Here’s the log - it gets stuck on the last log line:
[0000.212] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-c368a720)
[0000.221] I> Boot-device: eMMC
[0000.228] I> sdmmc bdev is already initialized
[0000.233] I> pmic: reset reason (nverc) : 0x43
[0000.266] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.286] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.292] W> No valid slot number is found in scratch register
[0000.297] W> Return default slot: _a
[0000.301] I> A/B: bin_type (16) slot 0
[0000.304] I> Loading partition bpmp-fw at 0xd7800000
[0000.309] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.315] I> Addr: 0xd7800000, start-block: 29417480, num_blocks: 1
[0000.339] I> Binary(16) of size 534416 is loaded @ 0xd7800000
[0000.345] W> No valid slot number is found in scratch register
[0000.351] W> Return default slot: _a
[0000.354] I> A/B: bin_type (17) slot 0
[0000.358] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.363] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.368] I> Addr: 0xd79f0000, start-block: 29419896, num_blocks: 1
[0000.387] I> Binary(17) of size 113248 is loaded @ 0xd79e4400
[0000.416] I> Loading SCE-FW ...
[0000.419] W> No valid slot number is found in scratch register
[0000.424] W> Return default slot: _a
[0000.428] I> A/B: bin_type (12) slot 0
[0000.431] I> Loading partition sce-fw at 0xd7300000
[0000.436] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.442] I> Addr: 0xd7300000, start-block: 29423992, num_blocks: 1
[0000.461] I> Binary(12) of size 125632 is loaded @ 0xd7300000
[0000.466] I> Init SCE
[0000.469] I> Loading APE-FW ...
[0000.472] W> No valid slot number is found in scratch register
[0000.477] W> Return default slot: _a
[0000.481] I> A/B: bin_type (11) slot 0
[0000.484] I> Loading partition adsp-fw at 0xd7400000
[0000.489] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.495] I> Addr: 0xd7400000, start-block: 29401096, num_blocks: 1
[0000.514] I> Binary(11) of size 77216 is loaded @ 0xd7400000
[0000.519] I> Copy BTCM section
[0000.522] W> No valid slot number is found in scratch register
[0000.528] W> Return default slot: _a
[0000.531] I> A/B: bin_type (13) slot 0
[0000.535] I> Loading partition cpu-bootloader at 0x96000000
[0000.541] I> Reading two headers - addr:0x96000000 blocks:1
[0000.546] I> Addr: 0x96000000, start-block: 29380616, num_blocks: 1
[0000.567] I> Binary(13) of size 308800 is loaded @ 0x96000000
[0000.573] W> No valid slot number is found in scratch register
[0000.578] W> Return default slot: _a
[0000.582] I> A/B: bin_type (20) slot 0
[0000.585] I> Loading partition bootloader-dtb at 0x85205400
[0000.591] I> Reading two headers - addr:0x85205400 blocks:1
[0000.596] I> Addr: 0x85205400, start-block: 29382664, num_blocks: 1
[0000.616] I> Binary(20) of size 192320 is loaded @ 0x85205400
[0000.622] W> No valid slot number is found in scratch register
[0000.627] W> Return default slot: _a
[0000.631] I> A/B: bin_type (14) slot 0
[0000.634] I> Loading partition secure-os at 0x85305600
[0000.639] I> Reading two headers - addr:0x85305600 blocks:1
[0000.645] I> Addr: 0x85305600, start-block: 29384712, num_blocks: 1
[0000.667] I> Binary(14) of size 402864 is loaded @ 0x85305600
[0000.675] I> TOS boot-params @ 0x85000000
[0000.678] I> TOS params prepared
[0000.682] I> Loading EKS ...
