf6 0x9bfe 0x9bfe 0x9bfe 0x9c06 0x9c06 0x9c06 0x9c0e 0x9c0e 0x9c0e 0x9c15 0x9c15 0x9c15 0x9c1d 0x9c1d 0x9c1d 0x9c25 0x9c25 0x9c25 0x9c2d 0x9c2d 0x9c2d 0x9c35 0x9c35 0x9c35 0x9c3d 0x9c3d 0x9c3d 0x9c44 0x9c44 0x9c44 0x9c4b 0x9c4b 0x9c4b 0x9c53 0x9c53 0x9c53 0x9c5a 0x9c5a 0x9c5a 0x9c61 0x9c61 0x9c61 0x9c69 0x9c69 0x9c69 0x9c70 0x9c70 0x9c70 0x9c77 0x9c77 0x9c77 0x9c7f 0x9c7f 0x9c7f 0x9c86 0x9c86 0x9c86 0x9c8d 0x9c8d 0x9c8d 0x9c95 0x9c95 0x9c95 0x9c9c 0x9c9c 0x9c9c 0x9ca3 0x9ca3 0x9ca3 0x9cab 0x9cab 0x9cab 0x9cb2 0x9cb2 0x9cb2 0x9cb9 0x9cb9 0x9cb9 0x9cc1 0x9cc1 0x9cc1 0x9cc8 0x9cc8 0x9cc8 0x9ccf 0x9ccf 0x9ccf 0x9cd7 0x9cd7 0x9cd7 0x9cde 0x9cde 0x9cde 0x9ce5 0x9ce5 0x9ce5 0x9ced 0x9ced 0x9ced 0x9cf4 0x9cf4 0x9cf4 0x9cfb 0x9cfb 0x9cfb 0x9d03 0x9d03 0x9d03 0x9d0a 0x9d0a 0x9d0a 0x9d12 0x9d12 0x9d12 0x9d19 0x9d19 0x9d19 0x9d20 0x9d20 0x9d20 0x9d28 0x9d28 0x9d28 0x9d2f 0x9d2f 0x9d2f 0x9d36 0x9d36 0x9d36 0x9d3e 0x9d3e 0x9d3e 0x9d45 0x9d45 0x9d45 0x9d4c 0x9d4c 0x9d4c 0x9d54 0x9d54 0x9d54 0x9d5b 0x9d5b 0x9d5b 0x9d62 0x9d62 0x9d62 0x9d6a 0x9d6a 0x9d6a 0x9d71 0x9d71 0x9d71 0x9d78 0x9d78 0x9d78 0x9d80 0x9d80 0x9d80 0x9d87 0x9d87 0x9d87 0x9d8e 0x9d8e 0x9d8e 0x9d96 0x9d96 0x9d96 0x9d9d 0x9d9d 0x9d9d 0x9da4 0x9da4 0x9da4 0x9dac 0x9dac 0x9dac 0x9db3 0x9db3 0x9db3 0x9dba 0x9dba 0x9dba 0x9dc2 0x9dc2 0x9dc2 0x9dc9 0x9dc9 0x9dc9 0x9dd0 0x9dd0 0x9dd0 0x9dd8 0x9dd8 0x9dd8 0x9ddf 0x9ddf 0x9ddf 0x9de6 0x9de6 0x9de6 0x9dee 0x9dee 0x9dee 0x9df5 0x9df5 0x9df5 0x9dfc 0x9dfc 0x9dfc 0x9e04 0x9e04 0x9e04 0x9e0b 0x9e0b 0x9e0b 0x9e13 0x9e13 0x9e13 0x9e1a 0x9e1a 0x9e1a 0x9e21 0x9e21 0x9e21 0x9e29 0x9e29 0x9e29 0x9e30 0x9e30 0x9e30 0x9e37 0x9e37 0x9e37 0x9e3f 0x9e3f 0x9e3f 0x9e46 0x9e46 0x9e46 0x9e4d 0x9e4d 0x9e4d 0x9e55 0x9e55 0x9e55 0x9e5c 0x9e5c 0x9e5c 0x9e63 0x9e63 0x9e63 0x9e6b 0x9e6b 0x9e6b 0x9e72 0x9e72 0x9e72 0x9e79 0x9e79 0x9e79 0x9e81 0x9e81 0x9e81 0x9e88 0x9e88 0x9e88 0x9e8f 0x9e8f 0x9e8f 0x9e97 0x9e97 0x9e97 0x9e9e 0x9e9e 0x9e9e 0x9ea5 0x9ea5 0x9ea5 0x9ead 0x9ead 0x9ead 0x9eb4 0x9eb4 0x9eb4 0x9ebb 0x9ebb 0x9ebb 0x9ec3 0x9ec3 0x9ec3 0x9eca 0x9eca 0x9eca 0x9ed1 0x9ed1 0x9ed1 0x9ed9 0x9ed9 0x9ed9 0x9ee0 0x9ee0 0x9ee0 0x9ee7 0x9ee7 0x9ee7 0x9eef 0x9eef 0x9eef 0x9ef6 0x9ef6 0x9ef6 0x9efd 0x9efd 0x9efd 0x9f05 0x9f05 0x9f05 0x9f0c 0x9f0c 0x9f0c 0x9f14 0x9f14 0x9f14 0x9f1b 0x9f1b 0x9f1b 0x9f22 0x9f22 0x9f22 0x9f2a 0x9f2a 0x9f2a 0x9f31 0x9f31 0x9f31 0x9f38 0x9f38 0x9f38 0x9f40 0x9f40 0x9f40 0x9f47 0x9f47 0x9f47 0x9f4e 0x9f4e 0x9f4e 0x9f56 0x9f56 0x9f56 0x9f5d 0x9f5d 0x9f5d 0x9f64 0x9f64 0x9f64 0x9f6c 0x9f6c 0x9f6c 0x9f73 0x9f73 0x9f73 0x9f7a 0x9f7a 0x9f7a 0x9f82 0x9f82 0x9f82 0x9f89 0x9f89 0x9f89 0x9f90 0x9f90 0x9f90 0x9f98 0x9f98 0x9f98 0x9f9f 0x9f9f 0x9f9f 0x9fa6 0x9fa6 0x9fa6 0x9fae 0x9fae 0x9fae 0x9fb5 0x9fb5 0x9fb5 0x9fbc 0x9fbc 0x9fbc 0x9fc4 0x9fc4 0x9fc4 0x9fcb 0x9fcb 0x9fcb 0x9fd2 0x9fd2 0x9fd2 0x9fda 0x9fda 0x9fda 0x9fe1 0x9fe1 0x9fe1 0x9fe8 0x9fe8 0x9fe8 0x9ff0 0x9ff0 0x9ff0 0x9ff7 0x9ff7 0x9ff7 0x9fff 0x9fff 0x9fff>;
