panel-s-wuxga-8-0.c listed as following
#include <linux/delay.h>
#include <linux/gpio.h>
#include <linux/regulator/consumer.h>
#include “…/dc.h”
#include “board.h”
#include “board-panel.h”
#define DSI_PANEL_RESET 1
static bool reg_requested;
static struct regulator *avdd_lcd_3v0;
static struct regulator *dvdd_lcd_1v8;
static struct regulator *vpp_lcd;
static struct regulator *vmm_lcd;
static struct device *dc_dev;
static u16 en_panel_rst;
static u16 en_backlight;
static u16 en_panel;
static bool vmm_vpp_fixed_regulators;
static int dsi_s_wuxga_8_0_regulator_get(struct device *dev)
int err = 0;
if (reg_requested)
return 0;
avdd_lcd_3v0 = regulator_get(dev, "avdd_lcd");
if (IS_ERR_OR_NULL(avdd_lcd_3v0)) {
pr_err("avdd_lcd regulator get failed\n");
err = PTR_ERR(avdd_lcd_3v0);
avdd_lcd_3v0 = NULL;
goto fail;
dvdd_lcd_1v8 = regulator_get(dev, "dvdd_lcd");
if (IS_ERR_OR_NULL(dvdd_lcd_1v8)) {
pr_err("dvdd_lcd_1v8 regulator get failed\n");
err = PTR_ERR(dvdd_lcd_1v8);
dvdd_lcd_1v8 = NULL;
goto dvdd_lcd_fail;
vpp_lcd = regulator_get(dev, “outp”);
if (IS_ERR_OR_NULL(vpp_lcd)) {
pr_err(“vpp_lcd regulator get failed\n”);
err = PTR_ERR(vpp_lcd);
vpp_lcd = NULL;
goto vpp_lcd_fail;
vmm_lcd = regulator_get(dev, "outn");
if (IS_ERR_OR_NULL(vmm_lcd)) {
pr_err("vmm_lcd regulator get failed\n");
err = PTR_ERR(vmm_lcd);
vmm_lcd = NULL;
goto vmm_lcd_fail;
reg_requested = true;
return 0;
vmm_lcd_fail:
if (vpp_lcd) {
regulator_put(vpp_lcd);
vpp_lcd = NULL;
vpp_lcd_fail:
if (dvdd_lcd_1v8) {
regulator_put(dvdd_lcd_1v8);
dvdd_lcd_fail:
if (avdd_lcd_3v0) {
regulator_put(avdd_lcd_3v0);
fail:
return err;
static int dsi_s_wuxga_8_0_enable(struct device *dev)
int err = 0;
err = tegra_panel_check_regulator_dt_support("s,wuxga-8-0",
&panel_of);
if (err < 0) {
pr_err("display regulator dt check failed\n");
goto fail;
} else {
vmm_vpp_fixed_regulators = panel_of.en_vmm_vpp_i2c_config;
err = dsi_s_wuxga_8_0_regulator_get(dev);
if (err < 0) {
pr_err("dsi regulator get failed\n");
goto fail;
err = tegra_panel_gpio_get_dt("s,wuxga-8-0", &panel_of);
if (err < 0) {
pr_err("display gpio get failed\n");
goto fail;
if (gpio_is_valid(panel_of.panel_gpio[TEGRA_GPIO_RESET]))
en_panel_rst = panel_of.panel_gpio[TEGRA_GPIO_RESET];
else {
pr_err("display reset gpio invalid\n");
goto fail;
if (gpio_is_valid(panel_of.panel_gpio[TEGRA_GPIO_BL_ENABLE]))
en_backlight = panel_of.panel_gpio[TEGRA_GPIO_BL_ENABLE];
else
pr_err("display backlight enable gpio invalid\n");
if (gpio_is_valid(panel_of.panel_gpio[TEGRA_GPIO_PANEL_EN]))
en_panel = panel_of.panel_gpio[TEGRA_GPIO_PANEL_EN];
else
pr_err("display panel enable gpio invalid\n");
if (dvdd_lcd_1v8) {
err = regulator_enable(dvdd_lcd_1v8);
if (err < 0) {
pr_err("dvdd_lcd regulator enable failed\n");
goto fail;
usleep_range(1000, 1500);
if (avdd_lcd_3v0) {
err = regulator_enable(avdd_lcd_3v0);
if (err < 0) {
pr_err("avdd_lcd regulator enable failed\n");
goto fail;
usleep_range(3000, 3500);
if (gpio_is_valid(en_backlight))
gpio_direction_output(en_backlight, 1);
if (en_panel)
gpio_direction_output(en_panel, 1);
if (vpp_lcd) {
err = regulator_enable(vpp_lcd);
if (err < 0) {
pr_err("vpp_lcd regulator enable failed\n");
goto fail;
if (!vmm_vpp_fixed_regulators) {
err = regulator_set_voltage(vpp_lcd, 5500000, 5500000);
if (err < 0) {
pr_err("vpp_lcd regulator failed changing voltage\n");
goto fail;
usleep_range(2000, 2500);
if (vmm_lcd) {
err = regulator_enable(vmm_lcd);
if (err < 0) {
pr_err("vmm_lcd regulator enable failed\n");