[0000.684] I> A/B: bin_type (15) slot 0
[0000.688] I> Loading partition eks at 0x85905800
[0000.692] I> Reading two headers - addr:0x85905800 blocks:1
[0000.698] I> Addr: 0x85905800, start-block: 29397000, num_blocks: 1
[0000.717] I> Binary(15) of size 1040 is loaded @ 0x85905800
[0000.722] I> EKB detected (length: 0x400) @ 0x85905800
[0000.727] I> Copied encrypted keys
[0000.731] I> boot profiler @ 0x175844000
[0000.735] I> boot profiler for TOS @ 0x175844000
[0000.739] I> Unhalting SCE
[0000.742] I> Primary Memory Start:80000000 Size:70000000
[0000.747] I> Extended Memory Start:f0110000 Size:856f0000
[0000.754] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:17, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0000.975] I> Welcome to Cboot
[0000.978] I> Cboot Version: t186-00029e71
[0000.982] I> CPU-BL Params @ 0x175800000
[0000.986] I> 0) Base:0x00000000 Size:0x00000000
[0000.990] I> 1) Base:0x177f00000 Size:0x00100000
[0000.995] I> 2) Base:0x177e00000 Size:0x00100000
[0000.999] I> 3) Base:0x177d00000 Size:0x00100000
[0001.004] I> 4) Base:0x177c00000 Size:0x00100000
[0001.008] I> 5) Base:0x177b00000 Size:0x00100000
[0001.013] I> 6) Base:0x177800000 Size:0x00200000
[0001.017] I> 7) Base:0x177400000 Size:0x00400000
[0001.022] I> 8) Base:0x177a00000 Size:0x00100000
[0001.026] I> 9) Base:0x177300000 Size:0x00100000
[0001.031] I> 10) Base:0x176800000 Size:0x00800000
[0001.035] I> 11) Base:0x30000000 Size:0x00040000
[0001.040] I> 12) Base:0xf0000000 Size:0x00100000
[0001.044] I> 13) Base:0x30040000 Size:0x00001000
[0001.049] I> 14) Base:0x30048000 Size:0x00001000
[0001.053] I> 15) Base:0x30049000 Size:0x00001000
[0001.058] I> 16) Base:0x3004a000 Size:0x00001000
[0001.062] I> 17) Base:0x3004b000 Size:0x00001000
[0001.066] I> 18) Base:0x3004c000 Size:0x00001000
[0001.071] I> 19) Base:0x3004d000 Size:0x00001000
[0001.075] I> 20) Base:0x3004e000 Size:0x00001000
[0001.080] I> 21) Base:0x3004f000 Size:0x00001000
[0001.084] I> 22) Base:0x00000000 Size:0x00000000
[0001.089] I> 23) Base:0xf0100000 Size:0x00010000
[0001.093] I> 24) Base:0x00000000 Size:0x00000000
[0001.097] I> 25) Base:0x00000000 Size:0x00000000
[0001.102] I> 26) Base:0x00000000 Size:0x00000000
[0001.106] I> 27) Base:0x00000000 Size:0x00000000
[0001.111] I> 28) Base:0x84400000 Size:0x00400000
[0001.115] I> 29) Base:0x30000000 Size:0x00010000
[0001.120] I> 30) Base:0x178000000 Size:0x08000000
[0001.124] I> 31) Base:0x00000000 Size:0x00000000
[0001.129] I> 32) Base:0x176000000 Size:0x00600000
[0001.133] I> 33) Base:0x80000000 Size:0x70000000
[0001.137] I> 34) Base:0xf0110000 Size:0x856f0000
[0001.142] I> 35) Base:0x00000000 Size:0x00000000
[0001.146] I> 36) Base:0x00000000 Size:0x00000000
[0001.151] I> 37) Base:0x1772e0000 Size:0x00020000
[0001.155] I> 38) Base:0x84000000 Size:0x00400000
[0001.160] I> 39) Base:0x96000000 Size:0x02000000
[0001.164] I> 40) Base:0x85000000 Size:0x01200000
[0001.169] I> 41) Base:0x175800000 Size:0x00500000
[0001.173] I> 42) Base:0x00000000 Size:0x00000000
[0001.178] I> 43) Base:0x00000000 Size:0x00000000
[0001.182] GIC-SPI Target CPU: 4
[0001.185] Interrupts Init done
[0001.189] calling constructors
[0001.192] initializing heap
[0001.194] initializing threads
[0001.198] initializing timers
[0001.201] creating bootstrap completion thread
[0001.206] top of bootstrap2()
[0001.209] CPU: ARM Cortex A57
[0001.212] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.217] initializing platform
[0001.220] I> Bl_dtb @0x85205400
[0001.223] I> gpio framework initialized
[0001.228] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.237] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.245] I> GPIO framework and drivers are initialized.
[0001.250] I> Boot-device: eMMC
[0001.257] I> sdmmc bdev is already initialized
[0001.288] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0001.305] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.311] W> opt-in fuse is not set, skip fuse_burning
[0001.316] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.322] W> No valid slot number is found in scratch register
[0001.327] W> Return default slot: _a
[0001.337] I> A/B: bin_type (21) slot 0
[0001.340] I> Loading kernel-dtb from partition
[0001.345] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.371] I> Kernel_dtb @0x80000000
[0001.374] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.382] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.392] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.400] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.406] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.413] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.423] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.431] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.439] I> fixed regulator driver initialized
[0001.461] I> register 'maxim' power off handle
[0001.466] I> virtual i2c enabled
[0001.469] I> registered 'maxim,max77620' pmic
[0001.474] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.484] E> failed to read label property for node 149932: 13
[0001.491] E> failed to read reg property for node 150028: 13
[0001.497] E> failed to read reg property for node 150080: 13
[0001.504] E> failed to read label property for node 150164: 13
[0001.511] E> failed to read reg property for node 150232: 13
[0001.518] E> failed to read reg property for node 150304: 13
[0001.525] I> Find /i2c@c250000's alias i2c7
[0001.529] I> Reading eeprom i2c=7 address=0x50
[0001.558] I> Device at /i2c@c250000:0x50
[0001.562] I> Reading eeprom i2c=7 address=0x57
[0001.591] I> Device at /i2c@c250000:0x57
[0001.595] I> Find /i2c@3160000's alias i2c0
[0001.599] I> Reading eeprom i2c=0 address=0x50
[0001.604] E> I2C: slave not found in slaves.
[0001.608] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.616] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.622] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.631] E> eeprom: Failed to read I2C slave device
[0001.636] I> Eeprom read failed 0x3526070d
[0001.641] I> Find /i2c@3180000's alias i2c2
[0001.645] I> Reading eeprom i2c=2 address=0x54
[0001.649] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.654] C> GPIO driver for chip_id 0x2 could not be found
[0001.659] E> cam_eeprom_read: Can't get gpio driver
[0001.664] I> Eeprom read failed 0x4d4d000d
[0001.668] I> Reading eeprom i2c=2 address=0x57
[0001.672] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.677] C> GPIO driver for chip_id 0x2 could not be found
[0001.682] E> cam_eeprom_read: Can't get gpio driver
[0001.687] I> Eeprom read failed 0x4d4d000d
[0001.691] I> create_pm_ids: id: 3636-0001-300-H, len: 15
[0001.696] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.707] I> create_pm_ids: id: 3449-0000-400-D, len: 15
[0001.712] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.735] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.746] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.751] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0001.758] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.765] E> cannot find any other nvdisp nodes
[0001.769] E> no valid display unit config found in dtb
[0001.775] W> display init failed
[0001.778] initializing target
[0001.781] calling apps_init()
[0001.784] starting app kernel_boot_app
[0001.807] I> found decompressor handler: lz4-legacy
[0001.812] I> decompressing BMP blob ...
[0001.824] I> Kernel type = Normal
[0001.827] I> ########## Fixed storage boot ##########
[0001.832] I> Loading kernel-bootctrl from partition
[0001.837] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0001.851] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0001.858] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0001.865] W> No valid slot number is found in scratch register
[0001.870] W> Return default slot: _a
[0001.874] I> A/B: bin_type (24) slot 0
[0001.889] I> Boot image size read from image header: 20e3008
[0001.895] I> Boot image load address: 0x80400000
[0001.899] I> Loading kernel from partition
[0001.903] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.846] I> Validate kernel ...
[0002.849] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0002.930] I> Decrypt the buffer ... [0002.933] W> tegrabl_decrypt_block: fuse (0x0) is not burnt to do encryption (0x4); skip decryption.
[0002.942] I> done
[0002.944] I> Checking boot.img header magic ... [0002.948] I> [OK]
[0002.950] I> kernel-dtb is already loaded
[0002.954] I> Validate kernel-dtb ...
[0002.957] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0002.964] I> Decrypt the buffer ... [0002.967] W> tegrabl_decrypt_block: fuse (0x0) is not burnt to do encryption (0x4); skip decryption.
[0002.976] I> done
[0002.978] I> Kernel hdr @0x80400000
[0002.981] I> Kernel dtb @0x80000000
[0002.985] I> decompressor handler not found
[0002.989] I> Copying kernel image (34484232 bytes) from 0x80400800 to 0x82800000 ... [0003.010] I> Done
[0003.011] I> Move ramdisk (len: 0) from 0x824e4000 to 0x96820000
[0003.018] I> Updated bpmp info to DTB
[0003.023] I> Ramdisk: Base: 0x96820000; Size: 0x0
[0003.028] I> Updated initrd info to DTB
[0003.031] W> WARN: Fail to override "console=none" in commandline
[0003.037] I> Active rootfs suffix:
[0003.040] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.048] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.055] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.062] I> disabled_core_mask: 0xffffff0c
[0003.066] W> No valid slot number is found in scratch register
[0003.072] W> Return default slot: _a
[0003.075] I> Active slot suffix:
[0003.078] I> add_boot_slot_suffix: slot_suffix =
[0003.083] I> Linux Cmdline: console=ttyS0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb earlycon=uart82
[0003.125] I> Updated bootarg info to DTB
[0003.129] W> MAC addr invalid!
[0003.131] E> Failed to get WIFI MAC address
[0003.135] W> MAC addr invalid!