goto fail;
err = regulator_set_voltage(vmm_lcd, 5500000, 5500000);
if (err < 0) {
pr_err("vmm_lcd regulator failed changing voltage\n");
goto fail;
usleep_range(15000, 15500);
#if DSI_PANEL_RESET
if (!tegra_dc_initialized(dev)) {
err = gpio_direction_output(en_panel_rst, 1);
if (err < 0) {
pr_err(“setting display reset gpio value failed\n”);
goto fail;
err = gpio_direction_output(en_panel_rst, 0);
if (err < 0) {
pr_err(“setting display reset gpio value 0 failed\n”);
goto fail;
if (err < 0) {
pr_err(“setting display reset gpio value 1 failed\n”);
goto fail;
#endif
dc_dev = dev;
return 0;
fail:
return err;
static int dsi_s_wuxga_8_0_disable(struct device dev)
if (gpio_is_valid(en_panel_rst)) {
/ Wait for 50ms before triggering panel reset */
msleep(50);
gpio_set_value(en_panel_rst, 0);
usleep_range(500, 1000);
} else
pr_err(“ERROR! display reset gpio invalid\n”);
if (vmm_lcd)
regulator_disable(vmm_lcd);
if (vpp_lcd)
regulator_disable(vpp_lcd);
msleep(125);
if (gpio_is_valid(en_panel))
gpio_direction_output(en_panel, 0);
gpio_direction_output(en_backlight, 0);
if (avdd_lcd_3v0)
regulator_disable(avdd_lcd_3v0);
msleep(780);
if (dvdd_lcd_1v8)
regulator_disable(dvdd_lcd_1v8);
/* Min delay of 140ms required to avoid turning
* the panel on too soon after power off */
msleep(140);
dc_dev = NULL;
return 0;
static int dsi_s_wuxga_8_0_postsuspend(void)
return 0;
static int dsi_s_wuxga_8_0_bl_notify(struct device *dev, int brightness)
int cur_sd_brightness;
struct backlight_device *bl = NULL;
struct pwm_bl_data *pb = NULL;
bl = (struct backlight_device *)dev_get_drvdata(dev);
pb = (struct pwm_bl_data *)dev_get_drvdata(&bl->dev);
#ifdef CONFIG_TEGRA_NVDISPLAY
tegra_sd_check_prism_thresh(dc_dev, brightness);
#else
nvsd_check_prism_thresh(dc_dev, brightness);
#endif
cur_sd_brightness = atomic_read(&sd_brightness);
/* SD brightness is a percentage */
brightness = (brightness * cur_sd_brightness) / 255;
/* Apply any backlight response curve */
if (brightness > 255)
pr_info("Error: Brightness > 255!\n");
else if (pb->bl_measured)
brightness = pb->bl_measured[brightness];
return brightness;
static int dsi_s_wuxga_8_0_check_fb(struct device *dev,
struct fb_info *info)
struct platform_device *pdev = NULL;
pdev = to_platform_device(bus_find_device_by_name(
&platform_bus_type, NULL, “tegradc.0”));
return info->device == &pdev->dev;
static struct pwm_bl_data_dt_ops dsi_s_wuxga_8_0_pwm_bl_ops = {
.notify = dsi_s_wuxga_8_0_bl_notify,
.check_fb = dsi_s_wuxga_8_0_check_fb,
.blnode_compatible = “s,wuxga-8-0-bl”,
struct tegra_panel_ops dsi_s_wuxga_8_0_ops = {
.enable = dsi_s_wuxga_8_0_enable,
.disable = dsi_s_wuxga_8_0_disable,
.postsuspend = dsi_s_wuxga_8_0_postsuspend,
.pwm_bl_ops = &dsi_s_wuxga_8_0_pwm_bl_ops,
I modify the file “tegra186-quill-common.dtsi”, comment the “nvidia,panel-en-gpio” ,because i never use this pin, i only use the “panel-rst-gpio” and “panel-bl-en-gpio”.
dsi { /* dsi@15300000 */
nvidia,dsi-controller-vs = <DSI_VS_1>;
status = "disabled";
panel-s-wuxga-8-0 {
nvidia,panel-rst-gpio = <&tegra_main_gpio TEGRA_MAIN_GPIO(P, 3) 1>; /* PP3 */
nvidia,panel-bl-pwm-gpio = <&tegra_aon_gpio TEGRA_AON_GPIO(U, 0) 1>; /* PU0 */
nvidia,panel-bl-en-gpio = <&tegra_aon_gpio TEGRA_AON_GPIO(U, 3) 1>; /* PU3 */
/* nvidia,panel-en-gpio = <&gpio_i2c_0_77 4 1>; tca9539 0x77 Pin 4 */
nvidia,en-vmm-vpp-with-i2c-config;
nvidia,default_color_space = <0>;
disp-default-out {
nvidia,out-parent-clk = "pll_d";
nvidia,out-xres = <720>;
nvidia,out-yres = <1280>;