[0003.138] E> Failed to get Bluetooth MAC address
[0003.143] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3b:34:44
[0003.149] E> Found no plugin manager ids in source DT
[0003.154] W> Add plugin manager ids from board info
[0003.158] W> "plugin-manager" doesn't exist, creating
[0003.163] W> "ids" doesn't exist, creating
[0003.167] W> "connection" doesn't exist, creating
[0003.172] W> "configs" doesn't exist, creating
[0003.176] I> create_pm_ids: id: 3636-0001-300-H, len: 15
[0003.181] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.192] I> create_pm_ids: id: 3449-0000-400-D, len: 15
[0003.197] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.208] I> Adding plugin-manager/ids/3636-0001-300=/i2c@c250000:module@0x50
[0003.215] W> "i2c@c250000" doesn't exist, creating
[0003.220] W> "module@0x50" doesn't exist, creating
[0003.225] I> Adding plugin-manager/ids/3449-0000-400=/i2c@c250000:module@0x57
[0003.232] W> "module@0x57" doesn't exist, creating
[0003.238] I> Adding plugin-manager/ids/3636-0001-300-H
[0003.244] I> Adding plugin-manager/configs/3636-mem-type 00
[0003.249] I> Adding plugin-manager/configs/3636-power-config 00
[0003.255] I> Adding plugin-manager/configs/3636-misc-config 00
[0003.261] I> Adding plugin-manager/configs/3636-modem-config 00
[0003.267] I> Adding plugin-manager/configs/3636-touch-config 00
[0003.273] I> Adding plugin-manager/configs/3636-display-config 00
[0003.279] I> Adding plugin-manager/cvm
[0003.283] W> "chip-id" doesn't exist, creating
[0003.287] I> Adding plugin-manager/chip-id/A02P
[0003.292] W> "odm-data" doesn't exist, creating
[0003.296] I> Adding /chosen/plugin-manager/odm-data
[0003.304] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.310] I> added [base:0xf0200000, size:0x85600000] to /memory
[0003.316] I> added [base:0x175e00000, size:0x200000] to /memory
[0003.322] I> added [base:0x176600000, size:0x200000] to /memory
[0003.328] I> added [base:0x177000000, size:0x200000] to /memory
[0003.333] I> Updated memory info to DTB
[0003.337] E> add_disp_param: failed to get display params for du=0
[0003.344] W> "reset" doesn't exist, creating
[0003.348] W> "pmc-reset-reason" doesn't exist, creating
[0003.354] W> "pmic-reset-reason" doesn't exist, creating
[0003.360] I> Adding ecid(00000001647c63c9200000000b058140) to DT
[0003.366] I> disabled_core_mask: 0xffffff0c
[0003.374] I> Add serial number:1420521014626 as DT property
[0003.382] I> Plugin-manager override starting
[0003.387] I> node /plugin-manager/fragement@0 matches
[0003.394] I> node /plugin-manager/fragement@3 matches
[0003.408] I> Disable plugin-manager status in FDT
[0003.412] I> Plugin-manager override finished successfully
[0003.417] I> tegrabl_load_kernel_and_dtb: Done
[0003.422] E> tegrabl_display_clear: display is not initialized
[0003.427] W> Boot logo display failed...
[0003.431] I> Kernel EP: 0x82800000, DTB: 0x80000000
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.253-tegra (matiss@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #3 SMP PREEMPT Fri1
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 85600000
[ 0.000000] OF: fdt: - 175e00000 , 200000
[ 0.000000] OF: fdt: - 176600000 , 200000
[ 0.000000] OF: fdt: - 177000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 990776
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb earlycon
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 30076(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3163200K/4026368K available (15358K kernel code, 2956K rwdata, 6704K rodata, 8640K init, 612K bss, 109504K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008200000 - 0xffffff8009100000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8009100000 - 0xffffff8009790000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009790000 - 0xffffff800a000000 ( 8640 KB)
[ 0.000000] .data : 0xffffff800a000000 - 0xffffff800a2e3008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a2e3008 - 0xffffff800a37c0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03dc8000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0f7200000 ( 3954 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009299] Console: colour dummy device 80x25
[ 0.013967] console [tty0] enabled
[ 0.017533] bootconsole [uart8250] disabled
I suppose it’s something to do with the display timing, because it’s 31.25 MHz in DTS:
display-timings {
480x800-32 {
clock-frequency = <31250000>;
hactive = <480>;
vactive = <800>;
hfront-porch = <46>;
hback-porch = <44>;
hsync-len = <4>;
vfront-porch = <15>;
vback-porch = <16>;
vsync-len = <1>;
nvidia,h-ref-to-sync = <0>; // ?
nvidia,v-ref-to-sync = <1>; // ?
